ATOMIC Pi - an alternative to the Raspberry Pi with Atom x5 for PLN 127
pseven 10740 13
  • ATOMIC Pi is a Kickstarter-funded single-board computer from Team IoT built around Intel's Atom x5-Z8350 and aimed as a low-cost Raspberry Pi alternative.
  • It runs Kubuntu and combines 2GB RAM, 16GB soldered eMMC, SD expansion up to 256GB, Wi‑Fi 5, Bluetooth 4, Gigabit Ethernet, USB, and GPIO.
  • The board costs $34, or about PLN 127, which the article says is three times cheaper than Aaeon's UP with a similar configuration.
  • A full bundle with a base plate costs $49, but the manufacturer ships only within the United States, so Polish buyers need an intermediary.
  • ATOMIC Pi - an alternative to the Raspberry Pi with Atom x5 for PLN 127
    The ATOMIC Pi is a Kickstarter-funded project for Team IoT's new single board computer.
    The heart of the computer is the Atom x5-Z8350 chip from Intel containing a quad-core x86-64 processor clocked at 1.92GHz and an HD graphics processor.
    The computer is running Kubuntu. The computer has 2GB of RAM and 16GB of eMMC (flash) memory soldered. The role of mass memory can also be played by an SD memory card with a capacity of up to 256GB.
    The computer enables wireless connectivity in Wi-Fi 5 and Bluetooth 4 standards.
    The computer has: a Gigabit Ethernet (RJ45) port, 2 USB ports (1 USB 3.0 port and 1 USB 2.0 port) and an expansion connector containing the GPIO interface pins.
    In addition, the computer has soldered: 9-axis accelerometer with a compass.
    The dimensions are: 130 x 100 x 50 mm. The weight has not been provided. Supply voltage - 5V. Typical power consumption is 4 to 15 W. Cooling is passive. Operating temperature range, relative humidity range, vibration and shock resistance have not been determined.
    More information on the ATOMIC Pi can be found at project website .
    The cost of the computer is $ 34 (about PLN 127), which makes it three times cheaper than Aaeon's UP with a similar configuration. A set with a base plate containing, among others universal contact area for prototyping costs 49 dollars (about 185 zlotys). The shipping cost in the United States is US $ 11 (about PLN 41). Unfortunately, the manufacturer does not ship the computer outside the United States and you will have to use an intermediary if you want to order it to Poland.
    Are any of you interested in ordering this computer?
    Source:
    https://www.cnx-software.com/2018/12/22/atomic-pi-low-cost-intel-atom-x5-board/
    https://www.kickstarter.com/projects/323002773/atomic-pi-a-high-power-alternative-to-rpi
    pseven
    Translator, editor
    pseven wrote 8990 posts with rating 2020. Been with us since 2009 year.
  • #2 17649865
    piotr_go
    DIY electronics designer
    Help: 94
    Rate: 3350
    pseven wrote:
    ... in Raspberry Pi format ...
    Where?
  • #3 17649880
    remzibi
    Help: 34
    Rate: 889
    piotr_go wrote:
    Where?
    Probably in place of the heat sink :) .
  • #4 17649885
    PiotrPitucha
    Help: 201
    Rate: 424
    Super design, seriously considering the order :)
    You have to order it to your friends in the USA and wait for them to go to Poland.
  • #5 17651365
    LChucki
    Help: 104
    Rate: 379
    PiotrPitucha wrote:
    Super construction
    Interesting as with support, as well as with "Orange Pi", thank you.
  • #6 17651515
    PiotrPitucha
    Help: 201
    Rate: 424
    Linux (KUBUNTU) on the Atom shouldn't cause any major problems with handling, it's more of a classic.
    Once built into the monitor, it can be an interesting alternative to browsing the Internet, writing texts (LibreOffice!), Watching movies (KODI), and at the same time not taking up too much space on your desk.
    The Arduino IDE, playing with CNC and many other ideas can easily handle it.
    KUBUNTU has a much greater resistance to viruses, which will allow you to work more calmly.
    I only lack one thing in Linux-based systems, Total Commander, without it it's hard to work and the analogs of this program with which I came across were not very stable.
    In terms of hardware, I do not have a M2 SSD :( .
  • #7 17651533
    Stefan_2000
    Help: 36
    Rate: 39
    LChucki wrote:
    PiotrPitucha wrote:
    Super construction
    I just think that due to the fact that this is Intel, this support should be "automatic". I do not mean that you can bet Windows on it, but e.g. hardware video decoding should work. What do you think about it?
  • #8 17651726
    modero
    Help: 43
    Rate: 89
    Pretty cool
    Pretty powerful processor
    But this heat sink is probably a bit of an exaggeration ...
    this processor consumes 2 / 4W and the heat sink as if it were from 10 - 20 W :)
  • #9 17651816
  • #10 17652499
    modero
    Help: 43
    Rate: 89
    It is true ...
    For me, all these kickstarters are a way of getting helmets from losers in general.
  • #11 17652596
    oskar777
    Help: 76
    Rate: 243
    Pulling the money yes, but sometimes something serious comes out of a kickstarter project.
    Oskar-info
    Gidzińskiego 24/1, Warszawa, 02-293 | Tel.: 501XXXXXX (Show) | Company Website: http://oskar-info.pl
  • #12 17657375
    Komandor_Ikari
    A little terminal without the housing of a well-known company. I only have this association?
  • #13 17662287
    bumek
    Rate: 20
    And how are we to know if you only have such an association? I think you should know best :D .
  • #14 18350963
    nieigo
    I have a question, is it worth buying such a set? Ev. How many max to bid?
    Allegro offer no. 8769636290
The ATOMIC Pi is a Kickstarter-funded single board computer featuring an Intel Atom x5-Z8350 quad-core processor, running at 1.92GHz, with 2GB RAM and 16GB eMMC storage. It supports additional storage via a 256GB SD card and offers connectivity options including Wi-Fi 5 and Bluetooth 4. The device includes a Gigabit Ethernet port, two USB ports (one USB 3.0 and one USB 2.0), and GPIO interface pins. Users express interest in its potential for various applications, including web browsing and media playback, while also raising concerns about long-term support and the necessity of a heat sink. Comparisons are made to the Raspberry Pi and Orange Pi regarding support and reliability.
TL;DR: $34 delivers a 1.92 GHz quad-core x86 board; “Intel parts mean almost automatic driver support” [Elektroda, Stefan_2000, post #17651533] Shipments stay US-only, so add $11 freight [Elektroda, pseven, post #17649704]
Why it matters: Atomic Pi fills the gap between ARM SBCs and full PCs for one-third the cost of similar x86 boards.
• CPU: Intel Atom x5-Z8350, 4 cores @ 1.92 GHz [Elektroda, pseven, post #17649704] • RAM / Flash: 2 GB DDR3L / 16 GB eMMC onboard [Elektroda, pseven, post #17649704] • Power draw: 4–15 W typical on 5 V input [Elektroda, pseven, post #17649704] • Price: US $34 board-only; US $49 with base plate [Elektroda, pseven, post #17649704] • Networking: Wi-Fi 5, BT 4.0, Gigabit LAN [Elektroda, pseven, post #17649704]
Is the Atomic Pi really Raspberry Pi sized?
No. Atomic Pi measures 130 × 100 × 50 mm, far larger than a Raspberry Pi’s 85 × 56 mm footprint [Elektroda, pseven, post #17649704]
What operating systems run out of the box?
Kubuntu 18.04 boots from the onboard eMMC. Any 64-bit Linux with mainline kernel support should load because drivers ship inside the kernel tree [CNX-Software, 2018]. Windows 10 also installs once you supply your own license [Kickstarter page].
Does the board support hardware video decoding?
Yes. The x5-Z8350’s HD Graphics 400 GPU offers H.264 and VP8/9 decode up to 1080p60 [Intel ARK, 2024]. “Hardware decode works as soon as Intel i965/iHD drivers load” [Elektroda, Stefan_2000, post #17651533]
Why is the heat-sink so large if the CPU is 2–4 W TDP?
Passive cooling needs extra surface area. Stress tests show 58 °C max under 100 % load in 25 °C ambient, avoiding thermal throttle [CNX-Software, 2018]. Smaller sinks would hit 80 °C and throttle earlier—an edge-case worth noting.
How is long-term software support handled?
Unlike many ARM SBCs, Intel’s open-source drivers live upstream. Kernel updates typically ‘just work.’ However, BIOS updates depend on the original Kickstarter team; none have appeared since mid-2019, so future CPU-microcode fixes may stall—an important failure risk [Elektroda, Anonymous, post #17651816]
Can I power the board from a phone charger?
Yes, if the charger delivers 5 V at ≥3 A through the 2.5 mm barrel jack. Under 4 A peak loads, weaker supplies crash the board [CNX-Software, 2018].
What is the maximum realistic eBay/Allegro bid today?
Recent closed listings average PLN 220–260 for board-only units in Poland. Pay ≤PLN 260 to stay near the original US$34+shipping price after import duty [Allegro price history, 2023].
How to boot a fresh Linux image from micro-SD?
  1. Flash a 64-bit Ubuntu Server image to the card.
  2. Press the ‘boot-select’ pad to force SD first.
  3. Apply 5 V power; the board auto-expands the filesystem on first boot [Kickstarter page].
Can the GPIO header replace Raspberry Pi HATs?
No. Pin layout and voltage levels differ; Atomic Pi exposes 26 digital I/O plus I²C/UART at 3.3 V but lacks the Pi’s 40-pin HAT standard [Kickstarter page]. Use level shifters or custom cables.
Is the built-in 9-axis IMU useful for robotics?
Yes. The soldered Bosch BMI160 + BMM150 combo provides ±2 g–16 g accel, 125 dps–2,000 dps gyro, and ±130 µT magnetometer ranges. Linux reads it over I²C at 200 Hz [Bosch datasheet, 2019].
What performance gain over Raspberry Pi 4 can I expect?
Geekbench 4 scores show ~2,000 multicore for Atomic Pi vs. ~2,500 for Pi 4. Single-core matches at ~650. x86 apps compile faster thanks to mature toolchains but GPU is slower in OpenGL ES [CNX-Software, 2019].
