Alternative to Eaton XC-303 and XV-102 in car park lighting control
djbully 1071 4
  • #1 17963697
    djbully
    Rate: 13
    Hello, I have a project to control car park lighting on an Eaton XC-303 and four XV-102 touch panels.
    As I haven't dealt with the subject of light yet and for programming I need Codesys, which is not free this question:
    What can I replace the Eaton with to minimise costs?
    You need 69 outputs to drive and a minimum of the same number of inputs. Some scenes will need to be done on the panels.
  • #2 17964121
    daro31ie
    Automation specialist
    Help: 366
    Rate: 649
    The market is now full of companies offering controllers from the Far East at reasonable prices.
    The software is usually free of charge.
  • #3 17984265
    ditomek
    Help: 24
    Rate: 230
    Another cheap PLC that comes to mind is WAGO. But it too needs codesys
    I think you will have to get one somewhere though
  • #4 18064707
    tomi513
    F&Home RADIO
  • #5 18068600
    gag70
    Help: 65
    Rate: 76
    Delta, Fatek, Wecon.
    All of these companies also have panels at reasonable prices (Fatek is Multiprojekt so Weintek).
    They all have free software for PLC and panels.
    The application is of the genre that does not take up device memory and designer time.
    edit: that Eaton controller is some big fly cannon
