ESP32 and Raspberry Pi Pico W: Which communication options to choose? Wi-Fi, UART, I²C, SPI?
it011 906 2
  • Clarifying the control use case for ESP32 and Pico W
    #1 21494324
    it011
    Communication options between ESP32 and Raspberry Pi Pico W: .
    1. Wi-Fi / MQTT (recommended) .
    The ESP32 and Pi Pico W support Wi-Fi, so you can use the MQTT protocol (e.g. with the Mosquitto broker).
    The Pico W sends commands (e.g. "turn sensor 1 on") to the ESP32.
    The ESP32 publishes the status of the sensors and the Pico W reads them and displays them on the screen.
    UART (serial communication) .
    You can connect the ESP32 and the Pico W via the UART (TX/RX) ports.
    The Pico W sends e.g. the command SET_SENSOR_1_ON, and ESP32 reads it and performs the corresponding action.
    I²C / SPI .
    You can use I²C, where the ESP32 is the 'master' and the Pico W is the 'slave' or vice versa.
    SPI is faster, but requires more signal lines.
    AI: What is the specific use case or application for which you want to use communication between ESP32 and Raspberry Pi Pico W? .
    Is the control of devices, LEDs
  • #2 21494378
    jarekgol
    Level 40  
    Help: 645
    Rate: 1150
    Are you asking or stating?
  • #3 21494592
