LED strip control with D1 Wemos + IR TSOP1736 by Domoticz
maystero 8826 43
Can I use a Wemos D1 with ESP Easy and a TSOP1736 receiver to control an LED strip by PWM and IR remote commands through Domoticz?
Yes — ESP Easy can drive an LED strip with PWM and it can also handle IR input through a supported IR build plus Rules. For PWM, use the control URL like `http:///control?cmd=PWM,13,500`, where `13` is the GPIO and `500` is the 0–1023 PWM value; the pin must be configured as an output first [#17568706] For IR, upload an ESP Easy BIN with IR support (for example a Mega build that includes it), then enable Rules and map the received `IR` values to actions in a rule [#17623041][#17568706] If IR reading behaves oddly, one reported fix was to use the 2018.12.04 Mega build because later versions had a bug [#17623618] For the TSOP receiver, proper decoupling/power wiring matters; adding the recommended capacitor and wiring it as in the datasheet fixed random IR interference for one user [#17852042][#17854239]
  • #1 17568296
    maystero
    Help: 58
    Rate: 205
    I want to use the D1 Wemos module to control an LED strip.
    The functions are to be as follows:
    - On/OFF
    - brightness adjustment (e.g. from 1% to 100%)
    D1 module connected to Domoticz.
    In addition, I want to connect an IR receiver (e.g. TSOP1736) to the GPIO of e.g. D3
    so that I can perform the same functions with the TV remote control.
    Is this feasible?
    I have looked in the options of ESP Easy for PWM support, but have not found it.
    Also, is ESP Easy able to handle the IR commands of the remote control?
  • #2 17568460
    Slawek K.
    Help: 259
    Rate: 1303
    ESP Easy can be controlled by PWM. You do this by calling up the URL as follows :
    http://<espeasyip>/control?cmd=PWM,13,500
    Where 13 is the GPIO pin number and 500 is the PWM fill value between 0-1023.
    You can also specify short pulses :
    http://<espeasyip>/control?cmd=Pulse,14,1,500 - one pulse lasting 500ms on GPIO 14
    Of course, beforehand you have to set the pins accordingly in the ESP Easy configuration (as output). You can also control HIGH/LOW states or servos.
    More can be found here :
    https://www.letscontrolit.com/wiki/index.php/GPIO
    As far as IR handling is concerned, there is such a possibility - TSOP4838. You can assign specific rules to the port it is connected to.
    Log into ESP Easy, go to the Tools tab, select Advanced and put a tick next to Rules. You will then see an additional tab called Rules, where you can define local rules.
    Example (from the web) : Switch Input named Button.
    on PrzyciskOn do
    gpio 12,1
    gpio 13,0
    inputswitchstate 0,1
    endon
    on PrzyciskOff do
    gpio 12,0
    gpio 13,1
    inputswitchstate 0,0
    endon
    on Przycisk#switch do
    if [Przycisk#switch]=1
    event PrzyciskOn
    else
    event PrzyciskOff
    endif
    endon
    And again to read the literature https://www.letscontrolit.com/wiki/index.php/Tutorial_Rules
    Greetings
  • #4 17568970
    maystero
    Help: 58
    Rate: 205
    Super. Thanks for the tips.
    Of course, I guessed that you would have to use the Rules option to operate the IR remote. Just wondering... If I use the 4 buttons on the remote.
    1. ON
    2. OFF
    3. LOWER
    4. DARKER
    Then how do you capture the RC commands and how do you "place" them in the RULES?
    Slawek K.
    Help: 259
    Rate: 1303
    I'll take a look in my spare time and try to help you out.
    Best regards
  • #6 17570596
    maystero
    Help: 58
    Rate: 205
    I have started PWM control
    Code: C / C++
    Admittedly Domoticz does not support this type of control, but the idea itself works.
    The question of IR control remains.
  • #7 17621047
    maystero
    Help: 58
    Rate: 205
    rs6000 wrote:
    I will take a look in my spare time and try to help you.
    Greetings
    Any luck?
    I have the device prepared for testing as shown in the diagram....
  • #8 17623041
    maystero
    Help: 58
    Rate: 205
    I found this description on googling:
    https://www.letscontrolit.com/wiki/index.php/IR
    Unfortunately there is no IR Input option on my ESP Easy Mega.
    Why?
    OK
    I found it!
    You need to upload a BIN with IR support. E.g.
    Code: C / C++
    Hym....
    only I don't know why there is no support for the command in this version:
    Code: C / C++
    gets a return:
    Code: C / C++
    Slawek K.
    Help: 259
    Rate: 1303
    There is a bug, reported on github, I had the same problem, upload mega from 2018.12.04, in later versions there is this bug.
    Greetings
  • #10 17624195
    maystero
    Help: 58
    Rate: 205
    Actually the download to an older version restored the functionality of the ESP.
    I was able to get the TSOP4838 working.
    The circuit works because when I send the RC5 remote control signal:
    Code: Bash
    So I wrote RULES
    Code: Bash
    So that it switches the state on GPIO 12.
    But something is not working. I don't know if a badly written rule or if ESP is reading RC5 wrong.
  • #11 17624215
    Slawek K.
    Help: 259
    Rate: 1303
    You have endon unnecessarily, but try it like this :
    Code: C / C++
  • #12 17625429
    maystero
    Help: 58
    Rate: 205
    Super! Thanks. Works :) .
    I have extended this script,
    so that the 4 GPIO outputs can be controlled from the IR remote control
    Code: Bash
    Only the script does not work as I would like;
    Because when I press key 1 it activates GPIO 14.
    And when I press key 2 it activates GPIO 12 but deactivates 14
    Code: Bash
  • #13 17625870
    Slawek K.
    Help: 259
    Rate: 1303
    Put all IF instructions in one ON event. Right now I'm typing from my phone so I'm uncomfortable, if anything, I can't help until the evening, but rest assured you can do it. It works as you wrote, else causes a switch off when the button is not the right one. Inside the IF you need to place another IF that checks the state of the GPIO and changes it to the opposite.
    Greetings
  • #15 17627371
    Slawek K.
    Help: 259
    Rate: 1303
    I understand that you want the state of the pin to change to the opposite when the remote control button is pressed, yes ?
    Greetings
  • #16 17627382
    maystero
    Help: 58
    Rate: 205
    Greetings
    Yes,
    i.e. I press "key_1" GPIO,14 changes to the opposite state. GPIO 12, 16, 13 unchanged.
    I press "key_2" GPIO,12 changes to the opposite state and GPIO 14, 16, 13 unchanged.
    Same with the other keys 3 and 4.
    I suppose it is impossible to do this using IF.
  • #17 17627401
    Slawek K.
    Help: 259
    Rate: 1303
    Add Dummy Device :
    LED strip control with D1 Wemos + IR TSOP1736 by Domoticz .
    This will be the variable into which we will store the state of the button. The instruction will look like this :
    Code: C / C++
    For each pin you will need to add a Dummy device (variable, otherwise named), correct the task number and add this to the other IF instructions.
    Greetings
  • #18 17627563
    maystero
    Help: 58
    Rate: 205
    This is what my "variables" look like
    script:
    Code: Bash
    I slimmed down to two keys to make it easier to test.
    The script works as in the examples above....
    EDIT:
    I noticed that I made a typo:
    Code: Bash
    and it should be
    Code: Bash
    but no effect
  • #19 17627656
    Slawek K.
    Help: 259
    Rate: 1303
    Square brackets, not curly brackets.
  • #20 17627696
    maystero
    Help: 58
    Rate: 205
    I made typos....
    I corrected the script
    Code: Bash
    now it works like this:
    I press key 1, it changes GPIO 14 to the opposite (to 1)
    I press key 2, it changes GPIO 14 to the opposite (to 0)
    press key 2 (again), changes GPIO 12 to the opposite (to 1)
    press key 1, it changes GPIO 12 to the opposite (to 0)
  • #21 17627718
    Slawek K.
    Help: 259
    Rate: 1303
    Where do you check the pin states ? In the log ? Check physically e.g. with a pin meter.
    Best regards
  • #22 17627720
    maystero
    Help: 58
    Rate: 205
    Greetings
    I have LEDs connected to GPIO 14 and 12. The whole thing is watching how the LEDs behave
  • #23 17627920
    Slawek K.
    Help: 259
    Rate: 1303
    Since there are problems with this firmware mega, upload R147 http://www.letscontrolit.com/downloads/ESPEasy_R147_RC8.zip , it is in device TSOP4838. And let's check on this version., at me it works best in the drivers, and I have a dozen of them at home. I think I have this diode somewhere in the house so I will try to test it, but only in the evening.
    Greetings
  • #24 17628108
    maystero
    Help: 58
    Rate: 205
    Greetings
    I have uploaded the R147 version.
    After initial configuration I see that the TSOP does not work as expected:
    Code: Bash
    I press the same key on the RC remote control. Specifically it is the "1" key (rc5 philips)
    In the Log I get some random values of IR_RECEIVER#IR
    If I don't come up with anything I'll go back to ESP_Easy_mega-20181204_normal_IR_ESP8266_4096.bin
    EDIT:
    I messed around and got this version of the R147 version working.
    I added the Dummy Device
    I took another RC remote (this time from LG - it works better than from Philipis)
    I tweaked the script again:
    Code: Bash
    The result, it works as I described above. I.e..
    I press key 2 (again), it changes GPIO 12 to the opposite (to 1)
  • #25 17629372
    Slawek K.
    Help: 259
    Rate: 1303
    So how about this, in the controller located in the light switch box I have this configuration on R147 :
    BUTTON is the button I use to switch the light on/off - in your case it's the button key, and LIGHT is the relay pin. When the state is changed (0 or 1) i.e. the BUTTON#Switch event is called, the state of the LIGHT#Switch pin which turns the relay on/off is checked and the state is changed to the opposite.
    The rules look like this :
    Code: C / C++
    The toggle event is called remotely by Domoticz as follows : http://192.168.1.xxx/control?cmd=event,toggle and does exactly the same as the event "on BUTTON#Switch do", and everything works perfectly, I have it in all the rooms, I have changed the switches to pulse (staircase) switches and it works in parallel when the button is pressed or through the switch in Domoticz, and always changes the state to the opposite, no matter which option I use.
    So try this method, instead of Dummy Device add Input Switch j.w for each pin you want to control.
    Greetings
  • #26 17629653
    maystero
    Help: 58
    Rate: 205
    Current status:
    I press the "1" key on the RC remote control:
    I press the "2" key on the RC remote control:
    It is better because
    I press key "1" GPIO 14 = 1
    I press key "2" GPIO 14 = 0 and GPIO 12 = 1
    I don't understand why the function of key "1" affects key "2" ?
    Code: Bash
    edit:
    struggle and fight
    noticed that:
    Code: Bash
    when I have only a rule for one GPIO and I send IR=2017267209 it changes the state to 1, but sending IR=2017267209 again does not change the state to the opposite. The LED does not go off.
    It only goes off when I press another button on the remote....
    what is wrong with this syntax?
  • #27 17630232
    Slawek K.
    Help: 259
    Rate: 1303
    You are missing the endif closing condition. Check like this :
    Code: C / C++
  • #28 17630482
    maystero
    Help: 58
    Rate: 205
    Late at night, I also noticed it was missing:
    Code: Bash
    I have added it to the RULES:
    Code: Bash
    It works as I described in the post above.
    And LOG
    Code: Bash
    You can see that it didn't change the state to the opposite....
    as if it did not change the Switch_1 value
    Added after 12 [hours] 30 [minutes]:
    I don't know what's going on anymore myself.
    I have assembled a second circuit.
    I am using a TSOP1736 for testing.
    The ESP in the DEVICES list has a TSOP4838.
    Could this be influencing this strange behaviour of the circuit?
  • #29 17851986
    maystero
    Help: 58
    Rate: 205
    I would like to get back on topic as I have not been able to solve the problem.
    I have purchased a TSOP4838.
    I found some time
    I connected to the ESP, according to the schematic:
    I connect the power via USB, no signal falls on the IR receiver. And in the LOG
    Code: C / C++
    [/code].
    There is an awful lot of this interference! Full of "random" waveforms (EVENT: IR_RECEIVER).
    I don't know what I'm doing wrong and where the error lies.
    Anyone who knows, anyone who has seen please help.
The discussion addresses controlling an LED strip using a D1 Wemos module integrated with Domoticz, focusing on on/off switching and brightness adjustment via PWM. The user aims to add IR remote control functionality using a TSOP1736 or TSOP4838 IR receiver connected to GPIO pins (e.g., D3). ESP Easy firmware is used for device control, with PWM commands issued through HTTP URLs. PWM control is confirmed feasible via ESP Easy, but Domoticz lacks native PWM support. IR command handling requires enabling the Rules feature in ESP Easy and uploading a firmware version with IR support (e.g., ESP_Easy_mega-20181208_normal_IR_ESP8266_4096.bin or R147). Users report issues with IR decoding, firmware bugs, and syntax errors in Rules scripts, such as missing spaces after IF statements and incorrect bracket usage. Solutions include using Dummy Devices to store toggle states, consolidating IF conditions within a single ON event, and ensuring proper wiring and power supply to the TSOP IR receiver, including adding a 4.7µF capacitor for stability. The IR remote codes are captured as events, and Rules scripts toggle GPIO outputs accordingly. Firmware version compatibility is critical, with older versions sometimes more stable for IR functions. PWM commands follow the syntax http:///control?cmd=PWM,,,,, with fill values from 0 to 1023; a fill of 0 immediately turns off LEDs without smooth dimming. Firmware updates (e.g., ESP_Easy_mega-20190903_normal_core_241_ESP8266_4M1M.bin) resolve some PWM issues. The discussion includes practical examples of Rules scripting for IR command handling and PWM control, emphasizing careful syntax and device configuration.
TL;DR: 0-1023 PWM range gives 1024 brightness steps and “ESP Easy can be controlled by PWM” [Slawek K., #17568706]. Use an IR-enabled ESP Easy build plus a TSOP4838 on D3 to read TV-remote codes.
Why it matters: One board handles Wi-Fi, fading LEDs and IR control without extra microcontrollers.
2. What PWM command string should I use?
Format: PWM,GPIO,DUTY. Example: /control?cmd=PWM,12,512 sets 50 % duty [Elektroda, Slawek K., post #18166363] Add optional TIME,Hz for fades (e.g. PWM,12,0,1000,4000).
3. Why does duty 0 switch the strip off instantly?
A duty of 0 resets the pin to LOW, exiting PWM mode; smooth fade needs a small non-zero value (e.g. 20) then ramp down [Elektroda, khoam, post #18166548]
4. How do I enable smooth fade on power-down?
Issue two commands: 1. PWM,12,1023,1000,4000 to ramp to full; 2. PWM,12,20,1000,4000 then finally PWM,12,0. Each step lasts the TIME parameter (ms).
5. Which firmware contains the IR Input plugin?
Any build name ending in IR (e.g. ESP_Easy_mega-20181204_normal_IR_ESP8266_4096.bin) or _normal_core241... after 2019-09-03 [Elektroda, maystero, #17623041; demsy, #18166746].
6. How do I wire the TSOP4838/1736 correctly?
Connect Vs to 3.3 V, GND to GND, OUT to D3 (GPIO 0/Pad3). Add 4.7 µF electrolytic across Vcc–GND and a 100 Ω series resistor on Vs to suppress noise [Elektroda, khoam, post #17852042]
7. I see random codes in the log—what’s wrong?
Noise or unstable supply. The capacitor + resistor filter removes >90 % of false triggers. Also keep receiver away from CFL and plasma TV sources [Elektroda, khoam, post #17852042]
8. How do I capture IR codes and toggle specific GPIOs?
  1. Enable Rules in Tools→Advanced. 2. In the log note IR_RECEIVER#IR value. 3. Create a rule:
on IR_RECEIVER#IR do
if [IR_RECEIVER#IR]=2017267209
gpio,14,![14]
endif
endon
This inverts GPIO 14 each time that code is received [Elektroda, Slawek K., post #17624215]
9. My rule never toggles twice—why?
Ensure a space after IF: if [var]=value. Missing space prevents the parser from updating the variable, so the second press appears identical [Elektroda, Slawek K., post #17852405]
10. "Unknown or restricted command!" after flashing—fix?
A bug exists in builds after 2018-12-08; downgrade to 2018-12-04 or newer 2019-09-03 core 2.4.1 build [Elektroda, Slawek K., #17623618; demsy, #18166746].
11. How can I integrate with Domoticz if it lacks PWM widgets?
Create a virtual switch in Domoticz and point its On/Off action URLs to ESP Easy PWM commands. Alternatively use a Dummy device and Rules to translate MQTT messages to PWM [Elektroda, maystero, post #17570596]
12. What’s the maximum current the ESP8266 GPIO can drive?
Each GPIO sources about 12 mA max; always drive LED strips through a MOSFET or LED driver, not directly [Espressif Datasheet, 2020].
13. What edge-case firmware failure should I watch?
Build 2018-12-08_normal_IR blocks all GPIO, returning "Unknown command"; many users spent hours debugging before rolling back [Elektroda, Slawek K., post #17623618]
14. Quick 3-step setup for IR-controlled dimming
  1. Flash _normal_IR build and enable Rules.
  2. Wire TSOP4838 with 4.7 µF cap to D3.
  3. Add rule that maps captured IR codes to PWM commands; test with /control?cmd=PWM,12,512.
