How to power the ESP-12E NodeMCU V3 from a 6V AAA battery?
Poczatkujacy11 4815 12
How can I power an ESP-12E NodeMCU V3 from a 6V battery pack?
You should not feed a bare ESP-12E with 5V; it needs about 3.0–3.6V, so from 6V AAA cells the right solution is an LDO/linear regulator to 3.3V [#16104945][#16104793] If you are powering the NodeMCU board itself, it already has a voltage regulator, so 5V input is acceptable [#16158559][#16158439] For a regulator, a dropout of about 0.5V is enough for this 6V-to-5V or 6V-to-3.3V step, and the ESP can draw roughly 200–300mA, so choose a part with adequate current headroom; 1A is fine if you want margin [#16105027][#16104813][#16104846][#16104863]
  • #1 16104409
    Poczatkujacy11
    Hello, I am new to the forum and immediately have a question :)
    I have an ESP8266 ESP-12E NodeMCU V3 module that I would like to power with batteries. I also have a basket for 4 AAA batteries, which give a total of 6V. And now my question, can you recommend me maybe the best way to make 5V from 6V? Because this is the voltage that the :) module should be powered with
    Thank you in advance for your answer.
  • #2 16104444
    cyann
    Help: 44
    Rate: 18
    Inverter or linear stabiliser.
  • #3 16104647
    Poczatkujacy11
    And won't the difference between input and output voltage be too small for the stabiliser?
    Added after 4 [minutes]:
    Because when I look at the specs on the internet, I see that usually around 2V there should be a difference
    cyann
    Help: 44
    Rate: 18
    Look for LDO stabilisers
  • #5 16104813
  • #6 16104846
    Poczatkujacy11
    Thanks :) and maybe you know of a specific stabiliser? because now I find ones with a max dropout voltage of 0.5V. But it's always me closer :)
    Added after 36 [seconds]:
    1A is enough?
  • #7 16104863
    cyann
    Help: 44
    Rate: 18
    Poczatkujacy11 wrote:
    1A is enough?
    And what does the circuit's datasheet note say about current draw?
    because I now find such with a max dropout voltage of 0.5V.
    I think that's about right? What is wrong with them?
  • #8 16104945
    olo
    Rate: 13
    Hello, the ESP module should be supplied with a voltage in the range of 3-3.6V
  • #9 16104956
    Poczatkujacy11
    From what I have found it is so 200-300mA.
    And that in my case is not 1V?
    This my module can be 5V :)
    cyann
    Help: 44
    Rate: 18
    And this in my case is not 1V?
    For a stabiliser that has DO 0.5V to work, the difference must be at least 0.5V.
    So it will be OK.
  • #11 16105042
    Poczatkujacy11
    Well yes, I blacked out, sorry for the confusion and thanks for the conversion :) And as for that 1A, I think it will be fine, better to have some stock :)
  • #12 16158439
    el2010tmp
    Help: 97
    Rate: 43
    to make 5V from 6V? Because that's the voltage the module should be powered with :)
    The ESP-12E will not survive five volts.
  • #13 16158559
