Powering the Qubino Relay (Z-Wave) switch from the socket - triggers the differential
jarekkroc 1785 6
  • Socket-fed relay wiring trips differential breaker
    #1 16878424
    jarekkroc
    Hi. I need to power a qubino relay switch (z-wave) to control lighting. I have already connected many of them, but with one I have a problem.
    It is known that I need a neutral wire to power the switch - in the switch box I don't have one. I also don't have an unused yellow one. Unfortunately I also don't have a switch box up there to pull anything down.
    Practically a no-win situation, but I thought I'd power the z-wave switch with a phase and neutral wire pulled from the socket that's near the floor, in line with the switch box. Well, all's well and good, the switch is seen by the system, but when I connect I1 (the phase input to the light, like S1 in the fibaro) and the Q1 output to the lamp (like O1 in the fibaro) after a while it trips my differential.
    I don't really have an idea what the issue is.
  • RCD trips from neutral mismatch between circuits
    #2 16878525
    retrofood
    Help: 1140
    Rate: 4800
    jarekkroc wrote:
    It is known that I need a neutral wire to power the switch - I don't have one in the switch box.
    And supposedly why? Who does installation now like they did in the days of King Æneas?
    The three-wire power cable is led from the distribution board and inserted into the switch box, the same three-wire cable comes from it to power our lamp, so at the bottom of the box we connect the blue wires together and separately the yellow-green wires and we are left with two wires to use, for example black or brown, here the colour is indifferent. And these wires are connected to the terminals of the switch! Simple, right? Nothing to get wrong!
    Simple? The whole thing here Link
    jarekkroc wrote:
    I also have no unused yellow.
    Wouldn't you know that it is intended only for other purposes? Modern installations start with grandfathering?
    jarekkroc wrote:
    Unfortunately I don't have a distribution box up there to pull anything down either.
    And so it should be. Distribution boxes are an anachronism, a relic, and it's high time switch fitters learned that.
    jarekkroc wrote:
    Practically a no-win situation, but I thought I'd power the z-wave switch with a phase and neutral wire pulled from the socket that's near the floor, in line with the switch box. Well, and all is nice, the switch is seen by the system, but when I connect I1 (the phase input to the light, like S1 on the fibaro) and the Q1 output to the lamp (like O1 on the fibaro) after a while it trips my differential.
    It's the manure from the stable that gets knocked out.
    And the cause of tripping RCD can be, for example, short-circuiting of neutral N wires from different circuits, or N and PE. Without knowing the whole installation it is difficult to make a detailed analysis, but this is a common occurrence, especially during installation work, even when the circuit where some work is being carried out is de-energised.
    The solution is to bring the electrical installation up to scratch, rather than trying to douse the d.... glass.
  • #3 16878526
    djlukas
    Help: 94
    Rate: 266
    Because you most likely have different neutral wires.
  • #4 16878548
    jarekkroc
    retrofood wrote:
    And supposedly why?
    And why?
    and because it is not a new installation
    j.w.
  • #5 16878566
    retrofood
    Help: 1140
    Rate: 4800
    jarekkroc wrote:
    retrofood wrote:
    And why, apparently?
    And why?
    j.w.
    I see. In that case, since with col. @djlukas we came up with the same idea, posted at the same time, it can't be a coincidence. You are connecting N wires from different circuits somewhere, probably behind and before the RCD.
  • #6 16878584
    kokapetyl
    Help: 1787
    Rate: 2107
    djlukas wrote:
    Because you probably have different neutral wires.
    And this will probably be the N from the socket and another one is the "N" from the lamp and they don't "like" each other.:D
  • #7 16878828
    jarekkroc
    I understand, thank you for your guidance. At the same time, I would like to straighten out that I am not a professional "switch fitter" :) instead I bought a house with a "found" installation that I would like to "automate" a bit.
    thanks, regards.
The discussion addresses the issue of powering a Qubino Z-Wave relay switch in a lighting control application where no neutral wire is available in the switch box. The user attempted to power the switch by drawing phase and neutral from a nearby socket line, but this setup causes the residual current device (RCD) to trip when connecting the input (I1) and output (Q1) terminals to the lamp. Responses indicate that the problem likely arises from connecting neutral wires belonging to different circuits, which can cause neutral-to-earth faults and RCD tripping. This is common in older or non-standard electrical installations where neutrals are not properly segregated. The recommended solution is to update the electrical installation to ensure all neutrals and protective earths are correctly configured and not mixed across circuits, rather than attempting to power the switch from a separate socket circuit. The discussion highlights the importance of proper neutral wiring and the risks of mixing neutrals from different circuits in smart home automation installations.
