PAN06 & Vera Lite - Analogue switch controls only one light
HanSolo 2364 0
  • #1 15840701
    HanSolo
    Rate: 12
    Hi. I have connected the above mentioned switch to the installation.
    From the computer, everything works as it should. You can turn the lights on and off.
    Unfortunately from the position of the analogue switch it does not work as it should. Both buttons turn on and off only 1 light.
    I have to turn the other one on or off via the app.
    The control unit is Vera Lite.
