Smart Home Wiring: Ethernet, Alarm, SAT, Wired vs Wireless Systems?
gmp 2883 13
How should I wire a renovated house for Ethernet, alarm, SAT and smart-home automation: wired or wireless, and what cables should I run now?
Use a wired, star-topology installation with everything brought to a central point, and leave room for future expansion in that cabinet [#18095690][#18096209][#18096222][#18099761] For Ethernet, run cables to each room as needed, plus to access points, switch/router location, and any devices you want to keep on a stable network; one reply recommends planning the number of devices per room and even keeping a single socket per room if you can split it later with a switch [#18095690][#18096645] For the alarm, do not guess the sensor layout yourself: ask the installer for help, because detector placement and cabling points are not obvious [#18095690] For smart-home automation, wired is preferred over wireless because wireless can be interfered with and loses range through walls, but the installation should be made for a specific automation system or at least route all circuits through the automation switchboard first [#18094878][#18095690] Also lay conduits or straight cable paths for future additions, because the biggest limitation later is usually the lack of a place to add more cables without demolition [#18099761][#18096828]
  • Recommend Ethernet to every room and wired alarm loops
    #1 18094839
    gmp
    Level 19  
    Help: 29
    Rate: 28
    I will soon be converting the installation from 2 wire (1988r) to normal. As forging is unavoidable - I would like to add other installations as well - alarm, SAT for a few rooms, Ethernet, and maybe a control for the Smart Home.
    What's worth doing? Maybe some other ideas still?
    Give Eth cables to each room?
    Give alarm cables to every outside door and window?
    Should I base the smart home on a wired installation or a wireless one (e.g. something like Fibaro)?
    If on a cable, are there any modules for sockets, lighting that can be bought?
  • Wired-first layout with UPS bypass switch
    #2 18094878
    Janusz_kk
    Help: 228
    Rate: 1478
    A wired system is always better than a non-wired system (wi-fi can be easily interfered with and bandwidth through walls decreases considerably). For this reason, you should have a twisted pair of cables for each light outlet in the room (for future remote light control), plan the sockets of the comp network and pull the twisted pair of cables there; you can also isolate one circuit for maintaining the network and put lighting on it (not the whole circuit, but one lamp per room), some sockets e.g. for a computer, router, refrigerator. Give the UPS-SIEC switch at the beginning of the circuit, then a normal power supply and a differential. And to the UPS only a normal circuit breaker and from it to the switch. This way, if the UPS fails, you can switch to the normal power supply, and if the power supply is OK, it will go through the UPS.
  • Centralize Ethernet and plan spare conduits
    #3 18095690
  • Plan for future cable access and room changes
    #4 18095808
    Przemcio
    Help: 196
    Rate: 257
    Erbit wrote:
    It is not that simple or obvious. Such installations can be done in a number of methods, and presumably each speaker will have a different vision.
    Holy crap !
    Erbit wrote:
    As for Ethernet - I'm an advocate of bringing all cables to one central point. There a switch, a router and that's it. Here you have to anticipate the number of devices in each room and only to that .... cables. Plus cables to the AP where necessary.
    And so you end up putting a switch in each room - that's another Holy Truth :D .
    Erbit wrote:
    That's it in a nutshell. If you think you are going to do it yourself and it will be fine then you are wrong. I have already made several mistakes thinking I know what I am doing and in fact only now do I know how I would like to do it which I have described in a few sentences above.
    It's not like that. I myself am at the stage of "ditching" from basement to attic of an old cottage, and I wonder if my great-great-great grandson will use Wi-Fi to open the gate or perhaps the Force of the Jedi Knights. :D .
    It's worth thinking about so that changes and modifications can be made without having to re-do the whole cottage.
    And that's really where the difficulty of the whole installation operation lies.
    Therefore ...
    Erbit wrote:
    One ideal would be feed-throughs (channels) which would allow the installation to be supplemented in the future with e.g. TV cables, additional Ethernet cables, etc. This is because sometimes the purpose of a room changes (e.g. growing children) and a problem arises because "you have to put a switch" or "pull the cables behind the skirting boards". This does not happen very often, but still...
    It is worth thinking about "wickets" that allow changes and modifications to be made.
    This allows you to use one system today and something supposedly more modern or(and) completely different tomorrow.
    A system is one thing and preparing a house for modifications without demolition is .... another matter.
    By the way Link .
    P.
  • #5 18095865
  • Links to related smart home wiring discussions
    #6 18096125
    suworow
    Help: 650
    Rate: 1278
    It looks like the one koelga wrote @Erbit in #3
    Regarding inspiration, let me toss in two topics for you to read.
    One completely loose, a bit of fun by our colleague @marek216
    https://www.elektroda.pl/rtvforum/topic3412319.html#16917367
    and a second one where not only the individual installations are discussed, but also how they are interconnected:
    https://www.elektroda.pl/rtvforum/topic3547264.html#17787519
    It is one thing to be inspired, but it is quite another to install an installation correctly, in accordance with the needs and the existing conditions.
  • Star topology simplifies maintenance and upgrades
    #7 18096209
    genuine486
    Help: 20
    Rate: 59
    I know from experience that only a star topology.
    central point allows for order and upgrade. it is also easier when professional help is called for. the wires are labelled and everything is in its place. working in such a house is immediately easier.
    You don't have to use lan at all and rely solely on wi-fi, but you always have a less fail-safe solution. If you are talking about unavoidable forcing, then maybe you could run it along the façade? unless you already have insulation, then that's a bummer.
  • Star topology eases future intercom and camera expansion
    #8 18096222
  • Recommend Ethernet plus 8-core alarm wiring
    #9 18096645
    gmp
    Level 19  
    Help: 29
    Rate: 28
    Ethernet - star topology as much as possible, but I can't predict how much equipment there will be in the future and whether this technology will be used at all in 10 years' time, so 1 socket, and you can always make 2 sockets out of 1 cable - or eventually a switch.
    Alarm installation - also, although if you run 8 wires, you can connect several detectors on 1 cable. My house is not a fortress and I am not a millionaire...
    Electrical installation - star topology is too many wires for me - especially lighting, of course, the kitchen has several power supplies, bathrooms separately, but the rooms do not need separate ones - not much power-consuming equipment now.
    Intercom: taking advice I think I'll do eth + 8 strands of alarm, we'll see what comes in handy.
  • Star topology needs a spacious central point
    #10 18096828
    retrofood
    Help: 1140
    Rate: 4797
    centre point allows for order and upgrade.
    It is only in this central point that you need to provide room for expansion . Because in the frenzy of planning, the concern not to forget anything, somehow it usually escapes us that this mythical "focal point" likes to be quite large after all. And after all, it must not be an ugly hindrance to householders and non-household alike.
  • 8-wire alarm cable can serve multiple detectors
    #11 18096926
    suworow
    Help: 650
    Rate: 1278
    gmp wrote:
    Alarm installation - also, although if you run 8 wires you can connect several detectors on 1 cable. My house is not a fortress and I am not a millionaire...
    I'm sorry that I got out of the way with this help. My colleague started something about a smart house and alarm cables to each window, so I thought (wrongly) that we are talking about a properly made installations and not such a DIY, just to be :(
  • Need for expansion space at the focal point
    #12 18096994
  • Future-proof wiring with spare cable capacity
    #13 18097299
    Przemcio
    Help: 196
    Rate: 257
    gmp wrote:
    Ethernet - star topology as much as possible, but I can't predict how much future hardware there will be and whether this technology will even be in use in 10 years
    Do you think Ethernet will share the fate of the "wire" phone ?
    Taking into account some advantages of "wires" such as the difficulty of jamming the signal
    and the speed of transmission it will probably be used for some time yet.
    retrofood wrote:
    It is only at this focal point that space needs to be provided for expansion.
    And this is usually the most difficult part.
    After all, usually even in the design of a new house there is room for a boiler room but
    but the designer rarely thinks of a "server room".
    Well, maybe only when the building is designed from A to Z with an IQ slightly greater
    than a pine cone.
    And if the house is from the pre-Internet era, the larder is at most usable.
    To the Author.
    The installation should be, as they say, prepared for all possible
    and the most imaginative of all possibilities. Costs are rising, but who knows if at some point in the future there will be no installation of roller blinds,
    window detectors, intercoms in a few places because children grow up, etc. etc.
    Of course, it is not necessary to install all the devices at once, but ... In the event of a "W", the cable is already there and is just waiting. The more cables, the less Wi-Fi, although these days it is probably
    although nowadays it is probably easier to have Wi-Fi than cable options.
    But that's just blah, blah because the reality ... is quite different.
    Thus, a cool topic but very, very difficult because there is no ready recipe.
    P.
  • #14 18099761
    ditomek
    Help: 24
    Rate: 230
    Me on the subject of forging and puttying.
    Regardless of what you choose it's a good idea to lay down conduit for switches and sockets depending on the construction of the house.
    Just straight pieces from the box to the floor. If you need to add a cable in five years' time, you can simply run it through the cable duct to the floor without any drilling and it will still be there. Maybe you can hide it behind the plinth. Forget that you will be able to run a cable through a conduit that has some kinks in it. It's a myth.
    In my house, I have a wooden ceiling where all the cables go. The attic is not in use and the floor is covered with OSB.
    I also recently needed to add a new cable and the fact that he has sunken grommets in his boxes helped a lot. I simply unscrewed a couple of boards and laid the cable and inserted it into the grommet from above. No forging.
    And now for a bit of a different story.
    If you don't know what system you're going to use now, then choose a star and lay 5 x more cables than you originally planned.
    My opinion is that if someone doesn't build a system from the beginning but prepares for the future, he or she will end up with kilometres of unnecessary cables in the walls, because the probability that he or she will start to destroy an existing and working installation in the name of some kind of automation is small.
The discussion revolves around the installation of smart home wiring, focusing on the transition from a 2-wire system to a more comprehensive setup that includes Ethernet, alarm systems, and possibly smart home controls. Participants emphasize the advantages of wired systems over wireless, citing issues like interference and bandwidth limitations with Wi-Fi. Recommendations include running Ethernet cables in a star topology to a central point for better organization and future upgrades, as well as installing alarm cables to all entry points for enhanced security. The importance of planning for future modifications without extensive rework is highlighted, along with suggestions for using conduits for easier cable management. The conversation also touches on the necessity of consulting professionals for alarm installations and the potential for integrating various systems like intercoms and cameras using Ethernet.
TL;DR: Plan 5× more cables now; "choose a star" topology with straight conduits for future pulls. Keep runs accessible for painless upgrades later. [Elektroda, ditomek, post #18099761]
Why it matters: For renovators asking “wired vs wireless and what to pre‑run?”, this FAQ gives practical, future‑proof wiring choices and pitfalls to avoid.
What wiring topology should I choose for a smart home remodel?
Use a star topology. Bring every run to a central point and label them. It keeps order and eases upgrades. “I know from experience that only a star topology.” Plan access so pros can work faster later. [Elektroda, genuine486, post #18096209]
Do I need Ethernet in every room, or is Wi‑Fi enough?
Prefer wired where you can. Wi‑Fi is easy to interfere with, and throughput drops through walls. Run Ethernet to rooms and to AP locations, then use Wi‑Fi for mobile devices. This improves reliability and backhaul speed. [Elektroda, Janusz_kk, post #18094878]
Where should all network cables terminate?
Bring every Ethernet cable to one central point. Install a switch and router there. Estimate devices per room and pull matching cables, plus drops to planned APs. Centralization simplifies changes and troubleshooting. [Elektroda, Anonymous, post #18095690]
How many Ethernet runs if I can’t predict future needs?
At minimum, pull one drop per room and plan AP locations. If uncertain, accept you may split one cable to two jacks or add a small room switch later. This keeps options open without over‑committing. [Elektroda, gmp, post #18096645]
Will one cable to a room force me to add local switches?
Often yes. With only a single drop and many devices, you’ll end up placing a switch in that room. Pull extra runs now if you want to avoid extra hardware later. [Elektroda, Przemcio, post #18095808]
How do I future‑proof without opening walls again?
Install feed‑throughs or cable channels to each room. They let you add TV, Ethernet, or SAT lines later as needs change. Room functions evolve, so leave pathways ready now. [Elektroda, Anonymous, post #18095690]
What conduit practices make later cable pulls realistic?
Run straight conduit segments from boxes to the floor or accessible voids. Avoid tight bends; pulling through kinked conduits is a myth. Provide access points or grommets to drop new lines cleanly. [Elektroda, ditomek, post #18099761]
How should I pre‑wire for a burglar alarm?
Consult an alarm installer early. Detector placement and wiring routes are not obvious. Good planning decides which zones get dedicated runs and how to route to the panel cleanly. [Elektroda, Anonymous, post #18095690]
Can several detectors share one alarm cable?
Yes, as a budget approach. With an 8‑core run, you can connect several detectors on one cable. It trades per‑zone detail for lower wiring cost—fine for non‑fortress scenarios. [Elektroda, gmp, post #18096645]
How can I avoid nuisance alarm triggers that people ignore?
Poorly planned systems can false‑alarm at night and get ignored. Work with pros on detector choice and placement. Reduce false alerts to preserve trust and response. [Elektroda, Anonymous, post #18096994]
Can I run intercoms and cameras over Ethernet?
Yes. Modern intercoms and cameras are easily built on Ethernet. Pre‑wire to likely device positions and home‑run to the central switch for simple power and network management. [Elektroda, Anonymous, post #18096222]
How should I plan for smart‑home automation if I haven’t chosen a platform?
Wire for centralization. Home‑run controlled circuits to the automation switchboard, then onward to the protection board. This keeps options open for different systems later. [Elektroda, Anonymous, post #18095690]
How do I wire an essential UPS‑backed circuit?
Create a small “maintenance” sub‑circuit. 1) Feed it via a UPS‑to‑mains changeover switch with a breaker on the UPS side. 2) Put one lamp per room and key sockets (router, PC, fridge) on that sub‑circuit. 3) Keep the normal supply and differential on the rest to switch over if needed. [Elektroda, Janusz_kk, post #18094878]
How much space should I reserve for the central point?
Leave generous room for expansion. The focal point tends to grow with switches, patching, and power gear. Keep it accessible and not visually intrusive. [Elektroda, retrofood, post #18096828]
Should I label and document every run?
Yes. Labeled home‑runs make upgrades and professional help straightforward. “The wires are labelled and everything is in its place.” It saves time and mistakes later. [Elektroda, genuine486, post #18096209]
Is Ethernet going away like landlines?
Unlikely soon. Cables resist jamming and deliver higher, stable speeds. Expect wired links to remain valuable for backbones and fixed devices for years. [Elektroda, Przemcio, post #18097299]
