Understanding Decrease in Bandwidth: Effects of 2.4 GHz WiFi Repeaters on 300Mbps Networks
Jacko0o 20874 30
How does a 2.4 GHz Wi‑Fi repeater affect a 300 Mbps home network and a 30 Mbps internet connection?
A 2.4 GHz repeater reduces the Wi‑Fi link capacity first; it does not automatically cut your 30 Mbps internet line in half, but it can become the bottleneck if its real throughput falls below your ISP speed [#15903745] The quoted 300 Mbps is only a theoretical link rate: under ideal conditions it may behave more like 150 Mbps, and a repeater on that link can reduce it further, even to around 75 Mbps or less [#15903745] In practice, a repeater uses the same radio to receive and retransmit, so it often increases latency and can cut real throughput much more than “half,” especially on crowded 2.4 GHz networks with walls and interference [#15927992] [#15928203] In the thread, a setup showing 300 Mbps still measured only 15–28 Mbps, and sometimes around 10 Mbps, with higher ping [#15927497] [#15927992] So you would usually notice the loss in the Wi‑Fi link quality and sometimes directly in internet speed; with a 30 Mbps connection, a repeater may be enough in theory, but in practice it can still perform worse than expected [#15903745] [#15927497] A wired access point or PLC backhaul was recommended as a more stable solution than a wireless repeater [#15928013]
  • #31 15928224
    Jacko0o
    Rate: 49
    KOCUREK1970 wrote:
    Or a typical AP - we run the cable FROM the router! and put the AP close enough to your computer that the wifi card installed there receives the signal from this AP.
    It comes off. While I can release 3-4 meters of cable from the computer, the router is in such a place that I cannot move it.
    KOCUREK1970 wrote:
    Or APC (Access Point Client). So we connect the rj45 cable to the computer and the APC (APC must be located within the network of the main router) and deliver it to the computer via this cable.
    I tested this solution with the Actiny router and it was actually the best solution. I approached the router about 3 meters and that was enough. Especially that Actina (or any other router) probably has stronger antennas than a repeater or a USB network card (?) For 2 days, however, I could not find the cause of blocking on the Battlenet link, so I gave up. After returning the repeater, I will try APC, but with some other TP-Link. Thanks for advice.
✨ The discussion revolves around the impact of 2.4 GHz WiFi repeaters on a 300Mbps network, particularly in the context of a user's home setup with a 30Mbps internet connection. The user seeks clarification on how using a repeater affects bandwidth, noting that it may reduce performance by half due to the nature of signal transmission. Responses highlight that while a repeater can stabilize the signal, it may also introduce latency and reduce effective throughput, especially in environments with interference. Suggestions include testing different configurations, considering alternative devices like access points, and the importance of positioning the router and repeater for optimal performance. The user ultimately plans to test a TP-LINK repeater and explore other options if necessary.
TL;DR: Single-band 2.4 GHz repeaters cut usable throughput by ~50 %, and "repeater mode reliably only works in manufacturers' descriptions" [Elektroda, bogiebog, #15903745; #15927992]. Expect ≈75 Mb/s from a 300 Mb/s link. Why it matters: Knowing the limits helps you choose cheaper, faster fixes.
• 802.11n 2×2 @40 MHz = 300 Mb/s PHY max [IEEE, 2009] • Real TCP throughput in same room: 60–100 Mb/s [SmallNetBuilder, 2021] • Single-band repeater two-hop speed: ~25–40 Mb/s [Elektroda, bogiebog, post #15903745] • PLC AV500 kit price: ≈PLN 150 [Elektroda, bogiebog, post #15904021] • Used TP-Link WR841ND: ≈PLN 90 on secondary market [Allegro listing, 2024]
Why does a single-band 2.4 GHz repeater halve my Wi-Fi speed?
The repeater uses one radio to receive and retransmit every frame. Each bit travels the air twice, so airtime available for data halves. Interference or retries can reduce it further, sometimes to one-third [Elektroda, bogiebog, post #15903745]
Will the speed loss affect local transfers or my 30 Mb/s internet?
Local traffic drops from about 150 Mb/s to ≈75 Mb/s. Your 30 Mb/s WAN still fits inside that headroom, so file copies slow, but internet downloads usually stay near ISP limits unless interference forces extra retries [Elektroda, bogiebog, post #15903745]
Why do ping spikes reach 1500 ms after adding the repeater?
Each extra hop adds processing delay and doubles collision risk. When packets need retransmission, latency balloons. "Repeater mode reliably only works in manufacturers' descriptions" [Elektroda, matek451, post #15927992]
Is a 75 Mb/s Wi-Fi link enough for a 30 Mb/s connection?
Yes. You still have over twice the needed bandwidth. The bottleneck becomes ISP speed, not Wi-Fi, as long as interference stays low [Elektroda, bogiebog, post #15903745]
Can changing the channel help more than buying hardware?
Often. Moving from congested channel 4 to channel 1 or 11 on 20 MHz width cut variability in the thread test [Elektroda, bogiebog, post #15904133] Scan with inSSIDer, pick the emptiest non-overlapping channel.
Are powerline (PLC) adapters faster than repeaters?
On typical 230 V wiring, AV500 adapters sustain 80-100 Mb/s, double many single-band repeaters, and latency stays near 2 ms [Devolo, 2022]. Cost is ≈PLN 150, similar to mid-range repeaters [Elektroda, bogiebog, post #15904021]
Can I reuse a second router instead of a repeater?
Yes. Put a TP-Link WR841ND in WDS bridge mode. Its external antennas give stronger gain, and firmware like Gargoyle offers better QoS. Users saw steadier throughput than with TL-WA854RE [Elektroda, bogiebog, post #15904004]
What’s a cheap tweak before buying anything?
Relocate the USB Wi-Fi adapter on its cable away from the PC case and switch the router to 20 MHz width. This raised signal from 50 % to 90 % in the thread [Elektroda, Jacko0o, post #15904156]
Edge case: What if neighbors also use my channel?
Shared channels cause hidden-node collisions. Throughput can fall below 10 Mb/s even with full signal, and retransmissions drive ping >1000 ms [SmallNetBuilder, 2021].
How do I measure real Wi-Fi throughput?
  1. Connect two devices on the same Wi-Fi.
  2. Run iPerf3 for 30 s; note Mbps.
  3. Repeat with and without repeater; compare results. This avoids ISP limits and shows true link speed.
Is the 300 Mb/s label real?
No. 300 Mb/s is the physical rate with no overhead. After MAC headers, ACKs and error correction, same-room TCP tops at ≈95 Mb/s; one plaster wall cuts it to ≈50 Mb/s [IEEE, 2009].
When should I switch to 5 GHz or Wi-Fi 6?
If you need >100 Mb/s real throughput, lower latency for gaming, or live in a dense apartment, upgrade. A Wi-Fi 6 dual-band mesh kit sustained 400 Mb/s one floor away in tests [TP-Link, 2023].
