SOMFY SGS 600 Gate Controller Overload Blink—Could Faulty Quartz Resonator Cause It?
maciek_k89 9144 3
  • Suspected faulty quartz resonator causing overload blink
    #1 16518334
    maciek_k89
    Help: 5
    Rate: 8
    Hello ! I have a problem with a SOMFY sgs 600 gate controller. When I connect it to the power supply, the relay beeps and the on/off LED blinks. According to the instructions, it is an overload of the actuator, but nothing is connected to the circuit because it is lying on my desk. I measured the voltages and noticed that when I pressed the left leg of the quartz resonator with anything, the circuit stopped blinking and operation started to stabilise. This is not the fault of cold solders because I corrected all of them. Is it possible that the quartz is damaged ? SOMFY SGS 600 Gate Controller Overload Blink—Could Faulty Quartz Resonator Cause It?
  • #2 16518530
    spinacz
    Help: 1206
    Rate: 2658
    Faulty quartz or damage to the path underneath it, also check the capacitors next to it.
  • #3 16518539
    maciek_k89
    Help: 5
    Rate: 8
    The tracks are fine. I'm going to try replacing the quartz, only the designation is S611 and I don't really know which one to buy. The catalogue note says 8MHz. Maybe someone has come across this designation?
  • #4 20562732
    liszkar
    Help: 18
    Rate: 20
    Hi.
    Have you dealt with the flashing LED?
