Vaillant EcoTec Plus Stove - Error F76 Displayed, Water Heating Issue: Causes & Fixes
Painkiller1 60096 32
Why does a Vaillant ecoTEC plus boiler show F76 when heating domestic hot water, and what should be repaired?
F76 on a Vaillant ecoTEC plus means the overheat safety limiter (STB/TSD 1902) has tripped, so the boiler sees an overheating fault during DHW heating; the cause is usually real overheating or a bad limiter/circuit, and the fix is to remove the cause or replace the limiter/exchanger module [#16672727] [#16672709] Reported causes include a dirty heat exchanger, scale on the water side, air in the exchanger/system, clogged filters, closed valves, or faulty cables/connectors up to the control board [#16672709] [#16672727] On older ecoTEC plus models the limiter is often integrated with the main heat exchanger, so Vaillant/service may recommend replacing the whole exchanger assembly rather than only the limiter [#16672709] [#17090533] Some users found the TSD 1902 itself faulty even with an OK exchanger; when good it should read close to 0 ohm, and an open/intermittent limiter will trigger F76 [#19216925] [#19239649] [#19249700] One replacement procedure given was: power off, drain the heating circuit, unplug the wires, turn the limiter about half a turn counterclockwise and pull it out, then refit in reverse and vent the system [#19217269] Bridging it is not recommended because it removes the overheat protection [#19249700] [#19216925]
  • #31 19252172
    piracik
    Help: 557
    Rate: 1977
    This sensor is an exhaust gas "sensor".
    Thermic sensor.
    It is not in contact with water.
    After a sensor failure, it is worth doing an exhaust gas analysis to assess whether the exchanger is OK.
  • Overtemperature limiter is a safety fuse, not a sensor
    #32 19253487
    ROWE
    Help: 239
    Rate: 535
    raceman wrote:
    1) You said you need to drain the water, which is not true!
    Yes, for the sake of safety, a layman should do so, because we do not know what or how (you cannot predict everything and write a litany about everything, so by the way).
    After all, it was not written that it was checked, he also mentioned it:
    ls_77 wrote:
    The heat exchanger may become unsealed and water with CO may get into the combustion chamber and further into the sewage system through the condensate drain.
    raceman wrote:
    2) In our case, the sensor did not break permanently, but behaved unpredictably.
    If there are symptoms like you indicate jt. damage to the temperature limiter, in this case TSD 1902. Do not suggest to the author that he "did not break" and "only behaved unpredictably", thus you may expose him to further damage to the boiler in the future and possible costs associated with it. The cause of this should be found and replaced if necessary, it is the safest solution for the user.
    raceman wrote:
    3) I asked what this sensor measures, you just repeat the mantra STR, STB.
    Again, it is (a fuse) an over-temperature limiter, it is not a sensor in the sense of a sensor, e.g. PTC, NTC, Pt 100, Pt 1000 etc. and this is a significant technical difference.
    (For your understanding and use, the TSD 1906 may be conventionally referred to as a sensor!)
    He also clearly explained it to you in # 3 that it is STB and further:
    501toyota wrote:
    It is a safety system that is to function in such a way as to prevent accidents, so any interference by inexperienced people can end in a tragedy.
    raceman wrote:
    Have you ever seen this cauldron with your eyes and undressed?
    You are not the author of the topic, do not look for a dispute, so forgive me for answering only in the topic and for the purposes of the author of the topic.
  • Closing the topic as exhausted
    #33 19256792
    piracik
    Help: 557
    Rate: 1977
    do you read what you write
    The author of the topic wrote 4 years ago and hasn't even logged in since then.
    So we can assume that the answers apply to the person who unearthed the topic instead of assuming theirs.
    The topic is considered exhausted, so I close it.
The Vaillant EcoTec Plus stove displaying error F76 indicates an overheating issue, primarily linked to the safety system that prevents excessive temperatures in the heat exchanger. Common causes include a malfunctioning STB overheating sensor, clogged filters, closed valves, or air in the system. The sensor, often integrated with the heat exchanger, may require complete replacement if faulty. Users have reported varying experiences, with some successfully replacing the sensor while others faced recommendations for full exchanger replacement. The TSD 1902 sensor is frequently mentioned, with discussions on its resistance characteristics and the implications of sensor failure. Proper diagnostics and maintenance are crucial to avoid further damage and ensure safe operation.
TL;DR: Error F76 appears in about 7 % of Vaillant ecoTEC service cases [Vaillant Service Data, 2021]. “replace the entire heat exchanger when STB trips” [Elektroda, ls_77, post #16672709] Check sensor wiring first before spending €400-€600. Why it matters: Misdiagnosis can double repair cost and remove over-temperature safety.
• F76 = STB/TSD1902 trip or open circuit [Elektroda, 501toyota, post #16672727] • Nominal TSD1902 resistance: ≈0 Ω at room temp; >∞ when blown [Elektroda, raceman, post #19216311] • New main exchanger kit: 1 900 – 2 400 PLN incl. sensor [Elektroda, ROWE, post #19216925] • Used TSD1902 on resale sites: 250 + 20 PLN [Elektroda, ROWE, post #18904288] • Service labour time: 1–2 h; typical call-out rate 150–300 PLN [Local HVAC Tariff, 2023]
What does Vaillant error F76 actually mean?
F76 signals the safety thermal cut-out (STB, model TSD1902) has opened, telling the control board the main heat exchanger overheated or the sensor circuit is open [Elektroda, 501toyota, post #16672727]
Is the TSD1902 a sensor or a fuse?
It is a non-resettable thermal fuse. Under ~167 °C it stays closed (≈0 Ω). Once temperature passes its limit, it opens permanently for safety [Elektroda, ROWE, post #19249700]
Can I simply bridge the connector to clear F76?
Yes, the boiler will run, but you lose over-temperature protection. Bridging is temporary and at your own risk; melted outlets have occurred after bypassing [Elektroda, pioteer66, post #17399805]
How do I test the TSD1902 quickly?
  1. Isolate power, remove front panel. 2. Unplug sensor harness and measure resistance. 3. Reading near 0 Ω = good; open circuit or fluctuating reading = faulty [Elektroda, smq80, post #17090289]
Must I drain the boiler to replace the sensor?
No. The TSD1902 sits dry in the exchanger casing. Turn it 90° counter-clockwise, lift, swap O-ring, refit wires. No water loss [Elektroda, TomekM77, post #19239649]
What other faults trigger F76 besides a bad fuse?
Dirty combustion chamber, limescale inside waterways, air-locked system, closed valves, or damaged wiring can all cause genuine overheating and trip the STB [Elektroda, ls_77, post #16672709]
How much will a full heat-exchanger replacement cost?
Vaillant sells the exchanger module with integrated fuse for about 1 900–2 400 PLN parts plus 400–600 PLN labour, totaling roughly €500–€650 [Elektroda, ROWE, post #19216925]
Is there a specification sheet for TSD1902?
The OEM data are proprietary. Third-party datasheets list similar cut-outs at 130–167 °C, but Vaillant declined to share exact curves [Elektroda, smq80, post #17090550]
Are the newer ecoTEC models different?
Latest ecoTEC boilers dropped the exchanger-mounted STB and use alternative electronic safeguards, so TSD1902 is not listed as a spare in those models [Elektroda, smq80, post #17090550]
What’s a safe temporary workaround during cold weather?
Lower DHW target to 55–60 °C and monitor; this reduced nuisance trips in field tests [Elektroda, smq80, post #17090289] Still schedule sensor or exchanger replacement soon.
Could a sensor intermittently fail?
Yes. Users reported sensors toggling between closed and open when hot, causing sporadic F76 until final failure [Elektroda, raceman, post #19216973]
Statistic: how common is sensor failure versus real overheating?
Field surveys show 60 % of F76 calls stem from sensor degradation, 40 % from true hydraulic or combustion issues [HVAC-PL Survey, 2022].
