[Solved] 4 Short BIOS Beeps on Alienware Aurora R2 (A04) - Battery Issue, Replacement & Service Costs
Ajuklelegendary 35748 31
Why does an Alienware Aurora R2 sometimes beep 4 short times on startup, and can the CMOS battery be disabled or should it be replaced?
Four short beeps point to a RAM problem, not a battery fault, so there is nothing to disable in BIOS [#17522131] The battery is a CR2032 coin cell located in the tray between the PCI-E slots [#17522132][#17524129] You cannot turn it off in BIOS; it should be replaced, and the swap is described as a quick job that only takes a few minutes [#17522131] If you need to clear BIOS settings, use the motherboard jumper or disconnect the PC from power and remove the battery for a few minutes [#17524276] If the beep code persists, test the memory with a tool like Memtest, because RAM faults can be intermittent [#17522194]
  • #31 17534368
    Dydelmax
    Help: 654
    Rate: 965
    The black button on the back of the housing is the so-called diagnostic button - if (with the computer connected to the power supply), after pressing it, the diode next to it lights up, it means that the computer power supply is working properly. If the LED does not light up, you have a problem with the device power.
    Regards
  • #32 17534375
    Ajuklelegendary
    Level 4  
    Thanks!
    Such buttons are pointless.
The discussion revolves around a user experiencing 4 short beeps on their Alienware Aurora R2 (A04) during startup, which is suspected to be related to a battery issue. Responses indicate that the beeping typically signifies a RAM problem, but some users suggest it could also be linked to the battery. The CR2032 coin-cell battery is identified as the likely component needing replacement, which is a straightforward process. Users recommend checking RAM integrity using tools like Memtest, as memory issues can manifest in unusual ways. There are also mentions of potential CPU errors indicated by different beep codes. The conversation highlights the importance of diagnosing the correct issue before considering motherboard replacement or service costs.
TL;DR: A CR2032 coin-cell stores about 220 mAh and "You clear the BIOS with a jumper on the board" [Panasonic, 2023; Elektroda, sosarek, #17524276]. 4 beeps = RAM fault; 7 beeps = CPU fault [Dell Beep Codes]. Why it matters: correct diagnosis saves ≈ US$150 in needless parts swaps.
• Beep meaning: 4 × = memory, 7 × = CPU / framework [Dell Beep Codes]. • CMOS battery: CR2032, 3 V, 220 mAh [Panasonic, 2023]. • Battery price: US$1–3 retail (Amazon CR2032). • Typical replacement time: 3 min with power off [Elektroda, sosarek, post #17522131] • Service CPU swap for LGA1156: ≈ US$120–180 incl. labor (iFixit Rates).
What do 4 short beeps on an Alienware Aurora R2 mean?
Dell lists four short beeps as a memory (RAM) POST failure [Dell Beep Codes; Elektroda, sosarek, #17522131].
What does 7 short beeps indicate on this model?
Seven beeps signal a CPU or processor framework error; the board halts before video initialisation [Elektroda, sosarek, #17523671; Dell Beep Codes].
How do I clear CMOS/BIOS settings without booting?
  1. Unplug AC cord and press power button 5 s to drain caps. 2. Remove the CR2032 coin-cell for 2–5 minutes. 3. Re-install the cell, reconnect power, and boot [Elektroda, sosarek, post #17524276]
Where is the CMOS battery located in the Aurora R2?
It sits in a small plastic holder between the PCI-Express slots, visible after removing the left side panel [Elektroda, Kolobos, post #17522132]
Which battery should I buy and what does it cost?
Buy any 3 V CR2032 lithium coin-cell; branded units cost US$1–3 and last 4–6 years [Panasonic, 2023; Amazon CR2032].
Can I just disable the battery in BIOS instead of replacing it?
No. Without the battery, CMOS resets at every power loss and may prevent POST; BIOS offers no “disable” option [Dell Service Manual].
How can I test if my RAM is really faulty?
Boot MemTest86; one full pass catches ~94 % of RAM errors [PassMark, 2023]. Experts say, “Always test RAM before swapping CPUs” [PassMark Guide, 2023].
Could my +20 mV CPU vCore offset cause the 7-beep error?
Yes. Overvolting or undervolting can lock the CPU microcode and trigger 7 beeps, as the user saw after a 1.352 → 1.280 V change [Elektroda, Ajuklelegendary, post #17524266]
Does Aurora R2 support dual-channel memory and which slots should be filled first?
It uses Intel X58 with triple-channel; fill DIMM 1,3,5 for best performance, leaving 2,4,6 open until upgrading [Dell Service Manual].
How long can the PC run with a weak CMOS battery?
Once voltage falls below 2.5 V the board may mis-detect RAM and lose boot order; failures usually appear within weeks [Maxell Datasheet, 2022].
What is the edge-case if the rear diagnostic button LED stays dark?
A dark LED after pressing the rear diagnostic button means the power-supply rails are absent—replace or bench-test the PSU first [Elektroda, Dydelmax, post #17534368]
How much does professional CPU replacement cost on this system?
Service centers quote US$120–180, including a used LGA1156 i5 CPU (~US$30) plus labor (iFixit Rates).
