OpenHAB, ESP8266, MQTT, RaspberryPi: Smart Home Automation for Light/Gate Control and Setup
---trafopowielacz--- 9912 11
How can I program an ESP8266 for home automation with Wi‑Fi and MQTT, and is it a suitable replacement for an ATmega?
The easiest way to start is to program the ESP8266 from the Arduino IDE by installing the additional ESP8266 support package; that gives you many examples for Wi‑Fi connection and basic I/O, so it can serve as a replacement for an ATmega in this kind of project [#16424198] For a convenient development setup, use a NodeMCU-style board, which already includes the ESP, USB-UART converter, buttons, LED, and broken-out pins [#16425922] If you want something ready-made instead of writing everything yourself, ESPEasy is recommended as a good starting point for relays, lighting, and other devices [#16446790][#16447657] Another free option mentioned is SUPLA, which can run on ESP-based flush modules and also works with NodeMCU plus relays [#16582229] You can also choose Lua on NodeMCU firmware if you prefer that approach, but the thread’s main advice is to begin with Arduino support or a ready firmware like ESPEasy/SUPLA rather than starting from bare ESP8266 firmware [#16424205][#16446790]
  • #1 16423755
    Help: 27
    Rate: 177
    Hello. I plan to create some intelligence and automation at home. Mainly light and gate control. I would like to do everything on ESP8266 modules and communication with them via MQTT. The server would be on RaspberryPi with OpenHAB software installed. Only now the question is how to program such an ESP8266 system? I have not dealt with them yet, I am still at the stage of atmega, uarta and BT HC-05. Can anyone suggest how to do this? Only software issues to establish a wifi connection, configure ports and it's MQTT. I am not familiar with Arduino, I can program in Bascom and I do not associate it with Lua or NodeMcu.
    Such an ESP bone would be appropriate? Would it replace atmega? link
  • #2 16423924
    piterek-23
    Help: 162
    Rate: 427
    From what you write, you want to start everything from scratch. See the nettemp.pl forum, it may be easier for you to start.
    There we operate on Raspberry Pi and ESP8266 :)
  • #3 16424012
    Help: 27
    Rate: 177
    I have a basic question. What language is ESP8266 Programmed in?
  • #4 16424198
    ditomek
    Help: 24
    Rate: 230
    You can program Esp8266 and all other tiles with it on board from the Arduino environment. You just need to install an additional package that supports 8266. there are many instructions on how to do this. And I must admit that this is the easiest way of programming. In addition, I advise you to equip yourself in Nodemcu or similar.
    After installing ESP8266 support in the IDE arduino there will be a whole bunch of examples that will show how to connect to the network etc.
  • #5 16424205
    piterek-23
    Help: 162
    Rate: 427
    When I play ESP, I write programs in LUA :)
  • #6 16424486
    Help: 27
    Rate: 177
    Is NodeMcu a device or software for ESP? I would rather do something myself and not upload the ready arduino program. Pure ESP8266 is not enough to write in Lua? I have a Usb-Uart.
  • #7 16425922
    ditomek
    Help: 24
    Rate: 230
    You really didn't think of typing the word nodemcu in Google?
    For 30 PLN you have a plate that has everything on it: ESP, USB converter, pins pinned and described, two buttons, LED
  • #8 16432679
    kosmogon
    Help: 12
    Rate: 8
    And who said you need to upload cash? If you want to write the program your own way, write.
  • #9 16446790
    pawel3110
    Rate: 25
    Check espeasy. It can be enough or good to start with.
  • #10 16447657
    DJ MHz
    Help: 40
    Rate: 254
    I recommend espeasy. I have it combined with domoticz on a raspberry. Control of lighting, relays, devices, for this now I add extra support for infrared equipment and issuing commands to the system with one remote control.
  • #11 16546003
    robja
    I don't really see the sense of doing electronics or software on average
    As for ready ESP modules there are executive modules with relays, infrared, dimmers, 230V power supply.
    can be mounted:
    - up to 4 relays,
    - infrared receiver
    - infrared transmitter
    - infrared sensor
    - 230V power supply
    - connectors needed
    smart home wifi
    It can work on the open eHouse TCP / IP protocol connecting to the server
    eHouse lan / wifi communication protocol
    you can also refer via HTML request or control via WWW directly.
    or you can program it yourself by connecting the programmer to the appropriate pins of the controller
    The firmware of the eHouse controller includes drive control, switching on / off inputs, dimming lighting, 3 LED dimmers 12VDC / 3A PWM, control is from an IR remote control in the SONY standard, Audio / Video equipment control (broadcast in dozens of infrared standards). So it's probably better to send control commands than to break open doors and program a few months.
  • #12 16582229
    Espablo
    Help: 5
    Rate: 48
    And I recommend the free SUPLA project. I have several inCan flush modules on ESP-12 placed on it. However, you can successfully use most modules based on ESP8266, e.g. NodeMcu + relays.
The discussion revolves around setting up a smart home automation system using ESP8266 modules for light and gate control, with MQTT communication and a Raspberry Pi running OpenHAB. Users suggest starting with the Arduino IDE for programming the ESP8266, as it simplifies the process by providing numerous examples. NodeMCU is recommended for its ease of use, and alternatives like ESPEasy and SUPLA are mentioned for their compatibility with ESP8266 modules. The conversation also touches on the possibility of using ready-made ESP modules with integrated relays and other components, as well as the option to program the ESP8266 directly without relying on pre-built solutions.
