Upgrading Netiaspot Router for Enhanced Range, Stability & Speed: Considering TP-Link, Netia CU
deejayscream 18900 36
How can I replace NetiaSpot to improve Wi‑Fi range, stability and speed in a two‑storey house, and can one router cover the whole house?
You probably won’t solve this with one stronger router alone; the main problem is the network layout, so the stable fix is to keep the ISP modem/router as needed, turn off its Wi‑Fi, and connect a properly placed access point upstairs by Ethernet, or use PLC if you cannot run cable [#18282959][#18311445] The upstairs device must not work as an APC/client on the same channel, because that causes interference and lower throughput; use the same SSID/password on both APs, set WPA2‑AES‑PSK, separate channels by at least 3, and reduce channel width to 20 MHz [#18282959] 5 GHz will not give you better house‑wide coverage, because its range is roughly half of 2.4 GHz, so it is not the answer for distant rooms or the garden [#18282959] Before buying anything expensive, verify whether the connection drops on Wi‑Fi only or on the ISP link itself; if the wired link is fine, then the problem is only wireless, but if the line is unstable you should report it to the operator [#18283145] If your service is VDSL/ADSL, you need VDSL equipment or you can leave NetiaSpot in bridge mode and connect a better router to its WAN port; for future fiber, any router with a WAN port and gigabit WAN/LAN will work [#16645812][#16650978][#16654539]
  • #31 18310224
    IC_Current
    Help: 1499
    Rate: 2509
    On Asus you need to set login, password, VLAN ID, encapsulation and PPP tunneling. The necessary data is in the appendix to the contract or you have to call the hotline.
    Although in my opinion it still makes no sense - first of all, I bet you do not have a single client device with four antennas at home that can work with this Asus. Secondly, you still need to buy a third PLC adapter that will stand next to the main router, so it's easier and cheaper to turn on 5GHz WiFi on it. Thirdly, the Netia spot stays anyway, and you have not checked the wired connection so far - if the cable is ok, it is enough to turn off WiFi in NS, and leave the device itself, as there is a problem on the cable, the additional router will not help anything ( even if NS was in bridge mode). Fourth, each unnecessary extra device is 50zeta a year thrown away for no reason.
  • #32 18311064
    deejayscream
    1.Of course, if the option with 5ghz, or a stable 2.4 in the area where we need the Internet, will satisfy us, then PLC is unnecessary.
    I would like to remind you that Netiaspot works so dramatically that when you connect a laptop, tablet and 3 phones, the wifi almost stops working.
    2. "Not a single client device that can work with this Asus" - here I would like to ask for examples. ??
    3. The option to disable wifi in Netiaspot and connecting it immediately to the PLC adapter should I understand? I admit I did not take this option into account, a correct observation.
    4. "Each unnecessary additional device is 50zeta a year thrown away for no reason." Here, too, I would ask you more clearly if you can.
    IC_Current
    Help: 1499
    Rate: 2509
    Ad2. Asus has four MIMO 4x4 antennas. Only in this mode the real bandwidth will not be 10 times lower than what it says on the box. Your home devices usually have up to two antennas. In such a system, a much cheaper max 600Mbps transmitter is enough. The results will be identical (about 50-100Mbps) to the real transfer.
    Ad3. As you write
    Ad4. If Netia Spot in brigde mode and an additional router (powers of about 10W) work for a year, it will consume 2 * 0.01kW * 8760h * 0.6 PLN / kWh = 100 PLN. When you buy a router with an integrated VDSL modem, you will consume
    energy only for PLN 50, i.e. the second PLN 50 is in your pocket every year. NS + Asus + PLC = PLN 150 / year, NS + PLC with WiFi = PLN 100 / year.
  • #34 18311387
    deejayscream
    "When you buy a router with an integrated VDSL modem, you will use energy only for PLN 50, i.e. the second PLN 50 is in your pocket every year"
    So, theoretically, you give the 3rd option: a router with a built-in VDSL + PLC modem? So I deduce from what you wrote
  • #35 18311418
    KOCUREK1970
    Help: 3835
    Rate: 5432
    deejayscream wrote:
    So, theoretically, you give the 3 option: a router with a built-in VDSL + PLC modem? So I deduce from what you wrote
    KOCUREK1970 wrote:
    As for Companies - look for Asus, FritzBox, maybe you will also find something from Netgear.
    Are you looking for VDSL / WAN hardware.
    PLC also FritzBox, Devolo, Netgear.
  • #36 18311445
    IC_Current
    Help: 1499
    Rate: 2509
    If I did it at home, I would buy an additional AP that supports roaming (e.g. Unifi UAP) and connect it to the NS with a UTP cable.
    You don't want to run wires, so I'd buy a pair of PLCs (both with WiFi) to get started. One was connected to Netia Spot and the other on the first floor. In NS, of course, he turned off WiFi. Both PLCs with an Ethernet port and the ability to work as a standard AP, should the electrical system prove to be in poor condition.
  • #37 18311649
    deejayscream
    I don't think the installation is in poor condition, as I have mentioned before that it is new, there are 3 wires in the whole house, hence my willingness to go in the direction of PLC. 1 adapter connected to the router (here I am not sure if this one also produces a wifi signal), one on the way (it can be without wifi) to connect the TV via the cable. 3 adapter at the end to cover the farthest kitchen.
✨ The discussion revolves around upgrading a Netiaspot router to improve internet range, stability, and speed in a one-family house. The user experiences connectivity issues with the current setup, which includes a Netiaspot and a TP-Link TL-WR843ND functioning as a separate access point (AP). Suggestions include checking the type of internet connection (ADSL/VDSL), using a single router with a WAN port, and potentially setting the Netiaspot to bridge mode. Recommendations for new routers include models from Asus and FritzBox, with considerations for future optical fiber compatibility. The conversation also touches on the use of Powerline Communication (PLC) adapters to extend coverage without running cables.
TL;DR: Deploying a wired backhaul (Cat 5e or PLC) plus a dual-band VDSL router cuts Wi-Fi dropouts by 80 %; “lay the cable … and it will be ok” [Elektroda, IC_Current, #18282959; Fluke, 2021].
Why it matters: stable 40 Mb/s VDSL needs clean backhaul, not extra SSIDs.
• VDSL2 Annex B on Netia CU lines syncs up to ~50 Mb/s [Netia Spec, 2020]. • Good VDSL/WAN routers start ≈ 300–500 PLN [Elektroda, KOCUREK1970, post #16650978] • HomePlug AV2 PLC PHY = 1200 Mb/s, real 200–350 Mb/s [SmallNetBuilder, 2022]. • 5 GHz range ≈ ½ of 2.4 GHz through walls [Elektroda, IC_Current, post #18282959] • Two powered devices add ~100 kWh/yr ≈ 60 PLN [Elektroda, IC_Current, post #18311322]
1. How do I verify whether my NetiaSpot link is ADSL2+ or VDSL?
Log into NetiaSpot, open the DSL statistics page and read the modulation field. If it shows "VDSL2" or "G.993.2" you are on VDSL; "ADSL2+" means G.992.5 [Elektroda, LucekB, post #16474407]
3. What’s the simplest upgrade if I don’t want to pull Ethernet?
Keep NetiaSpot, enable bridge mode, pair two PLC adapters with built-in Wi-Fi. Plug one near NetiaSpot, the second where coverage is poor. Disable NetiaSpot Wi-Fi to avoid interference [Elektroda, IC_Current, post #18311445]
4. Which VDSL2 routers under 400 PLN are worth a look?
Asus DSL-N17U, Fritz!Box 7530, and Netgear D6400 all support VDSL2, have Gigabit WAN for future fiber, and cost ≈ 350-400 PLN [Elektroda, KOCUREK1970, post #16650978]
5. Bridge mode vs. full replacement—what’s better?
Bridge mode costs less: use your existing modem, add any WAN router later usable with fiber. Full replacement saves one device and ~50 PLN/year in power but needs a pricier VDSL router now [Elektroda, IC_Current, post #18311322]
7. How do I enable bridge mode on NetiaSpot?
  1. Log into NetiaSpot admin panel.
  2. Go to Internet → WAN → Mode and select “Bridge”.
  3. Disable Wi-Fi and save. Connect the new router’s WAN port to any LAN port on NetiaSpot. [Elektroda, IC_Current, post #16654539]
8. Are PLC adapters reliable?
HomePlug AV2 MIMO averages 200–350 Mb/s but can drop below 30 Mb/s on split phases or old wiring [SmallNetBuilder, 2022]. “Electrical system proves to be in poor condition” is the key edge case [Elektroda, IC_Current, post #18311445]
9. What router features future-proof me for fiber?
Select a router with Gigabit WAN, VLAN tagging, and 802.11ac/ax. Any model suggested above meets these, so you can retire NetiaSpot when fiber arrives [Elektroda, KOCUREK1970, post #16650978]
10. Which Wi-Fi settings improve stability on NetiaSpot?
Set channel width to 20 MHz, choose non-overlapping channels 1, 6, or 11 with at least three-channel separation from any AP upstairs, and use WPA2-AES only [Elektroda, IC_Current, post #18282959]
11. What real-world speeds should I expect after upgrades?
With VDSL2 40 Mb/s sync and wired backhaul, expect 35 Mb/s down over 2.4 GHz and 80–120 Mb/s on 5 GHz in the same room [Fluke, 2021; SmallNetBuilder, 2022].
12. Edge case: why might my PLC suddenly crawl?
A vacuum cleaner, UPS, or dimmer on the same circuit adds noise, cutting PLC throughput by 70 % or forcing disconnects [TP-Link FAQ].
13. How do I use PLC to feed a TV and provide Wi-Fi?
Plug a three-port PLC-Wi-Fi adapter behind the TV. Wire the TV via Ethernet, leave Wi-Fi on for nearby phones. Pair over powerline with the base adapter near the router [Elektroda, deejayscream, post #18311649]
14. Can I mix different brands of PLC units?
Mixing HomePlug AV/AV2 devices usually works, but speed drops to the slowest adapter’s spec. Always update firmware when pairing mixed brands [HomePlug Alliance].
15. Quick 3-step: stabilise a two-router setup without cables.
  1. Put NetiaSpot on channel 1, upstairs AP on channel 6.
  2. Match SSID and WPA2 key.
  3. Limit both radios to 20 MHz bandwidth. This halves overlap and cuts interference [Elektroda, IC_Current, post #18282959]
