Identifying a Non-Heating Radiator Valve Type in a Rented Apartment
stanley274 24039 31
How can I get a radiator in a rented apartment to heat again when the valve stem seems stuck and loosening the valve only lets a few drops of water out?
Remove the thermostatic head and check the pin/stem, because the valve is likely stuck closed or throttled and the lower fitting is only the return/shut-off valve [#16705911][#16706405] The pin should move in with resistance and spring back out on its own; if it does not, press it repeatedly with a coin or gently tap it, and you can try a penetrating oil like WD40 [#16706553][#16706720] A few drops of water when you loosen the packing are usually normal and suggest an old O-ring or seal [#16705910] Leave the lower return valve fully open for now; if the radiator later heats too strongly or unbalances the system, adjust that return valve by a turn or so only after the radiator is working [#16706756][#16706811] In the thread, freeing the stuck pin restored heat, so if yours behaves the same way that is the most likely fix [#16706736] If the pin is still seized or the valve leaks, the likely long-term remedy is replacing the valve/packing, which is usually a plumber job [#16706390][#16706811]
  • #31 16767247
    arelektroda
    Help: 31
    Rate: 200
    Buddy @1702 where did you see such a project
    1702 wrote:
    Normally, the number of revolutions for individual radiators is selected when designing the central heating system. Regards
    Crimping is performed in the upper valve, to which a thermostatic head is attached or not. There are numbers from 1-6 indicating orifice (flow throttling) for the maximum open valve.
    Write down how you collect points.
  • Old valves need calculated return-valve turns
    #32 16767673
    BUCKS
    Help: 536
    Rate: 1087
    @arelektroda
    In the past, mainly thermostatic valves without pre-regulation were used, as a result, orifice was performed by setting the appropriate number of turns on the screw of the return valve, as described by 1702.
    Currently, thermostatic valves with pre-regulation are standard, and valve manufacturers also provide a chart with the characteristics of such a valve, which makes appropriate setting much easier, even for a technically-savvy person.
    From what we have established, the author of this thread does not have a valve with initial adjustment, so in this particular case, the description 1702 makes sense, although it generally does not fit new installations.
    The correct selection of the number of revolutions should be calculated for a given radiator, and not accidental. Similarly to the initial setting, it should also be preceded by calculations and not random settings, but practice shows that most people do everything on the so-called cock.
    Kowalski may be guided by the principle that the smallest radiator and the one closest to the boiler may be more twisted if it has an installation based on tees. Because if it has a distributor, the flow can be limited at the distributor, so additional blocking of the flow at the radiator may be unnecessary.
The discussion revolves around troubleshooting a non-heating radiator valve in a rented apartment. The user initially reported that one radiator was cold despite the water supply pipe being warm. Various responses suggested checking the valve's position, with advice to turn it to the right to open it. It was noted that the valve might be a return valve, and if it was stuck, using penetrating oil like WD40 could help. The user successfully resolved the issue by pressing the stuck pin of the thermostatic valve, allowing the radiator to heat up. Further advice included maintaining the valve's position for optimal heating and ensuring proper flow to other radiators.
TL;DR: Roughly 80 € is the average German plumber call-out fee; "There are no miracles—water must flow" [Elektroda, BUCKS, post #16706390] A cold radiator is usually fixed by freeing a 2 mm-travel thermostatic pin [Elektroda, BUCKS, post #16706720] Inline WD-40 plus gentle tapping often restores flow.
Why it matters: A five-minute DIY check can save renters the first 80 €.
• Stuffing-box cartridge: 10–12 € online [Elektroda, willyvmm, post #16706848] • Thermostatic pin travel: approx. 2 mm over a 5 mm protrusion [Elektroda, BUCKS, post #16706720] • Common head-nut size: 30–32 mm across-flats [Elektroda, BUCKS, post #16706405] • Acceptable flow-return ΔT: 8–12 K in typical radiator circuits [VDI 6030, 2020]. • Plumber call-out in DE: ~80 € before labour [Elektroda, stanley274, post #16708449]
How do I know which valve is which on my radiator?
The upper side valve with the numbered head is the thermostatic supply valve; the lower, hex-capped fitting is the return/shut-off or orifice valve [Elektroda, BUCKS, post #16706405]
Why is only one radiator stone-cold while the pipe before the valve is hot?
A stuck thermostatic pin blocks flow even when the pipe is hot. Once freed, heat returns within minutes [Elektroda, stanley274, post #16706736]
What quick test confirms a stuck thermostatic pin?
Unscrew the thermostatic head. Press the exposed pin; it should move in about 2 mm and spring back. No movement means it’s stuck [Elektroda, BUCKS, post #16706720]
Three-step fix for a stuck pin?
  1. Spray WD-40 at the pin base.
  2. Tap the valve body lightly with a plastic tool.
  3. Press and release the pin 20–30 times using a coin until it springs back [Elektroda, E8600, post #16706553]
How many turns should the return (orifice) valve be open?
Start fully open, then close 0.5–1.5 turns to balance nearby radiators. Designers often specify 1.0–3.0 turns per unit [Elektroda, 1702, post #16766638]
Can I replace the stuffing box without draining the system?
Yes for most Danfoss-type valves. Unscrew the old cartridge and fit the new one; expect minor drips only [Elektroda, willyvmm, post #16706848]
What tools are essential for radiator valve DIY?
Adjustable pliers or a 32 mm spanner, coin or blunt punch for the pin, and penetrating oil like WD-40 [Elektroda, BUCKS, post #16706405]
Edge case: what if the pin breaks or the valve pops out?
A broken pin or ejected screw can unleash pressurised water (≈1 bar) and demand system drain and full valve replacement [Elektroda, arelektroda, post #16705902]
How warm should the return pipe feel?
Aim for a return pipe about 8–12 K cooler than the radiator surface for efficient heat transfer [VDI 6030, 2020].
When should I call a plumber?
If the valve stem leaks persistently, the pin is seized internally, or balancing fails after adjustment, professional service is needed despite the 80 € call-out [Elektroda, stanley274, post #16708449]
