Does the limit switch on external roller shutters completely cut off the current?
Wfert 5868 7
  • #1 16598357
    Wfert
    Welcome,
    I'd like to know if cutting the power to the motor of an external roller shutter via a limit switch (once the roller shutter has reached the very top or the very bottom) cuts the power completely? I am referring to the power consumption of the roller shutter - if I leave the roller shutter control button pressed all the way down, the roller shutter reaches the very top, will the limit switch stop the motor, or will the roller shutter still draw any power?
    Thank you.
    Moderated By Krzysztof Reszka:
    3.1.15. Publish posts outlining a problem without providing enough information to enable other forum Users to take a substantive position. Type, model, make etc.
  • #2 16598385
    brofran
    Help: 648
    Rate: 1403
    Wfert wrote:
    will the roller shutter still draw any current?
    Yes , the roller shutter control continuously draws current . However , when the motor is not running this current is minimal ( the meter does not spin ) .
    ditomek
    Help: 24
    Rate: 230
    If the limit switch is open, how does this current flow then?
  • #4 16605540
    retrofood
    Help: 1140
    Rate: 4793
    Or it does not, depending on the type of control used.
  • #5 16605558
    brofran
    Help: 648
    Rate: 1403
    ditomek wrote:
    If the limit switch is open then how does this current flow?
    The current then does not flow through the motor , but some current is drawn by the standby system ( if there is control via remote control ).
    retrofood wrote:
    Or it doesn't, depending on the circuit.
    Well fact , direct push button control , does not download . :|
  • #6 16610895
    Wfert
    Thank you for your answers. Unfortunately I don't know the model of the roller shutter motor. The control button is the most ordinary three-position one - up + stop + down, without any automation, and without the Simon54 DZW1K.01/11 remote control. I was wondering if if I leave the button in the UP position permanently, will any current flow when disconnected by the limit switch. If there would be current flowing, it would mean that something is being loaded in the motor and it is unlikely to be good for it.
    retrofood
    Help: 1140
    Rate: 4793
    Wfert wrote:
    I was wondering if I leave the button in the UP position permanently, will any current flow when disconnected by the limit switch. If there would be current flowing, it would mean something is being loaded in the motor and it is unlikely to be good for it.
    Nothing is "in the motor being loaded", what ideas are these. Even if the control system and in fact its power supply would need to be in stand by, there is no way any voltage could be applied to the motors then. There was no need to throw stones at the school then when they talked about it. It would have stayed in the head and there would have been no silly thoughts.
  • #8 16611050
    Wfert
✨ The discussion addresses whether the limit switch on external roller shutters completely cuts off electrical current to the motor when the shutter reaches its upper or lower limit. It is confirmed that while the motor control circuit may continuously draw a minimal standby current, the motor itself does not receive power once the limit switch opens. The exact current flow depends on the control system type; direct push-button controls without remote automation typically do not draw current when the motor is stopped by the limit switch. Concerns about potential motor loading or damage due to current flow when the button is held in the "up" position are unfounded, as no voltage is applied to the motor once the limit switch interrupts the circuit.
