Fibaro Home Center - Correct Image Path for Edimax IC-3115W IP Camera Integration
POMOCRTV 3045 1
  • #1 16244629
    POMOCRTV
    Rate: 27
    I have purchased the Fibaro Home Center system and I have a problem with connecting to the Edimax IC-3115W IP camera.
    Specifically, I want to know how to set the image path of the camera so that I can view it via the Fibaro system.
    I found somewhere on the website that in the jpg path I have to enter: <i>http://mój_login:moje_haslo@192.168.0.104/snapshot.jpg?account=mój_login&password=password</i>.
    The camera on the internal network works on ip:192.168.0.104 and I can access it without any problem.
    Fibaro unfortunately does not want to show me an image from it:(
  • #2 16251063
    POMOCRTV
    Rate: 27
    The topic is closed. I handled the problem myself. I don't know why, but it only worked to add a camera via a plugin.
    Select the plugins tab then on the left hand side install. It turned out that there is a plugin ready to be installed for this camera model. Well and eureka :) after entering the data I can access and see the camera image.
