How to Upload .bin File to ESP8266 (ESP-12E) via OTA Without Disassembly?
egon-tv 2436 4
  • #1 17825995
    egon-tv
    Help: 5
    Rate: 35
    Welcome,
    I have a device made on ESP (unfortunately I didn't make it because I have no knowledge). I have a new .bin file with soft for it.
    How to upload it via OTA (the device is sealed and I can't take it apart).
    I installed the Andruino, downloaded the files to support the ESP8266. but I don't know how to upload the BIN to the device. I can connect to the device directly (it has a client) at address 192.168.1.1. Andruino sees it because in the bottom right I have info that it sees the ESP8266 at the address indicated but what to do next. Maybe someone can spare a few minutes to describe it to me in a simple way. I select the port with the address as in the screen shot but there is no option like upload bin or something like that.... Thank you in advance for your guidance.
    How to Upload .bin File to ESP8266 (ESP-12E) via OTA Without Disassembly? .
  • #2 17826271
  • #3 17826365
    kaczakat
    Help: 317
    Rate: 231
    If you have the bin file, it is uploaded via the configurator web page in ESP (you should have WIFI manager). Log in to ESP - SYSTEM SETTING tab, indicate the file to be downloaded and follow the instructions.
  • Spiffs.bin offset for ESP8266 OTA upload
    #5 17828016
    egon-tv
    Help: 5
    Rate: 35
    How to Upload .bin File to ESP8266 (ESP-12E) via OTA Without Disassembly? Gentlemen - the subject is back on the agenda.
    ESP 8266 version 4 MB - I need to upload two files - one is "program.bin: which I program from address 0x00000. But from what address do I program the second file "spiffs.bin" from the second memory space? I can't find this anywhere...
