How to connect a EURA AC-20C7 code lock to an electric door strike without a controller?
lukasz2231 2082 10
How can I connect a EURA AC-20C7 code lock directly to an electric door strike without using the controller?
The AC-20C7 only uses a relay to switch the strike circuit, so the strike must be powered from a supply with enough current. A separate strike supply should be about 300–350 mA, and if the keypad and strike share one supply, use at least 0.5 A; one reply recommends oversizing to 1 A [#18145200][#18145526] Test the output first with a small 12 V bulb: if it lights when the code lock unlocks, the wiring is correct, and only then connect the strike [#18145704] If the strike still does not open, the power supply is likely too weak [#18145200][#18145704] Add a diode across the strike to protect against voltage spikes [#18146612]
  • #1 18144921
    lukasz2231
    I have a problem with a EURA AC-20C7 code lock after connecting it to an electric door opener it does not open. I have connected it according to the YouTube video titled: "Video instructions for connecting the AC-20C7 code lock with the WS-70H1 wifi controller I EURA tech. ( without connecting the controller, which I do not want) please help
  • #2 18145034
  • #3 18145161
    lukasz2231
    Yes, there is a problem with the power supply to the deadbolt, as if there is not enough current going to it (unfortunately I do not know enough about electricity to explain this in any other way).
  • #4 18145200
  • #5 18145526
    CYRUS2
    Help: 1241
    Rate: 3536
    sharp wrote:
    Because the lock should be
    The power supply should have a current capacity of approx. 300 - 36.
    Not enough. It should be 1A.
  • #6 18145666
  • #7 18145696
    suworow
    Help: 650
    Rate: 1278
    This is no longer the electrical section :) .
  • #8 18145704
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    It may be that no voltage is reaching the electric door opener at all. It is best to use a small 12V bulb for the duration of the test. When it lights up (at the right moment), it means that everything is connected correctly. Only then can you connect the electric door strike, and then it may also turn out that the power supply is not current-efficient.
  • #9 18145712
    suworow
    Help: 650
    Rate: 1278
    zybex wrote:
    Maybe there is no voltage reaching the door opener at all.
    Perhaps many things, so much so that until the author gives details we can guess long and passionately.
    sharp wrote:
    What specifically do you have a problem with, because what you are writing about are generalities: with the power supply, with the control of the lock when correctly powered, or with something else?
    Draw on the diagram from the manual what connections you have.
  • #10 18145763
  • #11 18146612
    CYRUS2
    Help: 1241
    Rate: 3536
    A diode is needed on the bolt to protect against
    against overvoltage.
The discussion revolves around connecting a EURA AC-20C7 code lock to an electric door strike without using a controller. The main issue identified is insufficient power supply to the deadbolt, which is crucial for its operation. Participants emphasize the need for a power supply with a current capacity of at least 300-350mA, with some suggesting that a 1A supply may be necessary. Testing with a 12V bulb is recommended to verify voltage reaching the electric door opener before connecting the strike. Additionally, a diode is advised for overvoltage protection on the bolt.
