Good day, I am looking for a solution for radio control of window roller-blinds. The atypicality lies in the fact that I want to be able to programme 19 roller-blinds, some of which should close completely, i.e. to the limit, and not others only within a certain range, for instance setting the time of the motor operation at, say, 5 seconds, Another function which the controller should have is a weekly / hourly programmer with the possibility of programming each individual roller shutter whether it should close up to the limit switch or only the motor should operate for the set time; the program should have the possibility to set at least three / four times for each day of the week for each roller shutter. Has anyone of you met with such a controller? Preferably programmed via telephone, but not necessarily. Best regards
Przemekprzemek
Przemekprzemek
Rate: 28
