ESP8266 and OTA - programming from your own application in C#
Adix3 1473 3
  • Need for C# app to upload ESP8266 bin over Wi‑Fi
    #1 19608123
    Adix3
    Rate: 21
    Hi.
    I'm new to programming the ESP8266 using the Arduino IDE. I would like, to be able to reprogram the soft from my own application written for the computer in C# in Visual Studio, just don't know how to bite it....
    I know there's a sample ArduinoOTA program in Arduino that allows you to program the ESP8266 over WiFi directly from the Arduino IDE, but I'd like to do a similar upload from within my own application. Perhaps someone has already done something similar and could direct what to use etc?
    Of course, by this "programming" I mean something like this: in this application of mine, in a graphical way, I would select a .bin file with the compiled software and upload it remotely (within the local WiFi network) to the ESP8266 chip.
  • #2 19608278
  • OTA update impact on EEPROM and flash partition settings
    #3 19609000
    Adix3
    Rate: 21
    And how is it with this software upload using OTA, because I read somewhere that the ESP8266 does not have a physical EEPROM but emits such memory from Flash. If I update the software via OTA, do I also lose the data held in EEPROM?
    And do I need to change anything in the configuration of the ESP8266 in the Arduino IDE? Because there are different Flash memory capacities to choose from and they have some FS and OTA capacities in brackets, is this something important?
  • OTA uses a separate flash partition from EEPROM
    #4 19625961
