Where to find tutorials for ESP8266 in C? I am looking for structure, timers, interrupts
eriq2207 882 1
  • Requesting ESP8266 C tutorials on structure and interrupts
    #1 17979275
    eriq2207
    I have quite a lot of knowledge in Arduino programming. I would like to start the adventure of programming the ESP8266 module. My main goal is to use the source codes of the supla software to create my own device that I can modify fairly flexibly.
    My problem is that I have not found any solid documentation or tutorials for programming the NodeMCU in c. Everything I've come across has been based on either the Arduino IDE or the classic language without using the SDK.
    Is anyone able to recommend some material I can use? I am mainly concerned with program structure, timers, interrupt handling etc.
    Thank you in advance.
  • ESP8266 RTOS SDK and Kolban book recommended
    #2 17979308
