If Not Fronius or SMA, Alternatives Like Volt Spirvent, Elnix Elektronixa, Zeversolar? Opinions?
Lisciasty 29172 35
What are the opinions on lesser-known, cheaper solar inverters such as Volt Spirvent, Elnix Elektronixa, and Zeversolar, and where can I find real user reviews?
There are very few solid opinions or comparative tests, so most feedback is anecdotal [#17520818] Fronius and SMA are repeatedly described as proven, reliable higher-end inverters, while cheaper units are often called “lower shelf” or said to use inferior components, though some users argue Chinese quality has improved [#17520227] [#17520718] [#17521271] [#17522640] [#17523007] Zeversolar was reported as a Chinese inverter, and one owner said a 6 kW unit with heatsink ran smoothly [#17520818] [#17520891] Elnix got the harshest criticism: one user called it a “tragedy” with disturbances and warranty repairs, while another said he would only risk it for a larger installation and noted the company is growing and has active cooling [#17544032] [#17531405] [#18182559] Spirvent drew complaints about no response to emails/contact forms and poor availability through wholesalers, with comments that its price was higher than Fronius and that buying directly from the manufacturer may be necessary [#17581066] [#17583872] [#17584042]
  • #1 17520050
    Lisciasty
    Help: 19
    Rate: 123
    I am interested in the opinion about less known / cheaper inverters on the market,
    for example "Volt" Spirvent, "Elnix" Elektronixa, Zeversolar etc.
    Someone may use something similar? Possibly knows where you can find some opinions?
  • #2 17520227
    prose
    Level 36  
    Help: 173
    Rate: 850
    I have a Fronius and it is reliable.
    Lisciasty wrote:
    "Volt" Spirvent, "Elnix" Elektronix, Zeversolar etc.
    It's a lower shelf.
  • #3 17520272
    Lisciasty
    Help: 19
    Rate: 123
    And some development of the phrase "lower shelf"? :P
    I am asking for real.
  • #4 17520718
    Leon444
    Help: 48
    Rate: 355
    You just have inferior components inside these inverters, the production cycle is different, the control cycle after production, etc ...
    This applies to all electronics, not only inverters ...
    For example, SMA produces the latest inverters in China, when you search the net, enthusiasts from Germany compared the older model with the newest one, they compared what they are made of, the conclusions are that it is not what was produced in Germany anymore ...
  • #5 17520818
    cuuube
    Help: 36
    Rate: 267
    Zeversolar is a subsidiary of SMA.
    I have 6 kW with a heat sink from May, it runs smoothly.
    Generally, it's hard with opinions.
    You can find some single ones after reading http://www.pvforum.pl/inwertery-f10.html, there is not much of it.
    I have not heard or read about any of them breaking down remarkably, because there is generally nothing to break down there, well somewhere I have heard that those with fans can be heard and the windmill itself can fall.
    There are also no comparative tests.
  • #6 17520891
    prose
    Level 36  
    Help: 173
    Rate: 850
    This is a Chinese inverter converted from Ever Solar.
  • #7 17521162
    Lisciasty
    Help: 19
    Rate: 123
    Today I installed Fronius for my mother-in-law, it actually looks nice and everything is well thought out, much more pampered than my Growatt.
    I am trying to find an answer to the question of whether it makes sense to install our native inverters. They are so a bit in between with prices in between
    higher shelf and cheap Chinese food. And theoretically, it is easier to contact us in the event of a service or problems.
    But it will probably be difficult to find opinions on this topic ...
    prose
    Level 36  
    Help: 173
    Rate: 850
    China has gone up with quality, I prefer to buy Chinese because it is better quality than ours.
    Slak68
    Help: 8
    Rate: 111
    I confirm, I have a 3 kW hybrid - you can easily load 4 kW, and the maximum load I saw is over 8 kW, but only in peak.
    Below is an example chart from one day ...
  • #10 17522640
    Leon444
    Help: 48
    Rate: 355
    I think I was unlucky and all the Chinese inverters I had in my hands looked nice from the outside and inside, very poor quality of assembly and poor quality components ...
    It is true that I only had about 10-15 pieces of various Chinese inverters, so that is not the whole picture of the market, but ...
    You can find Fronius or SMA models at auctions and they are 30-year-old fully functional, I wonder if the Chinese will reach halfway through this time ...
    The quality can be assessed by dismantling the inverter and assessing what it is made of, or let's say after 10 years of continuous trouble-free operation ...
  • #11 17523007
    prose
    Level 36  
    Help: 173
    Rate: 850
    I am just undressing and I saw what Chinese and Polish look like. Fronius or SMA are incomparably, I have 2 Fronius and 1 Chinese.
  • #12 17523268
    Leon444
    Help: 48
    Rate: 355
    I had just started from Italian inverters through Chinese to Fronius and SMA, now I have three SMA and I will not exchange it for anything else ...
    I have never had a Polish inverter, so I cannot comment on this issue ... :)
    Michal_WWL
    Help: 76
    Rate: 284
    I used to dismantle a few inverters and repaired a few. These were the old Deltas and Danfos. I can confirm the excellent quality of the items.
    For example, the thickness of the cables inside, capacitors for voltage much higher than on the plate, for high temperature operation.
    PV_Albert
    Help: 11
    Rate: 117
    Personally, I use an older type Fronius IG40 and it works beautifully. I have seen the use of IG20 for less than PLN 1000, so for a small installation it is a good solution.
    For a slightly larger set, I would risk this Elnix. There is a separate topic for this inverter, where my colleagues did not leave a dry thread on it, so I would not like to develop the discussion here. I just see the producer growing. After all, you can see the device on their website, nice diagrams and explanations, and the last slanderous videos on yt are from two years ago. Of course, it has a lot of disadvantages, but there are also advantages. The worst (maybe best) is that I visually like this horrible box.
  • #15 17531446
    Lisciasty
    Help: 19
    Rate: 123
    Yes, I know this Elnix topic, generally not very substantive, so I started a new thread:>
    Anyway, I'm going to try different equipment, but when I take it for myself or my friends, I can always
    it is to embrace when something happens. If something starts to happen to someone else or who is still living in, this is already a problem
    logistics and cost ...
  • #16 17544032
    chrobry25
    Rate: 76
    As for the elnix, it's a TRAGEDY. A colleague was assembling at home, the first one walked for 3 hours and got out, the next one had such disturbances that it is a pity to tell and the third one was already fronius (at my insistence) and the problem is over! This is equipment that is to work for many years, according to there is no unnecessary risk for me here.
  • #17 17581066
    Lisciasty
    Help: 19
    Rate: 123
    Spirvent blew me away. I wrote via the contact form on the website, I also sent an e-mail to the merchant's mailbox. No response.
    There are also no such inverters in solar wholesalers. Maybe it is some money laundering or an empty shell for EU subsidies? :>
  • #18 17583045
    pppooo
    Help: 21
    Rate: 156
    And what about the twerd company from Toruń, apparently very good.
  • #19 17583070
    anet870
    Help: 67
    Rate: 248
    When it comes to Chinese inverters, Growatt is a good choice.
  • #20 17583872
    witekem
    Help: 30
    Rate: 176
    I only recommend Polish ale. It's a pity, because Spirvent also ignored me, he wanted exclusivity, and when he sent the prices, it was much higher than Fronius, but I am pressing to lower the prices. Twerd also has a very high price, but it is focused on specific customers and now Elnix competes with it strongly in inverters for wind or stream turbines. Elnix followed the path of ABB and Twerd some strange in the current control of windmills and not with every turbine. It is interesting to do on the turbine market because Elnix already has inverters up to 40KW, including cascades 15 / 25kW, and now I am preparing for PV. I wonder what Twerda's answer will be. Spirvent is also already preparing higher power of inverters, but only for PV, and they are much better than the Chinese ones.
    It is getting interesting among Polish producers.
    No Growatt or any other Chinese. Only Polish and give the boys a chance to develop so that people in Poland have jobs, not only in China.
    • Inwerter Elnix Kaskada 15-25 kW.pdf (1.08 MB) You must be logged in to download this attachment.
    • INWERTER Wind ELNIX.pdf (1.1 MB) You must be logged in to download this attachment.
    • INWERTER Wind ELNIX 30-40.pdf (1.05 MB) You must be logged in to download this attachment.
  • #21 17583979
    anet870
    Help: 67
    Rate: 248
    That's right, only Poles have to try harder, even when it comes to accessibility.
    Note that there are not many opinions about domestic inverters and the auction portals bring in stimulants from the west, Kostale or Chinese, etc. What do you think the interested party will buy if Polish inverters cannot be sold for even one unit?
  • #22 17584042
    witekem
    Help: 30
    Rate: 176
    You are right, but how can they try to boycott Polish products when companies importing Chinese equipment? I talked to traders from Spirvent or Elektronix, companies importing Chinese equipment do not even want to know what they produce and do not know this equipment. Tverd had a large network of sellers. When the Chinese market entered, they left it and many I knew from its distribution now say, we already have Chinese and now Twerd sells its products itself. See what large wholesalers sell - no Polish equipment and they do not want to know it. This is the promotion of the Polish industry. That is why it is worth calling and writing directly to manufacturers and buying from them directly.
    At least it will be cheaper, faster and more reliable!
  • #23 17586286
    Lisciasty
    Help: 19
    Rate: 123
    If Elnix had passive cooling like a normal civilized inverter, I would gladly take it. But the windmills? Err ....
  • #24 17586554
    witekem
    Help: 30
    Rate: 176
    Again buddy Leafy, stereotypes and lack of knowledge.
    Now, inverters with active walking are new on the market.
    Some knowledge: I recommend Article:
    https://magazynfotowoltaika.pl/spis_tresci_3_2017/
    Why active cooling is better for PV inverters.
    As in the case of chemicals or even chocolate, the West sells us antiques and they use other inverters with active cooling.
    For example, Fronius.
    http://www.fachowyelektryk.pl/technologie/odnawialny-zrodla-energii/2109-d Why-chlodz-aktywne-jest-lepsze-w-falownikach-pv.html
    So Fronius introduces active cooling to its market because it has many advantages.
    Like for example.
    -Lower maintenance cost over many years - virtually no need to perform service activities,
    - Easy to install - the inverter is smaller and lighter.
    -Increased safety of operation
    - Greater energy yields.
    And the most important
    - Longer service life of electronics due to lower temperature of inverter components.
    Elektronix already has active (intelligent) cooling and only now is Fronius introducing it. Another point in favor of Polish equipment.
  • #25 17586576
    Michal_WWL
    Help: 76
    Rate: 284
    Witek, what you cited are sponsored articles, in such you can prove everything.
    Too high temperature for passive cooling or the need for cleaning every 6 months, I do not agree with that. There is nothing about the working conditions (building or outdoor).
    For so many years the inverters have operated at maximum efficiency with passive cooling, and it worked. Producers wanting to lower the price add to it an ideology of efficiency and reliability.
  • #26 17586591
    witekem
    Help: 30
    Rate: 176
    In that case, ask Fronius why he sells new products with active cooling and tells us that passive is for us on our market.
    This is Fronius' opinion about the advantages of active cooling, not of Elektronix. Elektronix has long introduced active cooling. And please, they 'got' again.
    Intelligent active cooling temporarily consumes about 1W of power for a short time, and how many benefits.
  • #27 17586631
    Michal_WWL
    Help: 76
    Rate: 284
    Active cooling is an ever-present trend of material savings. Instead of a heavy aluminum heat sink, we have a few pieces of bent steel sheet or a small piece of alu.
    In return, we get moving parts, prone to failure, and probably filters to be replaced from time to time (how can an active heat sink break down?).
    What IP does this actively cooled Fronius have? Will IP 65 cope with passive cooling?
  • #28 17587647
    Lisciasty
    Help: 19
    Rate: 123
    The heat sink can break down by being killed with dirt, but why the manufacturers themselves prohibit the installation of their buckles in a dirty environment?
    Since it is impossible to install in a dirty one in a clean one, the problem of a dirty radiator does not exist.
    My clasp has been hanging in the boiler room for over 1.5 years and, apart from a few spiders, nothing is wrong with it. The fact that it was heavy, but still on its own without help
    I hung it on the wall so the argument that the heavy inverter is also weak. Nobody wears it, only hangs it once and forgets about the matter until the end of the world; P.
    After all, I am tempted to give Elnix a chance, if I find an installation in the vicinity to keep an eye on it, why not.
    Thank you to Spirvent for ignoring the customer.
    Anything else there is noteworthy, domestic production?
  • Elnix inverter reliability compared with SMA and Fronius
    #29 18182559
    TomaszFotowoltaika
    I installed the first old passive cooled inverter connected to cheap oelmaier amorphous panels, I also bought a new Elnix with a mains heater, I still have some old Sma - one three-phase inverter does not ensure the reliability of the system. I have a comparison -Elnix- tragedy of disruption two warranty repairs loud-active cooling = cost cutting- ended as an inverter for a heater in a boiler German old inverter are like old Mercedes with Polish Polonaise you can drive it, but how ........
The discussion revolves around opinions on lesser-known and cheaper inverter brands such as Volt Spirvent, Elnix Elektronixa, and Zeversolar, as alternatives to established brands like Fronius and SMA. Participants express mixed experiences with these alternatives, highlighting concerns about build quality, reliability, and customer service. Zeversolar is noted as a subsidiary of SMA, with some users reporting satisfactory performance. However, Elnix receives significant criticism for reliability issues, with one user describing it as a "tragedy" due to frequent failures. The conversation also touches on the quality of Chinese inverters, with some users advocating for Polish brands and expressing a desire to support local manufacturers. Active cooling technology in inverters is debated, with some users favoring traditional passive cooling for its reliability. Overall, the discussion emphasizes the importance of quality and service in inverter selection.
TL;DR: One user pushed a 3 kW hybrid inverter to 8 kW peak (267 %) [Elektroda, Slak68, post #17521523], yet “China has gone up with quality” [Elektroda, prose, post #17521271]; cheaper units work but component quality, cooling method, and service access vary widely.
Why it matters: The right inverter safeguards long-term yield and warranty claims.
• Used Fronius IG20 sells for < PLN 1 000 [Elektroda, PV_Albert, post #17531405] • Polish Lumel 20 kW inverter quoted at PLN 6 800–7 000 [Elektroda, noja102, post #18184821] • Elnix suffered two warranty failures within hours [Elektroda, chrobry25, post #17544032] • Active cooling draws ≈1 W and lowers internal temperature [Elektroda, witekem, post #17586591] • Zeversolar = SMA subsidiary, built in China [Elektroda, cuuube, #17520818; prose, #17520891]
Who actually owns Zeversolar?
Zeversolar is a Chinese company acquired by Germany’s SMA; designs originate from the older Ever Solar line, now assembled in China [Elektroda, cuuube, #17520818; prose, #17520891].
Which Polish-made inverter brands are discussed?
Forum users mention Elnix (Elektronix), Spirvent, Twerd and Lumel PVSA [Elektroda, multiple posts]. Availability is limited; wholesalers rarely stock them, forcing direct orders [Elektroda, witekem, post #17584042]
What real-world failures were reported for Elnix?
One unit stopped after only 3 hours; its replacement produced heavy grid disturbances; the installer switched to Fronius and ended the issues [Elektroda, chrobry25, post #17544032]
Can an inverter be overloaded safely?
A 3 kW hybrid unit handled 4 kW continuous and 8 kW peak without immediate failure [Elektroda, Slak68, post #17521523] Overloading shortens life and voids warranties; follow datasheet limits.
Are 30-year lifespans realistic?
Users still operate 30-year-old Fronius and SMA devices [Elektroda, Leon444, post #17522640] Budget inverters lack comparable long-term data, so expect shorter service intervals.
What should I inspect before buying a low-cost inverter?
  1. Warranty length and on-site service terms. 2. Internal build: PCB quality, cable gauge, heat-sink mass. 3. Vendor responsiveness—test email and phone support first. One user never got a reply from Spirvent [Elektroda, Lisciasty, post #17581066]
Where can I read independent tests?
Polish pvforum.pl hosts scattered user logs, but comparative lab tests remain scarce [Elektroda, cuuube, post #17520818] Check TÜV Rheinland or Photon lab certificates when available.
How do I verify a manufacturer supports my purchase?
Use this quick check:
  1. Email tech support; expect a reply within 48 h.
  2. Call the hotline; confirm spare-part stock.
  3. Ask for local service partner list. Lack of response at step 1 signals risk [Elektroda, Lisciasty, post #17581066]
