Wireless receiver for light switch with only two wires and no extra power supply
sauron9 3897 8
  • #1 17369801
    sauron9
    Rate: 16
    I need to move a light switch to another wall without pulling a new installation. I want to install a receiver controlled by a wireless switch in place of the current switch. The problem is that I can only find receivers that require a separate power supply, and there are only two wires in the switch box whose short circuit turns on the lamp and a separate power supply I am unable to provide.
    My question is: do such solutions exist? Where can I find such a thing?
    Thanks for your help. Regards.
  • #2 17369850
    kozi966
    Help: 599
    Rate: 1288
    sauron9 wrote:
    that I only find receivers that require a separate power supply
    Maybe instead of a receiver in the box of the old switch, one under the luminaire would be better?
  • #3 17369891
    sauron9
    Rate: 16
    Unfortunately I have an led lamp under the ceiling to which I am unable to connect such a fixture.
    lukaszd82
    Help: 143
    Rate: 491
    I have a 433MHz radio controlled switch from China. You can turn on the light from the remote, it works with LED bulbs, no extra wiring required (I only have L in the box, not even N because it's an old installation, everything has been working for 6 months now). I'll throw up what it's about :) just on ali to find the link.
    Post #650 Link .
    I have the white switch and remote control from this post.
    There is a choice of remotes to choose from. Anything on 433MHz can be programmed.
  • #5 17369907
    alster1
    CCTV and Stationary Alarms specialist
    Help: 352
    Rate: 540
    The wireless receiver won't fit under somewhere near the lamp, that's where you'd have power.
  • #6 17369936
    sauron9
    Rate: 16
    alster1 wrote:
    The wireless receiver won't fit under somewhere near the lamp, that's where you'd have the power.
    I don't have much space there, it's quite a flat lamp.
    lukaszd82 wrote:
    I have a 433mhz radio controlled switch from China. You can turn on the light from the remote, works with LED bulbs, no extra wiring required. I'll throw up what it's about soon just on ali to find the link.
    Post #650 Link
    Thanks. And how does it perform? Does it have some sort of battery power, or does it embrace power from connected wires?
  • #7 17369967
    lukaszd82
    Help: 143
    Rate: 491
    I have a switch for 2 lamps. The connection is L as input and L1, L2 as output to the lamps. A capacitor is included. On my LED bulbs it works without it. Switches illuminated on the perimeter in blue, as you turn the light on the perimeter changes to red. Remote control powered by 2032 batteries as I am not mistaken. Works ok, no problems so far. Battery in remote control still the same after 6 months.
  • #8 17370162
    w_szymek
    Chinese. I also have one of these and they work very well, plus there are remote controls in the shape of a simple switch.
  • #9 18395669
    JKM2
    Will you provide a link?
The discussion addresses the challenge of relocating a light switch without new wiring, specifically when only two wires are present in the switch box and no additional power supply is available. Conventional wireless receivers typically require a separate power source, which is not feasible in this scenario. A suggested solution involves using a 433MHz radio-controlled wireless switch and receiver system sourced from Chinese manufacturers, which operates without needing a neutral wire or extra power supply. This system can function with only the live wire present, suitable for LED bulbs, and includes a remote control powered by a CR2032 battery. The receiver integrates a capacitor to manage the load, and the switch features illuminated indicators that change color based on the light status. The wireless receiver is installed in the switch box, while the remote control mimics a traditional switch. Limitations include space constraints near the luminaire and the inability to install the receiver under certain LED fixtures. The solution has been reported to work reliably over extended periods without issues.
