FIBARO Dimmer 2 - How to connect a dimmer to a fan without a switch?
LiteMan 7005 20
How do I wire a Fibaro Dimmer 2 between a plug and a fan without using a physical switch, only Z-Wave control?
Wire it like Fibaro’s single-switch diagram, but replace the switch with a permanent jumper/fixed link [#16441986][#16454023] Connect neutral to the N terminal and on to the fan, and connect the protective earth directly to the fan [#16442014] In other words, the Dimmer 2 stays in the circuit and the switch input is simply shorted instead of using a wall switch [#16441986][#16454023] One reply also warned that Dimmer 2 is intended for lighting, so for a fan load or simple on/off control a Relay Switch may be the better choice [#16442014]
  • #1 16441963
    LiteMan
    I can't find a diagram anywhere of how to connect the plug with the three-wire cable to the FIBARO Dimmer 2 and on to the fan, without the intermediary of a switch - just Z-Wave control. Plug > Dimmer2 > Fan. Please help me a lot! Thank you!
  • #2 16441986
    sosarek
    Help: 9321
    Rate: 15545
    After all, it is in the instructions - as for the single switch (wiring diagram no.2), only you put a jumper in its place.
    Z
    Pka, Poznań, 60-850
  • #3 16442003
    LiteMan
    You mean this drawing? ...I don't really understand it, I don't know how to insert this "jumper" - cable permanently? What about the neutral wire? Can someone draw me on my drawing? Pls! FIBARO Dimmer 2 - How to connect a dimmer to a fan without a switch?
  • #4 16442014
    sosarek
    Help: 9321
    Rate: 15545
    Yes, it's about that drawing, yes jumper (fixed cable), neutral is connected to the N terminal and to the consumer (fan), you mean rather PE (protective conductor) - you connect it directly.
    By the way, I wonder how you want to calibrate the Dimmer when the load is a fan. If you intended only to switch it on/off, you should have used a Relay Switch with an appropriate load capacity.
    Z
    Pka, Poznań, 60-850
  • #5 16442025
    LiteMan
    I don't understand. I have a cable with a plug + Dimmer2 + fan with a cable like plug. I don't understand the diagram (for the socket) 2. Please help me a lot and draw me on my drawing how to connect these wires. Thank you for your help.
  • #6 16442030
    sosarek
    Help: 9321
    Rate: 15545
    What do I have to draw for you when the wiring diagram is in the instructions? Relate it to what you sketched at the beginning and that's it - what's so difficult about it?
    Z
    Pka, Poznań, 60-850
  • #7 16442039
    LiteMan
    I thank you for your help, and congratulate you on your knowledge and skill in reading schematics.
    Now I have a request to Dear Forumers to help me draw on my drawing from the attachment how to connect the existing wires to the Dimmer2 - sorry, I can't read wiring diagrams. Thank you for your understanding and understanding. <3
    • FIBARO Dimmer 2 - How to connect a dimmer to a fan without a switch? fibarodimmer2.png (145.14 KB) You must be logged in to download this attachment.
  • #8 16442104
    sosarek
    Help: 9321
    Rate: 15545
    On the diagram you have just attached, it is enough to draw the connections - according to the original Fibaro diagram. If you even have a problem with it, don't even start with electrical connection.
    Besides, as I wrote before - with a fan as a load, Dimmer calibration may be impossible.
    Z
    Pka, Poznań, 60-850
  • #9 16446374
    Krzysztof Reszka
    Help: 609
    Rate: 1552
    Firstly where will this fan be built . And secondly .
    LiteMan wrote:
    I don't understand. I have a cable with a plug + Dimmer2 + fan with a cable like plug. I don't understand the diagram (for socket) 2
    Where in the diagram there is a socket 2 . Where does the mate have the switch that is supposed to be in the circuit.
  • FIBARO Dimmer 2 controls fan without a wall switch
    #10 16453880
    LiteMan
    FIBARO Dimmer 2 - How to connect a dimmer to a fan without a switch? .
    On the left Plug - on the right Fan.
    Thank you for the mass of questions and no answers. On the FIBARO forum, I drew an answer on my diagram after 5 minutes ;) 3 minutes later, I had the connection ready as in the attached photo :) .
    Mr sosarek, - "Apart from that, as I wrote earlier - with the fan as the load it may not be possible to calibrate the Dimmer.
    " - Your advice, is worth as much as your doubts, which is NOTHING! The fan works very well, it has calibrated itself automatically - I have programmed it so that depending on the temperature it takes from the "smoke sensor", the speed changes :D :D :D :D .
    Mr Christopher, the fan is built where you can see in the photograph ;) As I pointed out in the first post no switch/switch was to be mentioned (only Z-Wave control!) - that's why I asked for help.
    I recommend you the FIBARO forum and the friendly and helpful community <3
  • #11 16453903
    sosarek
    Help: 9321
    Rate: 15545
    LiteMan wrote:
    On the FIBARO forum, I was drawn to my schematic answer after 5 minutes
    What diagram? After all, everything is clearly shown in the drawings in the manual and the level of your "question" is below criticism.
    LiteMan wrote:
    I recommend to you the FIBARO Forum and the nice and helpful community <3
    This Forum requires at least a MINIMUM of knowledge and your own involvement, whereas you have waited for a ready-made, without contributing to the topic with your own input, even an attempt to draw connections.
    Z
    Pka, Poznań, 60-850
  • #12 16453911
    LiteMan
    "cannot be calibrated" - a minimum of knowledge I suggest in order to comment on Fibaro :D .
    If you don't want to help someone, then don't comment. You are pointlessly littering the post with your "doubts".
    Unlike you, I posted the diagram (shared the knowledge I gained).... - in order to help others - because, there is no such diagram on the web - and you only had "doubts", which resulted from lack of basic knowledge on the subject of Fibaro :D
  • Dimmer 2 is intended only for lighting loads
    #13 16453925
    sosarek
    Help: 9321
    Rate: 15545
    LiteMan wrote:
    "cannot be calibrated". - a minimum of knowledge I suggest in order to comment on Fibaro :D
    I have installed several times, the Dimmer is not intended to be used to control anything other than lighting - which is clearly stated in the instruction manual.
    What doubts? Probably only those concerning the lack of any knowledge on your part.
    What diagram? You posted a picture of the connections, the same is in the manual - which you could not read, you did not show any logical thinking by presenting the problem and having the solution given to you on a platter.
    LiteMan wrote:
    and you only had "doubts" which resulted from lack of basic knowledge on the subject of Fibaro :D
    As I wrote above - I have assembled the Fibaro several times, while you have not even attempted to draw the connections yourself.
    Z
    Pka, Poznań, 60-850
  • Correct FIBARO Dimmer 2 wiring without a switch
    #14 16453944
    LiteMan
    So I asked the community :) which helped me <3 and I instead posted a picture of the schematic, which is not on the web :) those that are, are only with switches/switches :D :D :D well, that you are so "mondry" :D a.k.a. "can't" :) :) :) .
    You have most simply spammed/dropped a post. I, unlike you, shared the correct diagram and you continue to cry and spam :) .
    You have not shown the minimum of decency :) .
    Don't spam any more, or post a diagram, without the switch - as I have below.
  • #15 16453955
    sosarek
    Help: 9321
    Rate: 15545
    LiteMan wrote:
    That's why I asked the community :) which helped me
    Sure, it will be interesting to see how they help you when the Dimmer gets damaged as a result of connecting devices it is not designed to handle.
    LiteMan wrote:
    or post the schematic, without the switch
    All diagrams are in the INSTRUCTIONS - if you can't read it with understanding - not my problem.
    Z
    Pka, Poznań, 60-850
  • #16 16453965
    LiteMan
    Apparently you must have wired something wrong ;)
  • #18 16453978
    LiteMan
    Can you point to a diagram from the manual, WITHOUT the switch? (like mine) ? ;)
  • #19 16454023
    sosarek
    Help: 9321
    Rate: 15545
    Even if you used a jumper instead of a switch it would still work - that's about it, you had enough hints that you couldn't use it is another matter.
    Z
    Pka, Poznań, 60-850
  • #20 16454043
    LiteMan
    You claimed (and still do) that there is a diagram in the manual without the switch (as I posted) - can you post so forumers can see for themselves? "Hinted at" - Is this a teleseminar or a community help forum? Do you deal similarly with your customers? hmmm...
  • #21 16454139
    Krzysztof Reszka
    Help: 609
    Rate: 1552
    This dimmer cannot be connected via the socket and this is your basic error. And the fact that the "amateur experts" from some forum advised it this way is their problem and yours as well. The topic is closed.
The discussion centers on connecting a FIBARO Dimmer 2 to a fan using a three-wire cable without an intermediary switch, aiming for Z-Wave control only. The official wiring diagram for a single switch (diagram no. 2) is referenced, with the suggestion to replace the switch with a fixed jumper cable. The neutral (N) wire should be connected to both the Dimmer 2 and the fan, while the protective earth (PE) is connected directly. Concerns were raised about calibrating the Dimmer 2 with a fan load, as it is primarily designed for lighting control; however, the user reports successful automatic calibration and functional speed control based on temperature input from a smoke sensor. Multiple users emphasize that the Dimmer 2 is not intended for fan control and caution about potential device damage. The user shared a custom wiring diagram without a switch, which is not commonly found online, and confirmed the setup works as intended. The discussion highlights the lack of official diagrams for switchless fan control with the Dimmer 2 and the risks involved in using the device outside its specified application.
