How to address PCF8574 with ESP8266 in LUA - code examples
piotr411 6621 1
  • #1 15812942
    piotr411
    Help: 43
    Rate: 45
    The PCF8574 expander, fits perfectly with the ESP and is relatively cheap. I write relatively cheap, because using an AVR e.g. AM8 as a port expander the Atmega may turn out to be cheaper. Simple examples of how to address the above chip in LUA.
    All ports zeroed, i.e. high state:
    Code: Lua
    Port1 ON
    Code: Lua
    Scanner:
    Code: Lua
    Port readout and address scanner I will insert the PCF in a free chili.
  • #2 15929526
    panbosman
    When will you have that free moment?
