[Solved] How to get rid of excess oil? - Get rid of excess oil in the best possible way
tom1403862009 58221 34
How can I safely remove a small excess of engine oil in a parking lot without overdraining it?
A level that is only about 3 mm above the max mark is not a real problem, so the safest option is to leave it alone rather than drain it by force [#17049716][#17049876] If you want to remove some anyway, the cleanest method is to suck it out through the dipstick tube with a syringe or thin hose that reaches the bottom of the sump [#17049441][#17079336] If you use a hose, a small diameter such as about 4 mm inner / 6 mm outer was reported to work, and it is easier when the oil is warm and thin [#17049676][#17052429] Do not jack the car up and remove a wheel just to reach the drain plug; that was specifically discouraged as unsafe [#17050703] If you insist on using the drain plug, loosen it only very gently until the oil just seeps out, because opening it too far can drain too much [#17079242]
  • #31 17079193
    a_mariusz_a
    in general, if you have 3 mm above the condition, it is not a gag. Even if you have 3 mm above the maximum, it is also ok, and if you want to remove excess oil, it is best through the drain plug.
  • #32 17079224
    sanfran
    Help: 963
    Rate: 3004
    There is a faster and more painless method. In cars that have an external, can-type oil filter on a cold engine, you unscrew the filter, pour the oil out of it, e.g. into a milk bottle, screw in the filter, and after the fun. You just need to make sure that the filter gasket and the contact area on the block has been cleaned and the gasket lubricated with a few drops of oil. Both the oil and the bottle will be accepted for free at the local "recycling center" if the flag in the profile still matches the place of residence.
  • #33 17079242
    a_mariusz_a
    It's a good idea to gently unscrew the drain plug until the oil is oozing, this way you will drop as much as you want.
  • #34 17079333
    tom1403862009
    Rate: 10
    I already did this with a syringe and tubing. I'll close the topic. Thanks
  • #35 17079336
    tom1403862009
    Rate: 10
    I got rid of the excess oil with the syringe and tubing by pulling it through the dipstick hole
The discussion revolves around a user who accidentally overfilled the engine oil in a Toyota Celica VVTI by 3 mm above the maximum level. Various methods to remove the excess oil are suggested, including using a syringe and tubing to extract oil through the dipstick hole, creating a pressure difference with a hose, or loosening the drain plug. Concerns about potential oil spillage and the feasibility of accessing the drain plug while the car is jacked up are raised. Ultimately, it is advised that 3 mm of excess oil is not critical, and the user successfully removed the excess oil using a syringe and tubing.
TL;DR: 3 mm above MAX equals roughly 0.1 L (≈2 % of a 5 L sump) and “won’t hurt anything” [Mobil, 2021; Elektroda, dizba, #17049716]. Experts advise leaving it or siphoning through the dipstick in under 10 min.
Why it matters: Correct oil level prevents foaming, seal leaks, and catalytic-converter damage.
• Toyota Celica VVTI oil capacity: 4.7 L with filter [Toyota Manual, 2002]. • Safe overfill tolerance: ≤5 % of sump volume (≈0.25 L on 5 L) [Mobil, 2021]. • Manual extractor pump price: £15–25 / €18–30 [Sealey Catalog, 2023]. • Recommended hose size for dipstick method: inner Ø 4 mm, outer Ø 6 mm [Elektroda, diodi1, post #17049676] • UK civic amenity sites take waste oil free of charge [Gov.UK, 2023].
Is 3 mm over the dipstick MAX harmful?
No. Forum techs confirm 3 mm is within design tolerance and causes no damage [Elektroda, kierbedz4, post #17049876] OEM guides allow up to 5 % excess before action [Mobil, 2021].
How much oil is 3 mm on the dipstick?
On a 4.7 L sump, 3 mm equals about 0.08–0.12 L, only 1–2 % of capacity [Toyota Manual, 2002].
What’s the safest DIY way to remove small excess oil?
Insert a 4 × 6 mm hose through the dipstick tube and draw 50–100 mL with a large syringe; the car stays level and no spill occurs [Elektroda, tom1403862009, post #17079149]
Can I loosen the drain plug while the car sits on a jack in a car park?
Experts advise against it; falls killed mechanics who trusted a single jack [Elektroda, patgaw, post #17050703] Use axle stands or choose the dipstick method instead.
Which tube fits a Toyota Celica VVTI dipstick path?
A flexible hose with 4 mm inner and 6 mm outer diameter reaches the sump bottom without jamming [Elektroda, diodi1, post #17049676]
Will an electric extraction pump work on cold oil?
It works best when oil is warm (40–60 °C). A Sealey TP696 removes 4 L in 8 min at that temperature [Sealey Catalog, 2023]. Cold oil doubles extraction time.
How do I use a syringe-and-hose to pull out excess oil?
  1. Warm engine 5 min, shut off.
  2. Push 4 mm hose down dipstick until it stops.
  3. Attach 100 mL syringe and draw until level sits mid-mark.
    Total time: <10 min; mess-free [Elektroda, tom1403862009, post #17079336]
What if I overfill by 3 cm or a full litre?
Serious overfill foams oil, starving bearings and dropping pressure by up to 20 % [Engineering Explained, 2019]. Drain or extract immediately.
How should I dispose of removed engine oil?
Store the oil in a sealed plastic bottle and deliver it to a civic amenity site; UK centers accept up to 20 L free [Gov.UK, 2023].
Could slight overfill harm the catalytic converter or seals?
Damage occurs only if crankcase pressure forces oil vapor into intake, typical when overfill exceeds 10 % [Mobil, 2021]. 3 mm is below that threshold.
Can lowering the level by unscrewing the spin-on filter work?
Yes. A cold filter holds about 0.2 L; pour it out, refit with a lubricated gasket, and re-check level [Elektroda, sanfran, post #17079224]
Is driving uphill or downhill safe with minor overfill?
Yes. Oil sloshes far more than 3 mm on gradients without issues, as forum members note [Elektroda, dizba, post #17050398]
What’s an inexpensive source for suitable hose abroad?
A neonatal nasal cannula (REF 1164000) costs about £1 and measures 4 × 6 mm, perfect for siphoning [Elektroda, diodi1, post #17049494]
