How do I pair the additional remote control from the Velux KUX 110 with the SML roller shutters?
q111q 6072 4
  • #1 17432865
    q111q
    Rate: 140
    I have 2 external roller shutters Velux SML + Velux Kux 110 (there is an additional remote control for it). My question is whether it is possible to give this remote control to these two roller shutters without of course deleting the original remote controls that came with the roller shutters. What I want is the effect of using the additional remote from the Kux 110 to open and close both roller shutters simultaneously or one after the other.
  • #2 17434967
    q111q
    Rate: 140
    - and is it possible to add two remote controls to a velux SML roller shutter?
  • #3 17435952
    Marek J.
    Help: 526
    Rate: 950
    The Velux SML is the motorised roller shutter itself and the KUX 110 is the control system for these SML roller shutters. You can connect up to 5 roller shutters to the KUX system, but they will all work simultaneously. If you wish to have independent control you will need to purchase the KLR200. It is not possible to program independent remote controls for the SML roller shutters alone/single, as they do not have controllers/receivers.
  • #4 17436144
    q111q
    Rate: 140
    I thought the KUX 110 was a power supply, but if it is also a controller, can two remote controls be programmed to this controller for one roller shutter?
    The end result I would like to achieve: one remote in the room which was separately with each roller shutter (and here I control only this one roller shutter), and downstairs in the living room one remote which will cover all the windows at once.
    I don't know if this is a problem for velux?
    I have it this way with the nice
  • #5 17441214
    q111q
    Rate: 140
    I have found a solution - topic closed.
