What is the operational coverage of the x10 system?
grobelny 2376 1
  • #1 16325678
    grobelny
    What is the practical range of the X10 or other systems sending control data over the power grid? I understand that no one is going to give me an indication of what it will be like at my place, but I could use some general guidance so that I know whether it's worth getting down to some practical testing. In a new-build block of flats, is this coverage a matter of the circuit in the flat (what's on one fuse), the whole flat, the floor, the stairwell, the whole block or rather the estate?
    szymon122
    Help: 302
    Rate: 764
    This is certainly within a single phase. You have to take into account the "attenuation" of the cable, besides that data transmitted in this way has the problem of "passing" through the meter. I wouldn't count on transmission outside your home.
