KBSound ISelect 5'' 2012 - Audio Input Options for Raspberry Pi Connection
Pimpel1981 2343 5
  • #1 16290607
    Pimpel1981
    Does anyone have any knowledge whether it is possible to connect an audio signal from a raspberry pi to a KBSound ISelect 5' radio (purchased in 2012, without Bluetooth module)? Unfortunately I can't find any information on whether the head unit has any audio input (e.g. jack or coaxial), and at the moment I don't have access to it. I'd like to know the possibilities before I start stripping the ceiling to get to the radio (unfortunately the team setting up the place placed the radio in a rather impractical way).
  • #2 16293264
    sosarek
    Help: 9321
    Rate: 15543
    Pimpel1981 wrote:
    does the head unit have any audio input (e.g. jack or coaxial)
    No, the only option for connecting an additional audio source is a dedicated BT module.
    Z
    Pka, Poznań, 60-850
  • #3 16293281
    Pimpel1981
    Ok, there are BT modules on the market for around 370pln. Do they work with every version of the I select 5 radio or only the new versions where there is a BT sign on the remote control?
  • #4 16293291
    sosarek
    Help: 9321
    Rate: 15543
    Bluetooth module only works with new type radios, before purchasing the module itself, check that there is a Bluetooth logo on your radio.
    - information found on the Distributor's website.
    Z
    Pka, Poznań, 60-850
  • Affordable amplifier with USB-powered Raspberry Pi output
    #5 16293327
    Pimpel1981
    Well, I can see that the hardware is dire, as there is still the option to connect to an Ipod docking station, but these cost over PLN800 each, given that it fits at most an Iphone 4, it's a waste of money.
    Would it be possible to use the remote control and the speakers by connecting it to an amplifier? Then you could somehow coolly add a light sensor diode as a switch. The question is how much would such an amplifier cost to connect the speakers to? It would be even better if it had a powered USB output to power the Raspberry Pi directly from it. I'm just looking for a cheap solution for having a mobile managed Spotify, but using the speakers in the ceiling rather than a free standing BT speaker, as I don't have room for that in the bathroom anymore.
  • #6 16293347
    sosarek
    Help: 9321
    Rate: 15543
    16Ohm speakers, 2x1.5W built-in amplifier - you could be tempted to add an IR receiver to the RPi, plus some sort of low voltage amplifier circuit....
    Z
    Pka, Poznań, 60-850
