How do I configure the Sonoff Basic switching scene via TH10 thermostats?
lukasz040481 1860 3
  • #1 17686437
    lukasz040481
    Hi. I have sonoff th10 thermostats (pcs10) controlling the heating valves and a switch on the
    Sonoff basic which powers the pump. Is it possible to set up a scene (or any other way) which would switch on the regular sonoff basic switch when any of these 10 thermostats turns on its output (temperature below the set point) and switches off when the temperature set in th10 rises above the set point?
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Yes, but this would require a software change in all sonoffs e.g. to tasmot
  • #3 17687889
    lukasz040481
    On Evelinķ is it not possible to set the scene so that every th10 switches on basic while in auto mode?
  • #4 17694495
    lukasz040481
    Which firmware will be best for this application: AFE, SUPLA or TASMOTA? I am not a programmer but an electrician.
