Wemos D1 mini / switch on output only for a certain time millis()
dominenator 1395 4
  • Nonblocking millis timing for staged LED pulses
    #1 16854505
    dominenator
    I cannot tame the Wemos D1 mini in terms of millis(). I am trying to write a piece of code which, on receiving a command from the browser, turns on the output, in this case for testing purposes, of the "factory led" for 1 second, turns it off for 2sec and then on again for 3 seconds and then turns it off. I can't seem to get away with counting time. It is possible to take the easy way out and do a delay but at this point I will not be able to abort before the declared time has elapsed. Can I count on help with this?
    Below is what I have managed to scrape together.
    Code: C / C++
    thanks in advance for your help :)
  • #2 16855096
    krzbor
    Help: 42
    Rate: 1072
    I don't really know how this is supposed to work. When you receive a "/ON" you call led1(). However, this is the only call and always with starttime=0. It may be enough in loop() to add a call to led1(), but I don't know if this would be too frequent. Individual conditions (e.g. (millis() - starttime) >= time1) will be continuously called. It is best to add some kind of state variable that will be set after a single condition check and block the next input.
  • #3 16856052
  • #4 16857379
    dominenator
    I understand everything as much as possible. To blink a diode in a loop is no problem with a specific interval but how to trigger a series of blinks using after receiving "/ON". I am a beginner in this topic, so from your point of view trivial errors and trivial questions :) using delay the problem with millis disappears but another one appears, I can't stop the action because the program is suspended by delay ;) .
    Added after 39 [minutes]: .
    In short writing I would like to do something like this on millis.
    Code: C / C++
  • #5 16857850
    krzbor
    Help: 42
    Rate: 1072
    After all, I have written what needs to be done. Have you checked?
