ESP32-WROVER vs WROOM: Understanding pSRAM, Advantages, Disadvantages & SDRAM Inclusion
JanuszKornas 15699 4
  • #1 17754213
    JanuszKornas
    Help: 6
    Rate: 25
    I am thinking of buying to roughly touch some ESP8266 or ESP32 module. I am reading this page:
    https://en.wikipedia.org/wiki/ESP32
    and I see that the WRover differ from WROOM in that they have pSRAM
    I have not found a Polish explanation of what pSRAM is, except for descriptions that it is Pseudo Dynamic and refreshed less frequently. If it's the same and can be refreshed less frequently, is it only better? Any other disadvantages?
    And the second question in this layout comparison table for WROOM is only the size of the Flash memory. And yet SDRAM, some must have?
  • #3 17754679
    kaczakat
    Help: 317
    Rate: 231
    The RAM is in the ESP32 chip and all modules have the same, FLASH and PSRAM are separate silicon cubes "stuck" to the SPI, so their size is given, because they can be different.
    khoam wrote:
    Yes, SRAM. The manufacturer's documentation for ESP-WROOM-02 says:
    this is just from a completely different story.
  • #4 17754703
    tronics
    Help: 358
    Rate: 841
    PSRAM is dynamic memory with internal refreshing logic so from the outside it can be treated as static SRAM (hence the name pseudo static ram). Why such inventions? Because you can connect large memories quite cheaply. SRAM is expensive. DRAM is cheap. PSRAM is more expensive than DRAM but cheaper than SRAM.
