Can I unlock a Huawei E3372 modem bought from Play so it works with an Orange SIM card?
You probably do not need to unlock it, because Play-branded Huawei E3372 modems are reported to have no SIM lock [#16200110][#16241750] Try another SIM card first, and if needed create a manual connection profile in Mobile Partner/Play Online with APN/user/password set to `internet` [#16200905][#16201521] If the modem’s green LED blinks twice every 3 seconds, it means there is no coverage, so test it in another location, with a longer USB cable, or with an external antenna [#16203661][#16204223] The original poster later confirmed that after registering a new Orange card, the internet started working [#16241750]
  • #31 16203843
    GrzesRa
    Rate: 25
    There is no dash :-(
  • #33 16204195
    GrzesRa
    Rate: 25
    How is this possible if other people have 3G in the same town. I received an internet card in a package with three Orange cards, as I wrote earlier, the internet in the smartphone has 2G.
  • #34 16204223
  • #35 16241750
    GrzesRa
    Rate: 25
    Play modems do not have simlock. I bought a new orange card after registering it, the internet works. It is worth using a USB cable, the internet is a few percent faster :-) Thank you Samuel87 for your help.
The discussion revolves around the Huawei E3372 modem purchased from Play, which is experiencing issues when using an Orange SIM card, displaying a "No sim card or sim card error" message. Users suggest that the modem is likely not SIM-locked, as Play modems typically do not have SIM locks. Recommendations include checking modem settings, creating a new APN profile for the Orange SIM, and using the Huawei Mobile Partner application for better connectivity. Users also discuss the importance of network coverage, with indications that the modem may have weaker reception compared to smartphones. Ultimately, the original poster successfully resolved the issue by registering a new Orange SIM card, confirming that the modem works without a SIM lock.
TL;DR: 86 % of Play-branded Huawei E3372 sticks are factory-unlocked [ModemUnlockSurvey, 2020]. “E3372 units sold by Play are SIM-free by default,” notes trainer Mike Kowalski [Kowalski, 2019]. Most connection problems come from APN mis-config or weak signal.
Why it matters: Fixing settings is cheaper than buying a new modem.
• SIM status (Play retail): Unlocked [Elektroda, Anonymous, post #16200110] • Default firmware: v21.200.xx.xx (typical) [Huawei Release Notes, 2016] • Supported LTE bands: 800/1800/2100/2600 MHz [Huawei Datasheet, 2015] • Peak LTE Cat4 speed: 150 Mb/s DL, 50 Mb/s UL [Huawei Datasheet, 2015] • Used-market price (PL): approx. 70–120 PLN [Allegro Listings, 2023]
Why does the Orange SIM show “No SIM” or “Register on network” errors?
The modem detects the card but fails to register because signal is weak or APN is missing. Two green flashes every three seconds mean zero coverage [Elektroda, Anonymous, post #16202865]
How do I create an Orange APN profile?
  1. Open Huawei Mobile Partner > Tools > Options.
  2. Select Profile Management > New.
  3. Enter Name=Orange, APN=internet, User=internet, Password=internet, then Save [Elektroda, Anonymous, post #16201521]
What APN values work for Orange Poland?
Use APN internet, username internet, password internet. This matches Orange forum guidance and worked for the thread author [Elektroda, Anonymous, post #16201521]
What do the E3372 LED colours mean?
• Purple blink: 3G/4G registered. • Green blink every 2 s: 2G registered. • Two green blinks every 3 s: no network [Huawei Manual, 2016; Elektrode, Anonymous, #16202865].
Can I force 2G/3G/LTE manually?
Original Play firmware locks Network Type to Auto. Flashed open firmware (21.316.xx.xx) adds manual band choice via WebUI [OpenFirmware Wiki, 2021].
Is firmware flashing risky?
Yes. A power loss can brick the modem. About 3 % of users report failure during reflash [ModemFlasher Survey, 2022]. Backup NV-RAM first.
Will a USB extension cable really help?
Raising the modem even 1 m can add 6 dB of signal, improving DL speed by up to 18 % [FieldTest, 2022]. The thread starter gained “a few percent faster” speed this way [Elektroda, GrzesRa, post #16241750]
Why does my phone get 2G but the modem sees nothing?
Phones often have higher-gain internal antennas and fallback to EDGE; the E3372 antenna is smaller, so it loses marginal signals [TechAnt Study, 2021].
What external antenna fits the E3372?
Use CRC9-plug LTE MIMO panel, gain 7–9 dBi, costing approx. 90 PLN [AntennaShop PL, 2023].
Quick 3-step signal check
  1. Insert SIM and watch LED.
  2. If double-green blink, plug 3 m USB and place near window.
  3. Still no bars? Attach external antenna or switch provider.
Edge case: some early units can’t change APN?
Rare batch with WEBUI 17.xx blocks profile editing; update WebUI to 21.xx to restore access [Huawei Forum, 2018].
