[Solved] ESP32 with Arduino IDE: Setup, Server with MIT App Inventor, Bluetooth, TFT ILI9486
Kiboooo 2127 5
  • #1 17777352
    Kiboooo
    I have an esp32 however I have never used it as I have always worked on an arduino. And i have a few questions:
    1 how to upload the esp32 to the arduino ide as it is not in the device list?
    2 how do I create a server to which I can send information from several phones simultaneously with the help of MIT APPinventor?
    3 how to use Bluetooth on this module to send data and receive it?
    4 and how to connect a tft ili 9486 4" screen to the esp.
    Which library to use and how to program the image display and touch reading?
  • #2 17780333
    Kiboooo
    I am sorry if I have offended anyone, because that is not what I meant. I am simply "in hot water" and I want everything now. As far as searching the Internet is concerned, I am used to the fact that I often do not find answers to my questions. So I use the electrode. I wrote the previous message not with the aim of offending anyone but to liven up the discussion, so I hope you will forgive me for this mistake.
  • #3 17780425
    Misiaell
    Rate: 31
    Don't you think that this forum is for solving problems that you can't find on the web or their solutions are not clear. People here reach out for help in solving a problem or advice. What you are asking about is at your fingertips after typing a few simple phrases into a search engine . As for the second statement I find it terribly outrageous. You have the opportunity to consult experienced people who deal with this seriously in addition you have the opportunity to get help for free. So you cannot demand answers. If someone wants to they will answer your questions, and you should not think that an answer is simply due to you because you wrote a post. Regards
  • #4 17780451
  • #5 17791816
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    You would have to write a paper to answer your questions. To start with, install the ESP 32in Arduino platform, download a sketch and e.g. wink a diode. Then write your program and only then ask what your problem is, inserting your code of course. There are plenty of tutorials on the web on how to install ESP, so no one will write another one here.
  • #6 17814021
    Kiboooo
    Ok, so first I will look on the internet and look myself how this module works. Alternatively, if I need help I will post on the forum.
