If Not Fronius or SMA, Alternatives Like Volt Spirvent, Elnix Elektronixa, Zeversolar? Opinions?
Lisciasty 29172 35
What are the opinions on lesser-known, cheaper solar inverters such as Volt Spirvent, Elnix Elektronixa, and Zeversolar, and where can I find real user reviews?
There are very few solid opinions or comparative tests, so most feedback is anecdotal [#17520818] Fronius and SMA are repeatedly described as proven, reliable higher-end inverters, while cheaper units are often called “lower shelf” or said to use inferior components, though some users argue Chinese quality has improved [#17520227] [#17520718] [#17521271] [#17522640] [#17523007] Zeversolar was reported as a Chinese inverter, and one owner said a 6 kW unit with heatsink ran smoothly [#17520818] [#17520891] Elnix got the harshest criticism: one user called it a “tragedy” with disturbances and warranty repairs, while another said he would only risk it for a larger installation and noted the company is growing and has active cooling [#17544032] [#17531405] [#18182559] Spirvent drew complaints about no response to emails/contact forms and poor availability through wholesalers, with comments that its price was higher than Fronius and that buying directly from the manufacturer may be necessary [#17581066] [#17583872] [#17584042]
  • #31 18182636
    prose
    Level 36  
    Help: 173
    Rate: 850
    We do not pay tax without panels. :D
  • #32 18182641
    cuuube
    Help: 36
    Rate: 267
    Like this :cunning:
  • #34 18183101
    MichałS
    Level 36  
    Help: 259
    Rate: 689
    10kW at what price?
  • #35 18184821
    noja102
    Help: 38
    Rate: 245
    Ask the manufacturer about the offer, and 20kW with 2 MPPT I have an offer for 6800 and 3 MPPT for 7000 plus a nice option for network monitoring and management
  • #36 18188516
    Lisciasty
    Help: 19
    Rate: 123
    I lived in Wrock a few years ago. But this topic about tax exemption is interesting. Only this is rather for homeowners,
    because how much of this tax is paid by someone who lives in a block of flats ...
The discussion revolves around opinions on lesser-known and cheaper inverter brands such as Volt Spirvent, Elnix Elektronixa, and Zeversolar, as alternatives to established brands like Fronius and SMA. Participants express mixed experiences with these alternatives, highlighting concerns about build quality, reliability, and customer service. Zeversolar is noted as a subsidiary of SMA, with some users reporting satisfactory performance. However, Elnix receives significant criticism for reliability issues, with one user describing it as a "tragedy" due to frequent failures. The conversation also touches on the quality of Chinese inverters, with some users advocating for Polish brands and expressing a desire to support local manufacturers. Active cooling technology in inverters is debated, with some users favoring traditional passive cooling for its reliability. Overall, the discussion emphasizes the importance of quality and service in inverter selection.
TL;DR: One user pushed a 3 kW hybrid inverter to 8 kW peak (267 %) [Elektroda, Slak68, post #17521523], yet “China has gone up with quality” [Elektroda, prose, post #17521271]; cheaper units work but component quality, cooling method, and service access vary widely.
Why it matters: The right inverter safeguards long-term yield and warranty claims.
• Used Fronius IG20 sells for < PLN 1 000 [Elektroda, PV_Albert, post #17531405] • Polish Lumel 20 kW inverter quoted at PLN 6 800–7 000 [Elektroda, noja102, post #18184821] • Elnix suffered two warranty failures within hours [Elektroda, chrobry25, post #17544032] • Active cooling draws ≈1 W and lowers internal temperature [Elektroda, witekem, post #17586591] • Zeversolar = SMA subsidiary, built in China [Elektroda, cuuube, #17520818; prose, #17520891]
Who actually owns Zeversolar?
Zeversolar is a Chinese company acquired by Germany’s SMA; designs originate from the older Ever Solar line, now assembled in China [Elektroda, cuuube, #17520818; prose, #17520891].
Which Polish-made inverter brands are discussed?
Forum users mention Elnix (Elektronix), Spirvent, Twerd and Lumel PVSA [Elektroda, multiple posts]. Availability is limited; wholesalers rarely stock them, forcing direct orders [Elektroda, witekem, post #17584042]
What real-world failures were reported for Elnix?
One unit stopped after only 3 hours; its replacement produced heavy grid disturbances; the installer switched to Fronius and ended the issues [Elektroda, chrobry25, post #17544032]
Can an inverter be overloaded safely?
A 3 kW hybrid unit handled 4 kW continuous and 8 kW peak without immediate failure [Elektroda, Slak68, post #17521523] Overloading shortens life and voids warranties; follow datasheet limits.
Are 30-year lifespans realistic?
Users still operate 30-year-old Fronius and SMA devices [Elektroda, Leon444, post #17522640] Budget inverters lack comparable long-term data, so expect shorter service intervals.
What should I inspect before buying a low-cost inverter?
  1. Warranty length and on-site service terms. 2. Internal build: PCB quality, cable gauge, heat-sink mass. 3. Vendor responsiveness—test email and phone support first. One user never got a reply from Spirvent [Elektroda, Lisciasty, post #17581066]
Where can I read independent tests?
Polish pvforum.pl hosts scattered user logs, but comparative lab tests remain scarce [Elektroda, cuuube, post #17520818] Check TÜV Rheinland or Photon lab certificates when available.
How do I verify a manufacturer supports my purchase?
Use this quick check:
  1. Email tech support; expect a reply within 48 h.
  2. Call the hotline; confirm spare-part stock.
  3. Ask for local service partner list. Lack of response at step 1 signals risk [Elektroda, Lisciasty, post #17581066]
