Why connect DHT22 directly to ESP8266 NodeMCU V3 3.3V pins without level shifter?
labo 5811 18
Why do DHT22 modules and similar sensors often connect directly to an ESP8266 NodeMCU V3 without a level shifter?
Because the DHT22 can be powered from 3.3 V, so its data line then stays at a 3.3 V level that the ESP8266 can read directly [#17567319] [#17567337] For open-drain buses like I2C or 1-Wire, the pull-up can also be tied to 3.3 V, which avoids a level shifter as long as the module does not already pull up to 5 V [#17567756] [#17567899] If the peripheral is actually running at 5 V and drives its output high to 5 V, that is outside the ESP8266’s official pin rating, which is 3.3 V on the documentation; some users report 5 V tolerance, but that is not guaranteed [#17568259] [#17568333] In that case a level converter is the proper solution, or at least current limiting with a series resistor for slower interfaces [#17567756] [#17567919]
  • #1 17567301
    labo
    Rate: 16
    I found that the ESP8266 nodemcu v3 has a voltage on the data pins of 3.3V. In various places you can find info that the pins tolerate 5.8V, although I don't see this in the official materials.
    Now the question is, why are virtually all devices even the DHT22 connected without a level converter when the ESP8266 has 3.3V pins?
  • #2 17567319
    piterek-23
    Help: 162
    Rate: 427
    And doesn't the DHT sometimes run on a 3V3 supply?
  • #3 17567337
  • #4 17567389
    labo
    Rate: 16
    Depending on the specification it has a 3.3-5V, 3.3-6V supply.
    However, with a 5V supply people feed the output directly to the ESP8266 nodemcu pins. This doesn't just apply to the DHT22 but to other circuits with 5V output, hence my question about the tolerance of the ESP8266 nodemcu inputs and the possible need for a level converter.
  • #5 17567432
  • #6 17567496
    labo
    Rate: 16
    Maybe lame, but what's the difference? An acceptable pin voltage is an acceptable pin voltage. It doesn't matter which one, or what signal is flying with it.
  • #7 17567527
  • #8 17567687
    labo
    Rate: 16
    Er2lub wrote:
    So write what buses you are talking about.
    I have a device giving TX, RX 3.3V so no such problem here.
    The thing is, I was looking through various examples on the net looking for an answer to my question about pin voltages.
  • #9 17567756
  • #10 17567899
    labo
    Rate: 16
    Er2lub wrote:
    * 3.3V input 5V output.
    Here it can vary.
    This was the essence of my question.
    [/quote]* I2C, 1-Wire and others with OC(OD) you pull up to +3.3V and there is no problem. [/quote]
    Unless you have a module on 5V and there is already a pull-up resistor there, which brings it to a higher point.
    Er2lub wrote:
    I guess you can count what and what will be the max allowable rate of voltage change?
    No. You know, when you're retired, you don't always want to know everything or investigate everything anymore. Well, unless it turns out to be needed. ;)
    Which isn't to say you can't explain, this is an open forum after all, and it can be read by people who could use the knowledge as much as possible.
    Greetings
  • #11 17567919
  • #12 17568259
  • #13 17568280
  • #14 17568304
  • #15 17568333
    kaczakat
    Help: 317
    Rate: 231
    Officially, the ESP8266 is allowed 3.3V+10% on the pins. The CEO of Expressive has admitted that it tolerates 5V, which is in line with user observations. Does this affect the circuit well? Probably not, which is why it is better to use logic level converters. However, in most cases nothing will happen if you make a mistake and apply 5V to the pins (even if you supply the ESP with 5V). I wired it that way myself once by accident. But you can damage the processor by supplying even 3.3V, so it is better to use a converter. I have provided links to CEO statements here: https://www.elektroda.pl/rtvforum/topic3509270.html ( and this is the manufacturer, contrary to the answer in the comment). The converter not only lowers the voltage for the ESP, but will also raise the voltage for the 5V device, so it's harder to have a communication error - something that is a 1 can be considered a 0 and vice versa.
  • #16 17568339
  • #17 17568347
  • #18 17568351
  • #19 17568466
The discussion addresses why the DHT22 sensor is commonly connected directly to the ESP8266 NodeMCU V3 3.3V pins without a level shifter, despite the sensor often being powered at 5V. The ESP8266 pins officially tolerate a maximum of about 3.6V (3.3V + 10%), but many users report that the inputs can withstand 5V signals without immediate damage. The key technical point is that communication protocols like 1-Wire, I2C, and similar use open-drain/open-collector outputs with pull-up resistors, typically to 3.3V, which prevents the input voltage from exceeding safe levels. When a 5V device has its own pull-up resistor, it can raise the line voltage above 3.3V, potentially risking damage. The current flowing through the input protection diodes limits the risk, and if the series resistor is chosen correctly (e.g., 4.7kΩ), the current remains within safe bounds. However, this is not guaranteed for all ESP8266 chips or setups, and using a logic level converter is the safest approach to prevent damage and ensure signal integrity. The ESP8266 datasheet specifies 3.3V tolerance, and while some users and even the ESP manufacturer acknowledge that 5V tolerance is often observed, it is not officially recommended. The level converter also helps maintain proper voltage levels in both directions, reducing communication errors. Overall, the absence of a level shifter in many DHT22-ESP8266 circuits is due to the nature of the sensor's communication protocol, the use of pull-up resistors, and practical tolerance observed in ESP8266 inputs, but it carries some risk and is not strictly compliant with official specifications.
TL;DR: ESP8266 GPIO are 3.3 V ±10%; "It tolerates 5V" is anecdotal. Use level shifting for 5 V sensors like DHT22 on NodeMCU V3 to stay in spec. [Elektroda, kaczakat, post #17568333]
Why it matters: This helps makers safely hook DHT22 and other 5 V peripherals to ESP8266 without damaging GPIO or corrupting data.
Can I wire a 5 V–powered DHT22 directly to ESP8266 NodeMCU GPIO?
Do not wire a 5 V–pulled data line to a 3.3 V GPIO. Use a level shifter or ensure the signal never exceeds 3.6 V. “The need for a level converter is indisputable.” This avoids out‑of‑spec inputs and intermittent faults. [Elektroda, khoam, post #17568259]
Are ESP8266 pins 5 V–tolerant or only 3.3 V?
Treat ESP8266 GPIO as 3.3 V ±10% devices. Some users cite the vendor admitting field tolerance of 5 V, but that does not change the specification. Stay within spec and use a level shifter when in doubt. [Elektroda, kaczakat, post #17568333]
Why do many examples show DHT22 connected without a level shifter?
DHT22 typically runs from about 3.3–5 V, so many power it at 3.3 V and stay within ESP8266 limits. Some tutorials also assume anecdotal 5 V tolerance. Safer practice is 3.3 V power or level shifting when the sensor uses 5 V. [Elektroda, labo, post #17567389]
My DHT22 module has a 5 V pull‑up on DATA. What should I do?
Find the onboard pull‑up tying DATA to 5 V. Move the pull‑up to 3.3 V, replace it with a 3.3 V pull‑up, or insert a level shifter. Leaving it at 5 V overdrives the ESP8266 input. [Elektroda, labo, post #17567899]
How should I wire open‑drain buses (I2C/1‑Wire) between 5 V sensors and ESP8266?
Pull the shared lines up to 3.3 V. Open‑drain devices only drive low; the pull‑up defines the high level. With 3.3 V pull‑ups, the ESP8266 sees safe highs while 5 V devices still read lows. [Elektroda, Anonymous, post #17567756]
Will a simple series resistor protect a 3.3 V ESP8266 input from a 5 V output?
Yes, if it limits clamp‑diode current below about 20 mA. Estimate I ≈ (5 − 3.3 − 0.6)/R. Choose R to keep current under the limit, then verify timing still meets your baud/protocol needs. [Elektroda, Anonymous, post #17567919]
What happens if I exceed VDD + 0.6 V on an ESP8266 GPIO?
The input clamp diode conducts and sinks current. Excess can trigger parasitic latch‑up, shorting internally until power is removed. Limit current or keep the high level at or below 3.3 V to avoid this failure. [Elektroda, Anonymous, post #17567756]
Can a 5 V device read 3.3 V logic from the ESP8266 reliably?
Often yes, since many 5 V inputs register 3.3 V as high. Thresholds vary, so check the 5 V device datasheet. If margins are unclear, insert a level shifter to raise 3.3 V to robust 5 V levels. [Elektroda, Anonymous, post #17567919]
Do I need a level shifter for UART between a 5 V MCU and an ESP8266?
For modest UART speeds (≤1 Mb/s), a series resistor on the 5 V TX can work by limiting clamp current. For higher speeds or noisy wiring, use a proper translator for cleaner edges. [Elektroda, Anonymous, post #17567756]
Is 4.7 kΩ a good pull‑up for DHT22 with ESP8266?
4.7 kΩ is a typical DHT22 pull‑up value. If the sensor runs at 5 V, that pull‑up drives the data line to 5 V. Tie the pull‑up to 3.3 V or add a level shifter to protect the ESP8266. [Elektroda, Anonymous, post #17568280]
I accidentally put 5 V on an ESP8266 pin. Is it ruined?
Users report pins often survive brief 5 V mistakes. The spec remains 3.3 V ±10%, so any 5 V exposure is out‑of‑spec. Test the GPIO and add level shifting to prevent recurrence. [Elektroda, kaczakat, post #17568333]
How do I estimate maximum baud rate when using a series resistor?
Compute RC from your resistor and total input capacitances. The time constant limits edge speed and thus baud rate. Keep rise time far below the bit period for margin. “Once you have R and C, you can calculate the time constant.” [Elektroda, Anonymous, post #17567919]
What’s the safest way to hook up a DHT22 to an ESP8266?
  1. Power the DHT22 at 3.3 V to keep logic within limits.
  2. Ensure the data line’s pull‑up goes to 3.3 V.
  3. If any onboard pull‑up ties to 5 V, move it to 3.3 V or insert a level shifter. [Elektroda, Anonymous, post #17567756]
