TCP/IP tester with SSL for Windows/cross-platform - alternative to PacketSender
piotrva 2601 6
  • #1 15893033
    piotrva
    Help: 625
    Rate: 735
    Dear forumers,
    Briefly and to the point. There is a very cool program for testing TCP/IP and UDP connections: https://packetsender.com/
    Unfortunately it lacks the option to connect TCP/IP with SSL (I'm currently working on an IoT device that is supposed to use such connections).
    Do you know of any program (preferably running on Windows / cross platform) that supports the above functionality along with SSL encryption?
    Preferably in the form of an application similar to PacketSender.
    Thank you in advance for specific answers (to be more precise - I know I can write such a program in C++ or whatever, but I am looking for a ready-made solution).
    Regards
    PR
    waxman
    Help: 36
    Rate: 64
    Wireshark, ethereal... there's a lot of it
  • #3 15893217
    piotrva
    Help: 625
    Rate: 735
    But these are programs for capturing/analysing data, I'm talking about the program being a SERVER.
    Unless I don't know something and you can use Wireshark to pretend to be a TCP/IP server....
  • #4 15895671
    waxman
    Help: 36
    Rate: 64
    Forgive me for not having read this. Of the programs I listed, only Wireshark would have such an option, but you would have to create it yourself, e.g. in LUA. How about something like this: https://www.charlesproxy.com/download/ ?
    KeinXor
    Help: 62
    Rate: 63
    IO Ninja has the ability to run a TCP server but I don't know if it can handle SSL.
    http://tibbo.com/ninja.html
  • #6 15899889
    piotrva
    Help: 625
    Rate: 735
    IO Ninja does not have a server option. But Swoon by the way b. cool software. And has a serial sniffer ;)
  • #7 15910043
    Szymon Tarnowski
    Help: 61
    Rate: 181
    How about a stunnel from the openssl package? I think I also once saw a standalone use of openssl that could also do something like this but I think it could only put up its own https server.
