[ESP8266] ESP8266 ESP12 with NodeMCU does not connect to TP-LINK router - nil value error
bartosz.tarnowski 1677 2
  • #1 16629459
    bartosz.tarnowski
    Help: 26
    Rate: 30
    I am working with node MCU with ESPloter application
    STA mode is not working for me, I am not connecting to the router with the given SSID+password
    code below
    Code: Lua
    As a result, during code execution I get the answer
    Code: Lua
    more details below
    [ESP8266] ESP8266 ESP12 with NodeMCU does not connect to TP-LINK router - nil value error .
    TP-LINK router notices the ESP module and adds it to the statistics list,
    number of packets sent 8 received 4 and otherwise silence, they do not talk to each other
  • #2 16629481
    nolens_volens
    Help: 10
    I don't know or use LUA.
    But in no language I know PRINT in such a convention (two dots after a string) works.
    Try print(wifi.sta.getip())
  • #3 16632946
    bartosz.tarnowski
    Help: 26
    Rate: 30
    very strange things are used in this language, these dots are the basis.
    It moved me.
