How to connect the wires to a Drutex roller shutter? Diagram and doubts
tinca2 8415 18
How should I wire a Drutex roller shutter motor with five wires when it is controlled only by remote and not by wall switches?
For remote-only use, connect the motor’s supply and earth normally: brown to brown, blue to blue, and green/yellow to PE; leave the extra black and grey wires insulated/secured and do not bridge them to neutral [#17724163] The built-in radio module handles the up/down control itself, so you only need to program the remote to the actuator [#17722227][#17722478] Several replies warn that the posted wiring diagram/manual looks wrong or modified, so it should not be followed blindly [#17722215][#17724348]
  • #1 17722090
    tinca2
    I have some roller shutters from Drutex to connect .
    I have been given a wiring diagram , but I am not sure if I understand it correctly .
    I have five wires from the roller shutter as shown in the diagram.
    According to the diagram, I have to put a phase on the blue roller shutter
    On the grey of the roller shutter I have to feed zero and what ? On the black and brown I also have to bridge zero ?
    How to connect the wires to a Drutex roller shutter? Diagram and doubts .
  • #2 17722117
  • #3 17722201
    tinca2
    There are no switches, only remote control.
  • #4 17722213
  • #5 17722215
    Homo_toxicus
    Help: 76
    Rate: 375
    • N10E_kwiecien_2018.pdf (578.67 KB) You must be logged in to download this attachment.
    • INEL.pdf (370.33 KB) You must be logged in to download this attachment.
  • #6 17722227
  • #7 17722289
    tinca2
    Homo_toxicus wrote:
    I advise against using the scheme from post #1 ! I advise against using the scheme from post #1 !
    Downloaded from :
    http://www.inel.gda.pl/images/pliki/instrukcje/N10E_kwiecien_2018.pdf
    https://systemy.kasiarolety.pl/pl/p/SILNIK-IN...17-Detekcja-Elektroniczne-Krancowki-N-10E/733
    Well that's exactly what doesn't fit me either , that's why I'm looking for hints.
    In what you have given the black and brown is through the switch (up and down), in my case there is no switch, only the remote control.
    So should the voltage go to both wires at the same time?
  • #8 17722325
    Homo_toxicus
    Help: 76
    Rate: 375
    Read the engine manuals carefully. If you don't "get it", it's better to have it done by someone you know better. You can do great harm to someone with an incompetent connection.
  • #9 17722331
  • #10 17722357
    tinca2
    Robmac wrote:
    is this a scan of the original instructions?
    Yes, from drutex.
  • #11 17722367
    Homo_toxicus
    Help: 76
    Rate: 375
    If you have it in PDF why not release the whole manual?
  • #12 17722377
  • #13 17722412
    Homo_toxicus
    Help: 76
    Rate: 375
    I have the impression that this excerpt from the alleged manual is heavily modified by the subject author.
  • #14 17722415
  • #15 17722441
    tinca2
    Homo_toxicus wrote:
    I have the impression that this section of the alleged instructions is heavily modified by the subject author.
    Well that made me laugh. :) .
    As if to what end?
    I didn't post the whole thing because there is nothing else there that is needed for my question.
    • instrukcja silników(PL).pdf (410.88 KB) You must be logged in to download this attachment.
  • #16 17722445
    Homo_toxicus
    Help: 76
    Rate: 375
    Designation of the blue wire - LIVE. Why would the manufacturer use this word to describe the phase wire. Suggested wiring not in accordance with any standard. Resolution of the pictures as if someone incompetently pasted them together in painter's pen. I can't believe that a Polish manufacturer would mix up the colours of the wires so much.
    P.S. This manual is strange. I don't see any manufacturer's markings or logos on any of the pages and on top of that the notation "original instruction manual". - For me, this is a nightmare hoax, like so many on ELECTRODAY lately.
    Added after 7 [minutes]:
    Maybe someone sent a colleague such a "flep" without any trademarks and clear information about the deviation from the generally accepted rules used in electrical engineering in our country....
  • #17 17722478
  • #18 17724163
    tinca2
    Today I solved the problem , the connection is simple.
    Brown to brown
    Blue to blue
    Green to yellow to z-ż
    Black and grey can be secured, works as it should.
    I don't know why there are such contrived connections in this manual , but certainly not by me.
    Regards
  • #19 17724348
    Homo_toxicus
    Help: 76
    Rate: 375
    Please - here is the manual for this engine. It retains the connection rules and what the black and grey wires are for.
    The manual was downloaded from the INEL website. The manufacturer's "signature" appears on each page. This is why I think that the instruction you have presented to us is "wrong", because it is not even described precisely for which product it is intended, and, moreover, the alleged appendix for connecting radio-controlled motors contains an error in its very title, which certainly would not be allowed by a manufacturer as serious as DRUTEX. Therefore, I would just like to ask you where you "found" this nonsense?
    • N-10RE_kwiecien_2018.pdf (552.97 KB) You must be logged in to download this attachment.
The discussion addresses wiring a Drutex roller shutter with five wires and clarifies confusion about the provided wiring diagram. The blue wire is designated as live (phase), and the grey wire corresponds to neutral (zero). The black and brown wires are intended for manual control switches (up and down), which are tactile buttons; however, in the case of remote control operation only, these wires should remain insulated and unconnected. The remote control communicates wirelessly with the actuator, which contains an internal radio module that manages the shutter movement by shorting the black or brown wires internally. It is emphasized that connecting black and brown wires directly to neutral simultaneously can damage the actuator. Proper connection involves linking live (L) to blue, neutral (N) to grey, and grounding the protective earth (PE). The black and brown wires are only used if manual switch control is present. The original manual excerpt provided by the user is suspected to be unofficial or altered, lacking manufacturer markings and containing non-standard wire color designations. A reliable manual from the INEL website is recommended for accurate wiring instructions. The user later confirms a successful connection by matching wire colors (brown to brown, blue to blue, green/yellow to ground) and insulating black and grey wires, resulting in correct operation. The discussion highlights the importance of following official documentation and understanding the actuator's internal radio control mechanism to avoid wiring errors and potential damage.
TL;DR: Drutex radio shutters expose two control wires; "You can't connect them together to neutral." For remote-only, connect L, N, and PE, insulate the control leads, then program the remote. This FAQ helps DIYers safely wire five‑lead Drutex/INEL shutters. [Elektroda, Anonymous, post #17722478]
Why it matters: Miswiring control leads can instantly damage the actuator and create a safety risk.
How do I wire a Drutex radio shutter with no wall switch?
Use this remote-only setup. 1) Connect N to grey, L to blue, and PE to green-yellow. 2) Cap/insulate black and brown (manual control leads). 3) Program/enroll the remote to the actuator per instructions. This isolates manual control and uses the built-in radio safely. [Elektroda, Anonymous, post #17722377]
What are the black and brown wires for on Drutex motors?
They are manual control inputs. The internal radio module shorts either black or brown to N to run down or up. Do not tie them together or to N simultaneously. Use a momentary switch if adding manual control. [Elektroda, Anonymous, post #17722478]
Can I connect both black and brown to neutral (N)?
No. Connecting both control leads to N at once can burn the actuator. Quote: "You can't connect them together to neutral because you will eat up the actuator." Keep one open while the other is active. [Elektroda, Anonymous, post #17722478]
If my manual shows blue as LIVE, should I follow it?
Treat it as suspect. A user flagged such a diagram as modified, lacking logos, and mixing colors. Verify the manual’s origin and model labeling before wiring. Avoid undocumented color assignments. [Elektroda, Homo_toxicus, post #17722445]
Which wires do I connect when using only the remote control?
Connect L and N to power the motor, and leave control leads unused. Then program the remote to the actuator; the radio receiver is built in. [Elektroda, Anonymous, post #17722227]
What is the green-yellow wire for?
It is the protective earth (PE). Always connect PE for safety and compliance when powering the shutter motor. Do not leave PE floating. [Elektroda, Anonymous, post #17722377]
How many wires should I expect from the shutter motor?
Typical installations expose five conductors from the motor bundle. This includes power, earth, and two control leads for up/down. [Elektroda, tinca2, post #17722090]
How do I verify the actuator model and a manual’s authenticity?
Use manuals with manufacturer logos and clear product identification. One user shared an official INEL manual with branding on each page for the radio motor used. Avoid unattributed scans. [Elektroda, Homo_toxicus, post #17724348]
What switches work for manual control (without remote)?
Use tactile/momentary switches that feed N to either black or brown, never both. One direction must be open while the other operates. Direction mapping may swap; test briefly. [Elektroda, Anonymous, post #17722117]
What’s a safe fallback if I’m unsure about the diagram?
Stop and read the motor’s manual carefully, or hire a qualified installer. Quote: "You can do great harm to someone with an incompetent connection." [Elektroda, Homo_toxicus, post #17722325]
After wiring, the shutter moves wrong direction or not at all—what should I check?
Check that black and brown are insulated or not both tied to N. Ensure only one control lead is ever fed. Then enroll the remote correctly. Misusing both leads blocks motion or harms the motor. [Elektroda, Anonymous, post #17722478]
What connection finally worked for the OP’s Drutex shutters?
They reported success with brown-to-brown, blue-to-blue, and green-yellow to PE, with black and grey insulated. Always verify against your motor’s labeling before copying. [Elektroda, tinca2, post #17724163]
Do I need an external radio receiver for Drutex radio motors?
No. The actuator includes a built-in radio receiver. Supply L and N, then program the remote to the motor’s memory. [Elektroda, Anonymous, post #17722227]
What if my wire colors don’t match the advice here?
Color codes vary by actuator batches. One installer saw non-standard colors and wired per the manual successfully. Verify functions instead of assuming standards. [Elektroda, Anonymous, post #17722478]
