ESP8622 - how to send the $wyslij variable to the ESP8622 to control a relay?
globalinfo 2700 3
  • #1 15604077
    globalinfo
    Rate: 30
    Hello everyone.
    I have this code on my website.
    Code: PHP
    After executing this code I would like to send the variable $wyslij to the ESP8622 which will turn the valve on or off.
    Can you please suggest how this can be done. :?: :idea:
  • #2 15605291
    szymon122
    Help: 302
    Rate: 757
    192.168.1.1/$wyslij
    (give IP esp8266 in place of this IP).
  • #3 15605386
    globalinfo
    Rate: 30
    I am attaching the connection layout for the NodeMcu and the relay module, in case anyone doesn't know how to do it.
    • Przekaźnik.jpg (154.31 KB) You must be logged in to download this attachment.
  • #4 15805536
    piotr411
    Help: 43
    Rate: 45
    This is not a good connection, the power supply should be before the AS1117, i.e. connected under Vin. It is a good idea to add a transistor on the GPIO, as the maximum load of the ESP is only 12mA
