ESP8266 Arduino - invalid conversion error from 'const char*' to 'char*'
krzysiekwfd 2595 3
  • #1 16433316
    krzysiekwfd
    Good afternoon I have a problem with the code because the Arduino is throwing me errors even though the program is well written, so please help :)
    error
    Code: C / C++
    error
    entire programme
    Spoiler:
    Code: C / C++
  • #2 16433445
    grko
    Help: 247
    Rate: 141
    Piotrus_999 wrote:
    As you can see, it is not.
    It just so happens that the programme is well-written, only the API for this WiFi is wrong. It was probably written by some opponent of const.
    Piotrus_999 wrote:
    And a simple tip: throw out the "const"
    This simple advice will not work. The compilation error will appear elsewhere. The solution is:
    1. casting when calling WiFi.begin
    2. declare ssid and password as arrays. As in the examples:
    https://www.arduino.cc/en/Reference/WiFiConfig
  • #4 16439883
    krzysiekwfd
    thanks, it's working fine now :) but I have one more question how can I connect several ESP modules together so that one is the main module to which all the data from the other modules are sent and displayed on the server?
