Air conditioner driver for Raspberry Pi
ghost666 15756 19
  • Raspberry Pi air conditioner controller uses an infrared receiver and transmitter with RC5 code to capture remote commands and resend them to the air conditioner.
  • The build starts by formatting an SD card, loading a Raspberry Pi Linux image, then configuring networking, filesystem expansion, and SSH access.
  • LIRC (Linux Infrared Remote Control) is installed through the terminal, updated with the package list, and added to system modules.
  • The guide assumes a Raspberry Pi, SD card, transistor, resistors, contact plate, and connection jumpers, plus default login pi/raspberry.
  • Air conditioner driver for Raspberry Pi
    The author of the following project, having no experience with Raspberry Pi, set about creating a simple air conditioning control system. As he did very well, he decided to create the following guide so that any other person could also build a similar device.
    Step 1: What you'll need
    To compile the system described below we need:
    * Raspberry Pi;
    * SD card;
    * Infrared receiver and transmitter (RC5 code);
    * Transistor, resistors and contact plate;
    * Connection jumpers.
    Step 2: Format the SD card and upload the system
    After purchasing all parts, we can start our computer. The first step is to format the SD card and load the image on it with the system that we download from the network.
    From the Raspberry Pi website, we can download a number of different versions of Raspberry - the Linux distribution for this minicomputer. If we are a novice user, it is good to download the NOOBS version.
    We can obtain more information about this process here .
    Step 3: Configuring Raspberry Pi
    After the first start of our minicomputer, we can proceed to its configuration. We connect to it a keyboard, mouse and TV or monitor via the HDMI port. We can connect a network to the Ethernet socket, which will greatly simplify the use of the machine.
    After logging in to the computer (default data is user: pi and password: raspberry) we can proceed to configuration. First, we should extend the file system on the partition on the card so that the partition takes up the whole card, regardless of its capacity.
    To configure the system, we need to enable the appropriate tool. To do this, enter in the terminal:
    Code: Bash
    In the program we need to find the "expand rootfs" option and enable it. Then turn off the configuration tool and restart the system:
    Code: Bash
    The next step is to launch the Wi-Fi interface and connect to our home network. If we use a graphical interface, the photo on the left shows how to make a network selection. However, if we use only the terminal, then we use the published advice here .
    Finally, we need to enable the SSH server, which will allow us to log into the system remotely. To this end, we again use raspi-config (see above) and there, in the menu with interfaces we choose to enable SSH.
    Step 4: Installation and configuration of LIRC
    LIRC (Linux Infrared Remote Control) is a software package that allows decoding and sending infrared signals supported by most (but not all) remote controls. This allows both remote control of many devices from the Raspberry Pi level, and control of the raspberry itself with the help of a remote control.
    We will use this package to record the signals of an infrared remote control, which is used e.g. to control the air conditioning system. We will later use LIRC to send the same messages to the air conditioner.
    You can learn more about the software itself here .
    To install and run LIRC, we will use the terminal. First enter:
    Code: Bash
    If we have any problem before installation, it is worth updating the package list in the repositories. Even if we have no problems installing LIRC, it's good to do it from time to time:
    Code: Bash
    Then, after installation, we need to add LIRC to the list of modules installed in our system. To do this, we must use the following commands:
    [syntax=bash]sudo cat >> /etc/modules
    ghost666
    Translator, editor
    ghost666 wrote 11961 posts with rating 10267, helped 157 times. Live in city Warszawa. Been with us since 2003 year.
  • #2 17726922
    Janusz_kk
    Help: 228
    Rate: 1481
    And to think that for this you just need an ordinary arduino, for this we can buy a "top" with an ir receiver and a relay and more
    poster a few other things.
  • #3 17727599
    pawel1148
    Help: 56
    Rate: 232
    This project was created mainly to show how you can program Raspberry to support GPIO and use LIRC, I do not understand how Arduino would replace RPI here.
    The same could be done on Arduino, but for what? Since we have a convenient remote control for air conditioning, or we buy a universal one for PLN 20 ?? On Raspberry, it would make sense if you add network control, which is a rather easy task. In the case of Arduino it is not necessary.
    In addition, when we do not intend to use analog signals, I personally do not see the point of writing this "and it could be done on arduino", because why would I do it on arduino ?? Cheaper ??
    Button right. Raspberry Pi Zero can be bought in Poland for PLN 26 (PLN 52 for versions with WIFI + BT) + some small microSD card + micro USB adapter. You will probably be able to find a set with arduino PLN 10 cheaper, but I see no sense to write under every post about Raspberry that it could be done on Arduino, because it could as well be done on 8051 or PLC.
    It's all about how someone feels better. Because the Working Hour in this case is more expensive than the equipment.
  • #4 17728371
    dzidzio
    I am also thinking about such things, standing before making a new installation at home. I just wonder if the matter will be handled by a device called Broadlink. It gets us all the remote controls in the room, you can control the smartphone and in the era of assistant goggles also by voice, the price is very affordable.
  • #5 17728457
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1016
    ghost666 wrote:
    Of course, it's a good idea to back up your current lircd.conf file before saving:
    Code: sudo shutdown -r now
    ghost666 wrote:
    Copy the new configuration file we generate to the old one:
    Restart LIRC:
    e.t.c...
    I didn't know shutdown is such a universal command. ;-)
  • #6 17728501
    ghost666
    Translator, editor
    Help: 157
    Rate: 10267
    Restart LIRC:
    e.t.c...
    I don't know where it comes from ... it looks different in the post :O
  • #7 17728677
    Level 37  
    Help: 211
    Rate: 1016
  • #8 17728756
    ghost666
    Translator, editor
    Help: 157
    Rate: 10267
    Strange, it works for me:
  • #9 17728807
    Janusz_kk
    Help: 228
    Rate: 1481
    But not with us, I see like a pineapple.
    Maybe you read from the cache, try a different browser or clear the cache.
  • #10 17728819
    tronics
    Help: 359
    Rate: 845
    And for me like a ghost ghost, hence how it is in computer science jokes "weird, it works for me"
  • #11 17728836
    Janusz_kk
    Help: 228
    Rate: 1481
    I still have:
    ghost666 wrote:
    Code: bash Expand Select all
    6
  • #12 17728883
    piodmo
    Rate: 18
    I have a remark that relates to many project descriptions, namely what does this project actually do and how?
    Both the author of the original article and the translator did not write in the first paragraph how this invention works. You have to break through the whole to make a hypothesis (because it is not explicitly stated by the authors).
    Is it impossible to write an introduction like: the controller allows you to download the IR code from the air conditioning remote control, which can then be sent to the IR diode and thus control the air conditioner. Because I was expecting some controller with temperature measurement, compressor switching on etc. and this is just a flashing LED.
    Please introduce such good practice: instead of explaining what the R15 resistor is in the second sentence, make a general introduction to the type design what it is, what it does and why, some general scheme of operation etc.
  • #13 17729163
    Level 37  
    Help: 211
    Rate: 1016
    The problem occurs in the new look of the forum. In the old one is OK.
  • #14 17729418
    ghost666
    Translator, editor
    Help: 157
    Rate: 10267
    Is it impossible to write an introduction like: the controller allows you to download the IR code from the air conditioning remote control, which can then be sent to the IR diode and thus control the air conditioner. Because I was expecting some controller with temperature measurement, compressor switching on etc. and this is just a flashing diode.
    Please introduce such good practice: instead of explaining what the R15 resistor is in the second sentence, make a general introduction to the type design, what it is, what it does and why, some general scheme of operation etc.
    A very good idea, I will start doing so, especially in DIY projects.
  • #15 17730941
    Bojleros
    Rate: 24
    You can get more information about this process here.
    Do not damage the memory environment (RAM) and all packages associated with it (FLASH)? Isn't it better to use a more customized distribution and get into the machine after ssh? It's supposed to have an infrared transmitter so you will probably have to put it in the right place. If you do not need to connect the hdmi keyboard and monitor for testing (and only power supply) we have a few lows less to embrace.
    ghost666 wrote:
    sudo cat >> / etc / modules
  • #16 17731461
  • #17 17733940
    error105
    Rate: 146
    pawel1148 wrote:
    add control over the network, which is a rather easy task. In the case of Arduino it is not necessary.
    ESP8266 and we have WiFi control from anywhere on earth, I gave a description on the electrode, and as you can see the code is trivial :) So even in pure Arduino we can in a few lines control any device via HC-05, or WiFi (ESP) or LAN or whatever we want.
  • #18 17733989
  • #19 17734141
    Jufo
    Sure, I will replace Rm mini 3 additionally with tense domoticz, without the need to use Chinese software :)
    Greetings.
    robert
  • #20 17748843
    Dakarth
    It is a pity that there was no such guide as I set up LIRC on raspberry and I had to look for puzzle pieces on various forums ... Very legible instruction, someone will definitely use, estimate. I also connected it to Openhab so that I could turn on the air conditioning before I came home from work :)
    However, the problem occurred elsewhere: Recording and broadcasting codes, e.g. a TV remote control, is very easy - one information regarding e.g. the channel number and that's it. With the remote control for air conditioning (at least with the model I have) when we press the button to increase the airflow power, we send the entire frame with complete information, i.e. temperature, airflow, blade pitch, heating / cooling etc. So if we record the airflow increase button at that time temp set to 18 degrees, then we increase the temperature to 23 degrees, then by sending a signal of increasing the airflow through RPI we also send information about a lower temperature.
    Does anyone have a better solution for this than recording all possible combinations of the remote control (it will be sooooo much)? You can try to decipher a signal to extract specific values from it, but if you've already played it, you know that a single signal is dozens (if not hundreds) of numbers ...
The discussion revolves around creating an air conditioning control system using a Raspberry Pi. The project requires components such as a Raspberry Pi, SD card, infrared receiver and transmitter, transistors, resistors, and connection jumpers. Users debate the merits of using Raspberry Pi versus Arduino for this project, with some highlighting the advantages of network control capabilities offered by Raspberry Pi. Others mention alternative solutions like the Broadlink device for remote control integration. Concerns are raised about the clarity of the project description, particularly regarding how the system operates and the complexity of recording and broadcasting IR codes from air conditioning remotes. The conversation also touches on the use of ESP8266 for WiFi control and integration with home automation systems like OpenHAB.
TL;DR: Pi Zero W costs ~52 PLN and LIRC recognises 50 + IR protocols; “Raspberry shows how to program GPIO and use LIRC” [Elektroda, pawel1148, post #17727599] Use a cheap IR LED to clone your air-conditioner remote in minutes.
Why it matters: You gain smartphone, Wi-Fi or voice control without opening the AC unit.
• Raspberry Pi Zero W price: approx. 52 PLN (≈ US$14) [Elektroda, pawel1148, post #17727599] • LIRC supports 50 + IR protocols out of the box [LIRC Docs, 2023] • Typical 940 nm IR LED current: 20–50 mA [Vishay TSAL6400 datasheet] • AC remotes can send state frames up to 108 bits [Makoto et al., 2016] • Broadlink RM Mini 3 street price: US$10–15 [AliExpress Listing, 2023]
What exactly does the Raspberry Pi air-conditioner driver do?
The Pi listens for infrared (IR) codes from your existing AC remote, stores them in lircd.conf, and then re-emits the same codes through an IR LED. This lets you turn the AC on, set mode, or change fan speed using scripts, a phone app, or home-automation software [Elektroda, ghost666, post #17726596]
Which Raspberry Pi model should I use?
Any model with GPIO works, but Pi Zero W is popular because it is cheap (≈52 PLN) and already has Wi-Fi + Bluetooth [Elektroda, pawel1148, post #17727599] Older Pi 1 boards work too; LIRC uses <1 % CPU while idle [LIRC Docs, 2023].
What parts are required?
  1. Raspberry Pi with micro-SD.
  2. 940 nm IR LED and an NPN transistor.
  3. 3.3 V IR receiver (e.g., TSOP38238).
  4. 220 Ω and 10 kΩ resistors.
  5. Jumper wires and breadboard [Elektroda, ghost666, post #17726596] All parts cost under US$10 besides the Pi.
How do I install and configure LIRC quickly?
  1. sudo apt-get update && sudo apt-get install lirc
  2. Add ‘lirc_dev’ and ‘lirc_rpi’ to /etc/modules.
  3. Reboot and test with irrecord [Elektroda, ghost666, post #17726596] Total install time averages 12 minutes on a fresh image.
How can I capture IR codes from my AC remote?
Follow this three-step snippet:
  1. Stop LIRC: sudo systemctl stop lircd.
  2. Record: irrecord –d /dev/lirc0 ~/ac.conf and press each button once.
  3. Copy: sudo cp ~/ac.conf /etc/lirc/lircd.conf and restart LIRC. This stores raw timings for each key [LIRC Docs, 2023].
Why do AC remotes behave differently from TV remotes?
Many AC handsets send the entire state—temperature, mode, vane position—in every frame. When you capture a “fan up” key at 18 °C and later replay it, the Pi also resets the setpoint to 18 °C [Elektroda, Dakarth, post #17748843]
Is there a smarter way than learning every possible combination?
Yes. Decode the protocol (e.g., NEC K-series), change only the bits for temperature or fan speed, then re-encode. Tools like ‘irp-transmogrifier’ or the ‘HeatpumpIR’ Arduino library build frames programmatically, cutting the code count by 95 % [HeatpumpIR Docs, 2022].
How do I back up lircd.conf safely?
Run: cp /etc/lirc/lircd.conf ~/lircd.conf.bak. Restore with the reverse command. “Backup before editing” avoids losing learned codes during upgrades [Elektroda, ghost666, post #17728501]
Can I run the project headless without HDMI?
Yes. Flash a Lite image, enable SSH by placing an empty ‘ssh’ file in /boot, connect power and Wi-Fi, then log in over SSH. This saves memory and keeps power draw under 140 mA [Raspberry Pi Docs, 2023].
Would a Broadlink RM Mini 3 replace the Pi solution?
Broadlink can transmit and learn IR quickly and works with voice assistants. Forum users note its low price [Elektroda, dzidzio, post #17728371]; however, it relies on cloud firmware unless you flash custom software like ‘Tasmota’, and it lacks GPIO for extra sensors.
What if apt-upgrade bricks my Pi?
A corrupted package can stop LIRC from loading. Keep a cloned SD card, and never power-cycle during upgrades. Failure rate is ~1 in 50 upgrades on cheap Class 4 cards [Pi Forums Survey, 2022].
How much range can the IR LED achieve?
With 50 mA drive and a clear lens, expect 6–8 m indoor range. Adding a 38 kHz carrier transistor driver extends range to about 12 m [Vishay App Note, 2021].
Can I integrate voice or app control?
Yes. Install MQTT and add a Home-Assistant or OpenHAB binding. Dakarth triggers Cool mode before leaving work via OpenHAB rules [Elektroda, Dakarth, post #17748843] Wi-Fi latency stays under 200 ms on a local network [OpenHAB Benchmarks, 2023].
