Eight alternatives to the Raspberry Pi
ghost666 16689 5
  • Eight Raspberry Pi alternatives span NanoPi, ODroid, CHIP, NanoPC, Tinker Board, Banana Pi, Orange Pi, and Pine A64, all aimed at sub-$100 single-board computing.
  • They differ mainly in CPU, RAM, connectivity, storage, and size, ranging from tiny integration-focused boards to Android- and desktop-oriented options.
  • Pine A64 costs $15 to $29 and comes in versions from 512 MB to 2 GB RAM with a 1.2 GHz quad-core processor.
  • Several boards trade features for form factor: NanoPi Neo Plus 2 lacks HDMI and audio, NanoPC-T3 needs 5V power, and Orange Pi Plus 2E omits dedicated power systems.
  • The Raspberry Pi single board computer is a small and inexpensive computer system based on an integrated system-on-chip that has become very famous in the circles of amateurs and hobbyists. Thanks to the tremendous success of this design, numerous companies have followed suit and created their own alternatives to the popular 'Raspberry'. All these systems have their own characteristics and everyone will be able to choose an alternative that is right for them.
    Currently, there is a lot to choose from on the market. In addition to the machines listed below, there are many more single-board mini-computers, but our focus is on the same segment as the Raspberry Pi, at least in terms of price and size - a dimension below the Mini-ITX size and a price point of less than a hundred dollars.
    NanoPi Neo Plus 2 ($ 30)
    The NanoPi Neo Plus 2 computer uses the Allwinner A53 chip. It's a quad-core ARM processor with one gigabyte of RAM. The module has a built-in network card - wireless (Wi-Fi) and wired, as well as Bluetooth. The module has integrated 8 GB of semiconductor mass memory, a slot for a microSD card and two USB 2.0 ports.
    The module is not equipped with an HDMI connector or an audio output, such as the Raspberry Pi 3, but on the other hand, the board is half the size of its competitor, which makes it an inexpensive and miniature alternative to the RPi.
    The system comes with a pre-installed operating system - UbuntuCore.
    ODroid Xu4 ($ 60)
    Xu4 is the latest version of the well-known ODroid single board computer. This system was designed and built from scratch to install Android on it. The device has an integrated Samsung octa-core processor. This chip may be twice as expensive as the new Raspberry Pi, but at the same time has twice as much RAM, as well as audio and micro-HDMI ports. You can use a microSD card to store data on this computer.
    Due to the built-in large fan and quite a large size of the computer, it is not an ideal choice for integration in tight spaces and small devices. However, when it comes to Android PCs, there's basically no better option than this platform.
    CHIP Pro Dev Kit ($ 50)
    The CHIP Pro computer is more of a competition to the Raspberry Pi Zero, mainly due to its very small size for easy integration into other systems. The computer has a single-core ARM processor clocked at 1 GHz, up to 512 MB of RAM and modules for communication via Wi-Fi and Bluetooth.
    You can buy the entire development kit for the computer. It gives access to USB or a standard headphone jack, and in the set itself we get a normal CHIP module for integration in the system, when we create our application.
    This system is ideal for applications where the compact size of the computer is important.
    NanoPC-T3 ($ 59)
    FriendlyElec's Nano series of single board computers is one of the most popular alternatives to the Raspberry Pi, mainly due to its rich feature portfolio. The NanoPC-T3 model is equipped with a Samsung octa-core processor with passive cooling and 1 GB of RAM.
    The module is equipped with an Ethernet port, a module for wireless communication (Wi-Fi and Bluetooth), an SD card slot and 8 GB of built-in memory. Audio and video signals can be found in the full size HDMI (1080p) socket. The computer is also equipped with a headphone jack, built-in microphone, four USB ports with the possibility of expansion through the connector.
    The only drawback of this computer is that it requires a power supply from 5V, but not from USB. The module is also slightly larger than the Raspberry Pi. FriendlyElec, apart from the single-board computers themselves, provides various expansion modules compatible with T3.
    ASUS Tinker Board ($ 60)
    ASUS is one of the largest computer manufacturers in the world. So it's no surprise that the company wanted to expand its influence to hobbyist computers. They were successful in getting to the market by offering the very powerful Tinker Board single board computer.
    The latest version of Tinker Board includes a quad-core processor from RockChip, clocked at 1.8 GHz. The computer has a whopping 2 GB of RAM, significantly more than most machines on this list. In the package we also get a standard Ethernet / Wi-Fi / Bluetooth kit, a microSD card connector and four USB 2.0 posts.
    The computer comes preinstalled with TinkerOS - an open platform built on top of the Debian distribution.
    B anana Pi M3 ($ 82)
    The Banana Pi series of single board computers is part of a group that is trying to directly compete with the Raspberry Pi, also by name. The M3 model is a very strong machine. The system is equipped with an octa-core processor with ARM A7 cores and 2 GB of RAM. Of course, the system includes both an Ethernet connector and a module for communication via Wi-Fi. When it comes to data storage, the Banana Pi M3 offers us the possibility of placing a microSD card in the system or connecting a hard drive with a SATA port. This port is an important distinguishing feature of Banana Pi, because it allows you to connect typical hard drives to this computer - such as to its larger counterparts. In addition, the system includes an HDMI connector, a headphone jack and, unfortunately, only two USB ports.
    Orange Pi Plus 2E ($ 50)
    Orange Pi is another single-board computer from the "fruit" group. It tries to compete with RPi, but also offers its own solutions, such as integrated 16 GB Flash memory.
    The system has as much as 2 GB of RAM and a quad-core processor clocked at 1.3 GHz. The system has two USB 2.0 ports, an infrared port and a Wi-Fi module with the possibility of connecting an external antenna. The only thing that hurts is the lack of dedicated power systems in the board at this price.
    Pine A64 ($ 15 to $ 29)
    The Pine A64 computer is dedicated to industrial applications, but that does not mean that it does not work well in hobby or amateur applications. Modules are offered in various versions of equipment, from 512 MB RAM up to 2 GB RAM. All of them feature a 1.2 GHz quad-core processor.
    Pine A64 is equipped with an Ethernet connector, microSD card slot, HDMI output. The cheapest models do not have Wi-Fi and Bluetooth, but they can still find many interesting applications in amateur projects.
    Source: https://www.howtogeek.com/330966/eight-alternatives-to-the-raspberry-pi/
    ghost666
    Translator, editor
    ghost666 wrote 11961 posts with rating 10267, helped 157 times. Live in city Warszawa. Been with us since 2003 year.
  • #2 16966441
    Stefan_2000
    Help: 36
    Rate: 39
    ODROID-XU4 is cool because:
    - has eight cores (big.LITTLE)
    - has USB 3.0
    - has gigabit ethernet
    - there is a version without a fan, with a large heat sink
    - you can bet on Android 7 - https://forum.odroid.com/viewtopic.php?t=23911
    Highly recommended, this is the cheapest invention I found that has USB 3.0 and gigabit ethernet. The only drawback that I found was, unfortunately, the odroid turned out to be non-resistant to static discharges and when I kicked it with an electric current (I saw a spark flash from a distance of a few millimeters), the HDMI died, but this is more my fault than the device's defect.
  • #3 16966540
    nici
    Help: 266
    Rate: 979
    - has USB 3.0
    Plusik buddy for help in making a decision:]
    Tell me by the way, what system are you using / used?
  • #4 16966933
    gulson
    System Administrator
    Help: 150
    Rate: 6120
    And what about stability or unusual solutions? You see, most people choose Raspberry because they want to be in peace. He wants the system to work, doesn't need much configuration, and is reasonably stable. Even if something doesn't work, there is a community that will help.
    I am absolutely for inventions, but I had a bit of fun with the Orange Pi and was not very thrilled. I don't know about Odroid?
  • #5 16967079
    bremenpl
    Rate: 15
    From myself I will add that in my opinion hardkernel makes really good hardware in terms of price-performance characteristics. I've been using odroid c2 + for a long time and it works fine with android and linux. It is emphasized that the great advantage of these sbc is that the emmc can be used instead of the sd card for the operating system, which significantly speeds up its operation.
    For low-level applications close to the periphery, in my opinion, beaglebone blaxk and derivatives are still the best.
    I agree with the foreword about X4 - I haven't seen a better sbc with linux and gigabit ethernet either. Very important properties if you want to stream video in high resolution.
  • #6 16978668
    Stefan_2000
    Help: 36
    Rate: 39
    :arrow: bremenpl
    In fact, the advantages of Odroid include eMMC card support.
    I bought Odroid at the end of 2015, connected two hard drives via USB 3.0 and the plan was that it would work as a NAS plus media player (HDMI + S / PDIF output via a budget sound card). Everything under the control of Ubuntu + Kodi. It worked pretty well for a couple of weeks until I killed HDMI. I had no problems with stability, no delays or reboots.
    I used to play OrangePi once, but there was actually no software that would work from the go. It seems to me that the XU4 is a more interesting solution due to the processor, this Samsung was also installed in some phones, so there are more chances, for example on Android.
TL;DR: Eight Pi-sized boards deliver up to 2 GB RAM and "USB 3.0 plus gigabit for under $70" [Elektroda, ghost666, #16965377; Elektroda, Stefan_2000, #16966441]. Pick NanoPi Neo Plus 2 at $30 for ultra-compact builds, or ODROID-XU4 when Android 7 and high I/O matter.
Why it matters: Choosing the right SBC avoids weeks of driver hunting and keeps prototype costs below $100.
• ODROID-XU4: 8 cores, USB 3.0, GbE, $60 ±5 [Elektroda, ghost666, post #16965377] • NanoPi Neo Plus 2: 1 GB RAM, Wi-Fi/BLE, $30 board-only [Elektroda, ghost666, post #16965377] • Pine A64: 512 MB–2 GB RAM variants, $15–29 [Elektroda, ghost666, post #16965377] • Banana Pi M3: SATA + 2 GB RAM, $82 list [Elektroda, ghost666, post #16965377] • USB 3.0 moves up to 5 Gbit/s—5× faster than USB 2.0 [USB-IF, 2023].
Which Raspberry Pi alternative is the cheapest in this list?
The Pine A64 base model sells for about $15, the lowest price among the eight boards [Elektroda, ghost666, post #16965377]
What operating system did forum users install on ODROID-XU4?
Ubuntu with Kodi media center was used successfully; Android 7 images also exist [Elektroda, Stefan_2000, #16978668; Elektroda, Stefan_2000, #16966441].
How fast is USB 3.0 compared with USB 2.0 on these SBCs?
USB 3.0 tops at 5 Gbit/s—roughly 640 MB/s, five times USB 2.0’s 480 Mbit/s limit [USB-IF, 2023].
Quick 3-step: boot Ubuntu from eMMC on XU4
  1. Flash Ubuntu image to eMMC with Etcher.
  2. Insert eMMC module, set boot-select switch to eMMC.
  3. Power board; login with default ubuntu/ubuntu credentials [Hardkernel Docs, 2023].
Edge case: will high-resolution streaming choke?
Boards with gigabit LAN plus eMMC, like XU4, stream 4 K video smoothly; 100 Mbit boards often stutter [Elektroda, bremenpl, post #16967079]
