[Solved] Error Compiling ready Sketch on ESP8266 in Arduino IDE
szaryczlowiek831 1146 4
  • Compilation error in ESP8266 Arduino IDE setup
    #1 19792783
    szaryczlowiek831
    I found a weather station on YouTube. In the caption under the video is the address to the source code which you open in the Arduino IDE, type/change in 3 lines of data and it works.
    Me as a green chive in spring. -Let's try
    Yesterday the ordered components arrived, so believing in my strengths I squatted down, downloaded, installed and after spending a total of 7h I managed to figure out which libraries I was missing. But when compiling it gives me an error.
    I have a Nodemcu CH340G V3 board and a MSP 2401 or MSP 2042 shield.
    According to LcdWiki, the driver that is given in the code should fit.
    But it gives an error. Maybe I am using the wrong library?
    I would appreciate any help/advice as to what is wrong.
    • esp8266-weather-station-color.7z (194 KB) You must be logged in to download this attachment.
  • #2 19793176
    ex-or
    Help: 147
    Rate: 151
    szaryczlowiek831 wrote:
    Found multiple libraries in "XPT2046_Touchscreen.h "Used:
    To start with, do a tidy up of the libraries. Check which of these libraries is used in the project and remove the others. It is possible that it is another library, in which case this one needs to be installed and the others removed.
    The same applies to the SPI and ESPWifi libraries.
  • Duplicate libraries not the compile cause
    #3 19793698
    szaryczlowiek831
    Found multiple libraries in "XPT2046_Touchscreen.h "Used: C:C:UsersDocumentsArduinolibraries_ThingPulse_XPT2046_Touch
    Unfortunately deleting the duplicate libraries did not help.
    I still get the same error.
    gps79
    Level 37  
    Help: 495
    Rate: 799
    At the end of the this file is something missing from your settings.h and therefore the compiler throws errors.
  • #5 20030823
    szaryczlowiek831
    Thanks to help on another forum, it turned out that the screen works under a different library.
