How do I add the Philio PAN08 module to the Vera Plus control panel?
czort-kalisz 2853 2
  • #1 16669677
    czort-kalisz
    Hey,
    I have installed the Philio PAN08 roller shutter control module. Today I connect the control panel (Vera Plus) to the internet, I set the name, etc. but it does not see the modules :/ The list of equipment of the control panel does not have the modules listed, I do not know how to add them. Please give me a hint :) .
    Thanks a lot, regards, Kamil.
    Added after 11 [hours] 48 [minutes]: .
    How it works ;) .
    Log in and select the "devices" tab, then "add devices".
    If our device (driver) is not listed, we select "generic z-wave devices" and follow the instructions in the description. Each controller has a different pairing method, I read in my manual (PAN08) that I had to click the button on the controller three times within two seconds, and it worked! Vera added the blinds.
    I posted the query shortly before I left for work, so I apologise for the spam (I could have read the instructions better) and politely describe the procedure for the next - seekers....
    Greetings, Kamil.
  • Pair PAN08 as generic Z-Wave device with triple click
    #2 16682482
    czort-kalisz
    I don't know if this is possible but I will answer my own question. Solution:
    1. you go into the "devices" tab
    2. then click on "add device"
    3. select "generic z-wave device" from the list
    4. the first of the three tabs is information, click "next"
    5. the second one counts down the time of 30s, the sytem wants to pair with the roller shutter controller
    - in the case of the Philio PAN08, during this time you have to click 3 (three) times in 2 (two) seconds
    - it is better if you have already prepared the controller, connected in such a way that you have access to the "button" (the only one on the device)
    6. then you sign the roller shutter and assign a room, if you have not prepared a room division you can also add one at this point and then modify it (rename it, etc.)
    With me almost all ;) one does not speak when pairing, I think it is faulty although with the button (manual) it responds correctly to up-down commands :/.
    The controllers will add an extra function to the roller shutter buttons (keys), namely you will not have to hold the key down wanting to close the roller shutter, by pressing once it will close :P .
    My "faulty" one lowers the roller shutter automatically down with the key but doesn't report for pairing, maybe someone knows something or can let me know if this can still be fixed or already advertised. The problem is that it's the middle one and I have to yank out a large number of cables :(
    Regards, Kamil.
    PS if you have any interesting controllers, sensors and others I would be happy to learn more about them, I want to expand my system and at first I am thinking about cameras but I do not know what they will be compatible and I do not have much time for "snooping the internet" because work and finishing the house take the rest of that intended for the family....
  • #3 16806755
    kkknc
    Help: 1915
    Rate: 6709
    When it is switched on, you can add it without pressing the button. For a couple of minutes it turns on the spread.
