Linux-based SoM modules for H.264 image processing, max 6mm high
al555 2487 4
  • #1 16079446
    al555
    Help: 32
    Rate: 8
    Does anyone know of any SoM ( System on Module) modules similar to the Samsung Artik on which you can run Linux, with enough power to process camera video and display on a large 10" LCD, with H.264 video decoding preferably hardware-based.
    Unfortunately the module cannot be large, total height max 6mm so any RJ45, USB etc connectors are out.
    Is it only Samsung that has come up with something like this ?
    I have looked at Olimex, Kristech, Pi Zero, Odroid, nanoPI solutions.
    Basically I'm looking for a twin solution to the Artik.
    Anyone somewhere not seen something similar ?
  • #2 16174816
    Soyter.pl
    Check out the GRINN and Variscite solutions; you will find products from these companies in our shop.
    Soyter Components
    Ekologiczna 14/16, Warszawa, 05-080 | Tel.: +48XXXXXXXXX (Show) | Company Website: www.soyter.pl
  • #3 16174867
  • #4 16174973
    JarekC
    Level 32  
    Help: 231
    Rate: 399
    Welcome,
    Please specify which input and output interfaces you need.
    JarekC
