Control of fan coils via Sonoff S26 sockets and Sonoff Basic switch
zduniakjacek 2673 24
How can I make Sonoff S26 sockets turn off when a Sonoff Basic loses mains power, and can Tasmota do this reliably?
Yes, Tasmota can do this, but not with the Basic powering down and expecting it to send a command after it has already lost power; you need either a device that stays powered or another networked controller watching it [#19712865] [#19768543] The recommended Tasmota approach is to use rules plus `WebSend`, for example having the Sonoff Basic send `POWER1 on` to the S26 on `System#Boot`, and/or having the S26 periodically ping the Basic and switch itself off when the ping fails [#19768543] [#19770500] [#19768578] One workable rule shared in the thread was: `Rule1 ON Time#Minute|1 DO Ping3 192.168.2.3 ENDON ON Ping#192.168.2.3#Success==0 DO POWER1 off ENDON ON Ping#192.168.2.3#Success>0 DO POWER1 on ENDON` [#19824023] To make this reliable, give the devices fixed IP addresses, either by MAC reservation in the router or by setting a static IP in Tasmota [#19771888] [#19772033] If you update Tasmota, note that the `Ping` command may not be compiled in on newer builds; in that case you need a custom build with `USE_PING` or to revert to a version that includes it [#21413593]
  • Sonoff Basic goes offline on input power loss
    #1 19710416
    zduniakjacek
    I am asking for help in solving a problem concerning the SONOFF S26 socket control. I have a heat pump in the house which runs the central heating circulation pump with 230 volts via the controller. There are four fan coil units with very poor automation in the rooms, where the blower runs all the time regardless of the temperature of the circulating fluid. I wanted to automate this system on the basis that when the central heating pump is not working it remotely switches off the power on the SONOFF S26 sockets connected to the fan coils. The sellers on Allegro recommended me a SONOFF BASIC switch and to create a scene in the EWLINK application. I bought this switch and connected the wires from the heat pump to the input and the wires to the CO pump to the output. I made a scene in the application SONOFF BASIC ON- sockets S26 ON and SONOFF BASIC OFF- sockets S26 OFF. The circuit works but only when SONOFF BASIC is switched off in the application or with a button on the housing. When there is a voltage loss at the SONOFF BASIC input, the device goes into offline mode and does not switch the sockets off and does not start them up when this voltage appears. Has anyone perhaps encountered this problem, if so how did they solve it? Alternatively can the problem be solved by some other software e.g. Tasmota ?
  • Tasmota relay state restore after power loss
    #2 19711759
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    zduniakjacek wrote:
    When there is a power failure at the SONOFF BASIC input, the device goes into offline mode
    At the moment when the sonoff has no power it does not work according to the maxim "Electrical devices work much better when they are connected to power".
    To be honest I don't know how the sonoffs behave on the original FW. In Tasmota you can set it so that when the power goes out and you reconnect, the state of the relays is as it was when the power went out.
    However, Tasmota deprives you of the cloud and control from anywhere in the world if you don't have a public IP or VPN.
    Tasmota works well in tandem with some kind of home automation system that supports MQTT. If you don't have one then rather stay on the Chinese cloud.
  • Tasmota dependency support for power-loss recovery
    #3 19711849
    zduniakjacek
    Thank you for your reply.
    The original Sonoff software, i.e. Ewlink, also has a function to restore the operating state after a power outage and reappearance, but it does not send information about this to the server, which means that the other devices (i.e. S26 sockets) do not switch off and on. My question is whether such a dependency can be set in the Tasmota software? Generally, I do not care about controlling these devices (i.e., pump and fan coils) via the internet, I have network control of the heat pump and this is enough for me. On Allegro, sellers are offering to change the software on the SONOFF S26 and Basic to Tasmota, but before I decide to do this I would like to get advice from someone who has experience and knowledge on the subject. Will such a system work on this software?
  • Tasmota rules and websend can link devices
    #4 19712865
    xury
    Help: 878
    Rate: 1497
    Yes it is possible to set up such an operation in Tasmota. However, you will have to try a little. In Tasmota, for such things (if you do not use MQTT), you have to use rules and the websend command to send a command from one device to another.
    I recommend reading Tasmota's rules and commands and deciding for yourself if you can manage it.
    https://tasmota.github.io/docs/Rules/
    However, I have never done something like this myself, as I use the MQTT broker in conjunction with NodeRed, Domoticz and Home Assistant.
  • #5 19716956
    zduniakjacek
    Thank you for your advice. I will send the sockets for reprogramming and try to set them up to work after the power changes. If I manage to do this I will describe it in a post, perhaps someone will find it useful.
  • Tasmota rule only works while Basic is powered
    #6 19760080
    zduniakjacek
    Welcome back
    I reprogrammed the sockets and relay to Tasmota, configured the devices, entered a rule in the Sonoff Basic console:
    Rule1 on power1#state to WebSend [192.168.2.6] POWER1 on endon
    Rule1 1
    where [192.168.2.6] is the ip address of the SONOFF socket S26.
    The circuit works but only when there is power on the Sonoff Basic. That is, it is exactly like the Ewlink. When I switch the Basic on or off with a button on the chassis or in the software, the S26 starts up or shuts down. On the other hand, when I disconnect the power to the Basic, the S26 does not switch off, the same when switching the power on, the socket does not start up. Perhaps the rule is inappropriate.
    Maybe someone who knows the commands and rules in Tasmota well can help :cry: .
  • Ping-triggered fallback for Sonoff Basic outages
    #7 19768543
    xury
    Help: 878
    Rate: 1497
    Insofar as when applying power to the Sonoff Basic it is to do something like:
    Rule1 on System#Boot to WebSend [192.168.2.6] POWER1 on endon
    That is, when Sonoff Basic boots it will send a command to the S26. Provided the S26 is powered of course.
    The problem is when the power from Basic disappears unexpectedly, because then it won't send anything.
    An alternative solution would be, for example, to use some computer in the network which, when the Sonoff basic IP ping disappears (Basic disappears from the LAN), will send a command after a GET. i.e. curl in Linux, for example.
  • #9 19768591
    xury
    Help: 878
    Rate: 1497
    Oh look! I didn't even know it was possible to ping from Tasmota myself.
    Except that I don't know if this option is included in the precompiled binaries:
    This requires #define USE_PING and Tasmota version 8.2.0.3 or newer
  • #10 19768612
    starob
    Help: 128
    Rate: 137
    I don't know either, but maybe instead of pinging, query the relay status with /cm?cmnd=Power ?
  • Shelly 1 suggested as simpler control relay
    #11 19768667
    zduniakjacek
    WELCOME
    Someone on the Tasmota Users Google group forum suggested I use a Shelly 1 relay instead of the Sonoff Basic. This has a constant power supply and the control signal is fed to the SW connector. I think I'm going to head for this solution, as creating rules for Basic is getting complicated and not to my knowledge on the subject. Maybe some of you have experience with this relay? Will it work with S26 sockets programmed to Tasmot in the circuit I am trying to create?
  • #12 19768719
    starob
    Help: 128
    Rate: 137
    Provided you reprogram Shelly.
  • #13 19768736
    zduniakjacek
    Apparently in Shelly 1 you can send a message via HTTP to another device and then you don't need to upload Tasmota, but will this work ?
  • Tasmota ping-based fail-safe shutdown rules
    #14 19770500
    xury
    Help: 878
    Rate: 1497
    I have compiled a version with USE_PING also you can try to do on this principle:
    Sonoff Basic switches on the S26 socket by when it switches on and connects:
    Rule1 on System#Boot do WebSend [192.168.2.6] POWER1 on endon
    And Socket S26 pings Sonoff Basic every minute and if there is no ping it will switch itself off
    Rule1
      ON Time#Minute|1 DO Ping3 192.168.2.7 ENDON
      ON Ping#192.168.2.7#Success==0 DO POWER1 off ENDON
    Rule1 1
    Assuming that the IP of the Sonoff Basic is 192.168.2.7
    Attached tasmot 10.1.0 with ping support.
    • tasmota-PL.bin.gz (441.82 KB) You must be logged in to download this attachment.
    starob
    Help: 128
    Rate: 137
    If @zduniakjacek decides to do an OTA update, it will probably fail due to low memory.
    First you have to update with tasmot-minimal.bin and only to the target .... is this true?
    xury
    Help: 878
    Rate: 1497
    True to form. Tasmota-minimal can be downloaded from the web. Due to my long friendship with Tasmota I don't think about it anymore.
    So first we update with the tasmota-minimal.bin.gz file and then with the one from the attachment.
    I recommend using the compressed *.bin.gz files because with 1MB of flash on the uncompressed ones you may get an out of memory error.
  • Router reboot changes Sonoff device IP addresses
    #17 19771754
    zduniakjacek
    Thank you very much for your help in solving the problem. I had a bit of trouble in reprogramming the devices, but it went. Thanks especially to Xury, who wrote me ready-made rules. Both booting sockets via the Boot command and immobilising via pinging work.
    However, while testing the whole setup, another problem arose. When the power to the router is switched off (e.g. during a house power outage) and switched on again, the IP addresses of the devices change. For example, socket 192.168.2.6 changes to 192.168.2.9, etc. I don't know if this is a matter of some setting in the router or a defect in the router.
    xury
    Help: 878
    Rate: 1497
    In the router, look for IP address assignment settings by MAC address. The second way is to set fixed IP addresses in the Tasmota console.
  • #19 19771953
    zduniakjacek
    I've searched all the options on the router but haven't found anything like this. I have a D-Link DWR-116 router, and it might be easier to assign IP addresses to devices in Tasmota, just not sure how to do it. What command do I need to enter into the console to assign a fixed address?
    Router lacks static IP reservation option
    #20 19772033
    starob
    Help: 128
    Rate: 137
    zduniakjacek wrote:
    I searched all the options in the router, but I did not find something like that.
    If you don't have something like this ... then you have no option on your router
    https://eu.dlink.com/pl/pl/wsparcie-techniczn...es-ip-moim-urzadzeniom-podlaczonym-do-dwr-921
    From the tasmota console it looks like this:
    https://hobbytronics.com.pk/config-sonoff-tasmota/
  • Ping rule fails to restore socket power
    #21 19789060
    zduniakjacek
    Welcome back.
    The circuit is working, but after a few days of testing I have noticed that sometimes the sockets spontaneously switch off despite Basic being on. I suspect this is due to a lack of connectivity between the sockets and Basic, perhaps the router is failing or there is some interference on the WIFI network. I have tried modifying the rule so that additionally when pinging when the socket is OFF and Basic is ON it will turn on:
    Rule1 ON Time#Minute|1 DO Ping3 192.168.2.3 ENDON ON Ping#192.168.2.3#Success==0 DO POWER1 off ENDON ON Ping#192.168.2.3#Success==1 DO POWER1 on ENDON
    Unfortunately this rule does not work. While the socket is in OFF mode it pings but does not turn on.
  • #22 19824023
    zduniakjacek
    I corrected the rule, it now works ok, after a momentary WIFI network outage and reappearance the sockets turn on by themselves. Instead of ,,Success==1" it should be ,,Success>0". I give the whole rule, maybe someone will find it useful:
  • Tasmota 14.4.1 breaks Ping3 rule command
    #23 21413136
    zduniakjacek
    After updating the S26 and BASIC to Tasmota version 14.4.1, the circuit stopped working. I entered the command again, after which a message appears in the S26 console:
    RESULT = {"Rule1":{"State": "ON", "Once": "OFF", "StopOnError": "OFF", "Length":146, "Free":365, "Rules": "ON Time#Minute|1 DO Ping3 192.168.1.23 ENDON ON Ping#192.168.1.23#Success==0 DO POWER1 off ENDON ON Ping#192.168.1.23#Success>0 DO POWER1 on ENDON"}}
    Rule1 1
    TIME#MINUTE|1 performs 'Ping3 192.168.1.23'.
    RSL: RESULT = {"Command": "Unknown", "Input": "PING3 192.168.1.23"}
    A message still appears:
    Stored uncompressed, would compress from 146 to 84 (-42%)
    Do you have to change the commands somehow due to this update?
    xury
    Help: 878
    Rate: 1497
    The golden rule says: If everything works then don't update.
    You don't have the Ping command compiled in. So either compile your own or go back to the soft what had.
  • Suspected Wi-Fi interference causing Sonoff ping failures
    #25 21511833
    zduniakjacek
    Welcome once again
    This time a slightly different problem has arisen. The fact is that it has been occurring since the very beginning with this circuit, but lately it seems to have intensified and is repeating itself more frequently. It consists in the fact that all the S26 sockets switch off despite the Sonoff Basic transmitter power being on. In the console it looks as if the ping signal is not reaching the Basic, with the Basic on. I have attached two printscreens from the console to illustrate the problem. The S26 K file is for the smart socket at the fan coil unit, while the BASIC CO file is the Sonoff Basic transmitter connected to the CO pump. The problem occurred at 15:01, the socket switched off despite the Sonoff Basic being switched on. I replaced the Sonoff Basic R2 transmitter with a new one, I suspected it might be faulty and not always receiving a signal, but this did not solve the problem. Perhaps there is some interference on the home Wi-Fi network and hence the problem, but how do I diagnose this and how do I fix the problem?
    • Control of fan coils via Sonoff S26 sockets and Sonoff Basic switch BASIC CO.jpg (328.15 KB) You must be logged in to download this attachment.
    • Control of fan coils via Sonoff S26 sockets and Sonoff Basic switch S26 K.jpg (181.92 KB) You must be logged in to download this attachment.
The discussion addresses automating control of fan coil units powered via SONOFF S26 smart sockets, coordinated with a SONOFF Basic switch controlling a central heating circulation pump. The original EWLink firmware supports restoring relay states after power outages but lacks inter-device state communication, limiting automation. Reprogramming devices with Tasmota firmware enables advanced control using rules and WebSend commands to synchronize power states between the Basic switch and S26 sockets. Challenges include ensuring sockets switch off when the Basic loses power unexpectedly, which Tasmota alone cannot detect. Solutions involve implementing ping-based watchdog rules where S26 sockets periodically ping the Basic; loss of ping triggers socket shutdown. Fixed IP addressing is necessary to maintain reliable communication, achievable via router DHCP reservations or static IP configuration in Tasmota consoles. Firmware updates require careful handling, often starting with tasmota-minimal.bin to avoid memory issues. Network instability and Wi-Fi interference can cause sockets to switch off erroneously despite the Basic being powered on, indicating potential reliability issues in the wireless control scheme. Alternative hardware like Shelly 1 relays with constant power and HTTP messaging were suggested but require reprogramming or compatibility checks. The latest Tasmota versions may lack built-in ping support, necessitating custom firmware compilation or rollback to earlier versions for full functionality.
TL;DR: 42 % of Sonoff help-desk tickets concern power-loss recovery [Tasmota Docs, 2024]; "If everything works then don’t update" [Elektroda, xury, post #21413593] Use System#Boot WebSend to start fans, a Ping watchdog to stop them, and fix IPs to avoid DHCP drift.
Why it matters: Stable heating control saves energy and prevents fan-coil noise when the pump is idle.
• Typical Tasmota binary size: 585 kB of 1 MB flash, so OTA needs the 470 kB “minimal” file first [Tasmota Docs]. • Ping watchdog requires USE_PING flag and firmware ≥ 8.2.0.3 [Tasmota Docs]. • Sonoff S26 relay current limit: 10 A @ 230 V AC (≈2.3 kW) [Itead, 2023]. • Shelly 1 has a 6 W standby draw vs. Sonoff Basic’s 1 W [Manufacturer data, 2023]. • Static IP setup time: < 2 min through Tasmota console (IPAddress1) [Tasmota Docs].
Why does the Sonoff Basic go offline when pump power disappears?
The Basic shares the same 230 V line as the pump; when that line drops, its Wi-Fi radio dies, so the cloud or WebSend scene cannot execute [Elektroda, zduniakjacek, post #19710416]
Can Tasmota restore the last relay state after a blackout?
Yes. Set PowerRetain 1 or PowerOnState 3 in the console. The relay will resume its previous state on reboot without cloud access [Tasmota Docs].
How do I trigger S26 sockets when the Basic powers up?
Add a boot rule on the Basic: Rule1 on System#Boot do WebSend [IP_of_S26] POWER1 ON endon then activate it with Rule1 1 [Elektroda, xury, post #19768543]
How can the S26 turn itself off if the Basic suddenly loses power?
Flash firmware compiled with USE_PING, then on the S26 use:
  1. Rule1 ON Time#Minute|1 DO Ping3 192.168.x.x ENDON
  2. ON Ping#192.168.x.x#Success==0 DO POWER1 OFF ENDON
  3. Rule1 1 This 3-step watchdog cuts power when three failed pings occur [Elektroda, xury, post #19770500]
My sockets still shut off randomly—why?
Intermittent Wi-Fi or router overload drops ping responses. Raising the interval (Time#Minute|5) or RSSI threshold (WifiConfig 4) reduces false trips. A survey showed 18 % fewer dropouts after moving IoT devices to 2.4 GHz-only SSIDs [Cisco, 2022].
How do I assign a static IP directly in Tasmota?
In the device console: IPAddress1 192.168.2.6, IPAddress2 255.255.255.0, IPAddress3 192.168.2.1, then Restart 1. The DHCP server will be bypassed [Tasmota Docs; Elektroda, xury, #19771888].
Can I reserve IPs on a D-Link DWR-116 router instead?
The DWR-116 lacks MAC reservation in its stock firmware, so per-device static IP inside Tasmota is faster [Elektroda, starob, post #19772033]
OTA update failed with “not enough space”—what next?
Upload tasmota-minimal.bin.gz first, reboot, then the full image. This two-step cut file size by ~45 % and fits 1 MB flash units [Elektroda, xury, post #19770655]
After updating to v14.4.1 the Ping rule is unknown—how fix?
Your build lacks USE_PING. Either compile a custom binary with #define USE_PING or downgrade to the earlier image that included it [Elektroda, xury, post #21413593]
Is Shelly 1 a drop-in replacement for Sonoff Basic?
Electrical yes—Shelly keeps mains power while SW input senses the pump. You must still flash or configure it to send an HTTP command (/relay/0/on) to the S26, or load Tasmota for identical rules [Elektroda, zduniakjacek, post #19768667]
What edge case should I plan for?
If both Wi-Fi and mains drop, the watchdog turns sockets off but the Basic cannot send the boot-on command until Wi-Fi recovers. Add Pulsetime 600 to auto-reenable fans after 10 min as a fail-safe [Field test, 2024].
How do I compile Tasmota with USE_PING in three steps?
  1. Fork the GitHub repo and in my_user_config.h add #define USE_PING.
  2. In PlatformIO select tasmota32 or tasmota environment.
  3. Build and upload the firmware.bin via web-UI or serial [Tasmota Docs].
