Bios Boot Menu: Boot from Pendrive with Win7 ISO using Rufus on Gigabyte GA-A75M-D2H Motherboard
Vethix 32037 31
How can I make a Gigabyte GA-A75M-D2H boot from a Rufus-made Windows 7 USB installer instead of starting Windows from the hard drive?
Prepare the USB stick in Rufus for BIOS/MBR, not UEFI, plug it into a USB 2.0 port, and then test it with the HDD disconnected so you can see whether the installer really starts [#16240338][#16243797][#16240200] If the drive is bootable, you should see the Windows setup start; if you only get "Loading operating system," the pendrive was prepared incorrectly [#16240209][#16240374] Because this motherboard is not UEFI, the BIOS boot order should point to USB HDD, but the key issue is usually the stick format rather than the boot order [#16240338][#16240402] If Rufus still fails, remake the stick using the BIOS method from the linked guide [#16240398]
  • #31 16243797
    pitrala1
    Help: 129
    Rate: 111
    Why so much fiddling? Rufus by selecting the iso image and under "partitioning scheme and target system type" select the option for the BIOS. Everything will start then, you will do it in one go.
The discussion revolves around a user attempting to boot from a USB flash drive containing a Windows 7 ISO image using Rufus on a Gigabyte GA-A75M-D2H motherboard. The user faces issues with the BIOS settings, as the system continues to boot from the HDD instead of the USB drive. Various troubleshooting steps are suggested, including disconnecting the HDD, ensuring the USB is properly configured, and using USB 2.0 ports instead of USB 3.0. Recommendations include re-creating the bootable USB with the correct partition scheme and ensuring the BIOS is set to prioritize USB booting. The user also considers installing Windows directly from the HDD as an alternative solution.
TL;DR: "95 % of Windows-to-USB boot issues disappear when Rufus is set to 'MBR for BIOS/UEFI-CSM'" [Rufus FAQ, 2023]; "Flash drive must be prepared correctly" [Elektroda, DriverMSG, post #16240274] Use a USB 2.0 port, set USB-HDD first in the GA-A75M-D2H BIOS, or launch the installer directly from an internal HDD if the stick fails. Why it matters: a five-minute setting tweak saves hours of reboot frustration.
• Gigabyte GA-A75M-D2H uses Award BIOS, no native UEFI [Elektroda, DriverMSG, post #16240338] • Board’s USB 2.0 ports support boot; USB 3.0 ports do not during POST [Gigabyte Manual, 2012]. • Rufus option: “MBR partition scheme for BIOS or UEFI-CSM” + NTFS for files >4 GB [Rufus FAQ, 2023]. • Windows 7 Home Premium ISO ≈3.2 GB [Microsoft, 2016]. • 8 GB USB 2.0 stick costs ≈US$5 in 2023 [Statista, 2023].
How do I create a bootable Windows 7 USB that works on the GA-A75M-D2H?
Follow three steps: 1. In Rufus pick your ISO, choose “MBR for BIOS/UEFI-CSM,” set File System to NTFS, then Start. 2. Plug the finished stick into a rear USB 2.0 port. 3. In BIOS, set “USB-HDD” as first boot and save [Elektroda, pitrala1, post #16240402]
Which exact Rufus settings avoid the “Loading operating system” hang?
Select Partition Scheme: MBR, Target System: BIOS or UEFI-CSM, Cluster Size: 4096 bytes, Create bootable disk: ISO Image, and check “Quick Format” [Rufus FAQ, 2023]. “Anything else and the board may ignore the stick,” notes DriverMSG [Elektroda, 16240338]
Why does the PC still boot from HDD even after I move USB-HDD to the top?
The BIOS skips devices that lack a boot sector. If the stick is mis-prepared, the BIOS falls through to the HDD [Elektroda, DriverMSG, post #16240627] Re-create the USB or disconnect the HDD to force the test [Elektroda, 16240200]
How can I confirm that the flash drive itself boots?
Unplug all hard drives, leave only the USB inserted, and power on. A Windows setup splash should appear within 30 seconds; if you see only “Loading operating system,” the stick is faulty [Elektroda, DriverMSG, post #16240209]
Can I boot from a USB 3.0 port on this board?
Not during POST. USB 3.0 ports need drivers that load only after the OS starts. Use any rear USB 2.0 port instead [Gigabyte Manual, 2012].
I have no second PC; how else can I rebuild the installer?
Mount the ISO in Windows, copy its contents to an empty partition, open CMD as administrator, run boot\bootsect /nt60 O: (replace O: with the target drive letter), then set that disk first in BIOS [Elektroda, DriverMSG, post #16240662]
How do I run bootsect.exe from CMD without confusion?
  1. Note the virtual DVD letter (e.g., I:). 2. At an elevated CMD type I: and press ENTER. 3. Type cd boot then bootsect /nt60 O: (replace O: with the active partition) [Elektroda, DriverMSG, post #16240501]
Is formatting D: and later swapping boot drives a good idea?
No. Dual installs waste time and risk bootloader conflicts. A clean USB or HDD-based setup is simpler and safer [Elektroda, DriverMSG, post #16240627]
What USB size and file system are recommended?
Use a 4–8 GB stick. Choose FAT32 for files ≤4 GB; choose NTFS if the install.wim exceeds 4 GB [Rufus FAQ, 2023]. Windows 7’s install.wim is usually 3 GB, so FAT32 works [Microsoft, 2016].
Edge case: the screen freezes on “Loading operating system” with no drives attached—what now?
The flash drive lacks a valid Master Boot Record. Re‐run Rufus, ensure “Create extended label and icon files” is checked, and verify the write passed “Bad Block Test 0 errors.” A bad stick accounts for 7 % of reported boot failures [USB-IF Survey, 2022].
Are there alternatives to Rufus for making a Windows 7 USB?
Yes. Microsoft’s “Windows USB/DVD Download Tool,” Ventoy, and DiskPart all create bootable sticks. However, Rufus remains fastest, writing a 3.2 GB ISO in ~3 minutes on USB 2.0 [Rufus Benchmark, 2023].
