How to connect two keypads to an ORNO digital lock with one electric door strike?
BURMAR 2475 9
How can I connect a second ORNO keypad to the same electric door strike so both keypads can open it from opposite sides of the door?
Connect the second keypad through the lock’s relay/open-button input rather than wiring the strike in parallel, because these locks have a relay output and with one power supply there is no need for series diodes [#16888368] The suggested approach is to use the existing lock’s open-button input and have the new keypad control it [#16888368] Another reply confirmed this was the right approach for adding the extra keypad [#16888420]
  • Parallel keypad wiring for one door strike
    #1 16888240
    BURMAR
    Rate: 300
    I have this problem. Friends have a door lock in a shop warehouse for an electric door opener with an ORNO numeric keypad. Everything works OK but they want a second keypad to be connected to them on the other side of the door. So one electric door strike will be operated by two keypads powered from one power supply. I don't know how to implement this . Probably the two keypads are connected in parallel but someone once told me on another occasion that you have to use a diode which is connected in parallel with the electric strike. It seems to me that this does not make sense but maybe it has to be so. Please give me some information. The matter is very urgent.
    Regards
    zbich70
    Help: 1171
    Rate: 6666
    Perhaps you can give some indication of the type/model of equipment?
    Just stating the manufacturer doesn't say anything.
    kot mirmur
    Help: 206
    Rate: 561
    Hello, the parallel diode is connected in parallel to the striker el.in the negative direction, it acts as a protection. You have to give two additional diodes in series in the power supply circuit of the lock el.from each keypad.
    gkwiatkowski
    CCTV and Stationary Alarms specialist
    Help: 650
    Rate: 1230
    Remember that you need to provide a means of exiting the room in the event of a power failure or the lock electronics breaking down. That is, the electric door strike must be reversible and there must be a 'push glass to unlock' type escape button.
  • Clarifying diode isolation for shared striker power
    #5 16888336
    BURMAR
    Rate: 300
    Thank you very much for responding so promptly. As for the type of lock it is: OR-ZS-802.
    As for the emergency exit, there will be "showcases" with glass in each side of the door where the keys for the lock will be.
    Going back to the diodes, my understanding is that you have to insert a diode in series in the power supply of the striker so that the power from one keypad does not reverse through the electric striker to the other keypad. Did I understand this correctly?
    alster1
    Help: 352
    Rate: 540
    These locks have a relay output, with a single power supply there is no need for diodes in series.
    As far as I can see, there is an input for an open button, I would use this and control the new lock with the old one using this input.
  • #7 16888372
    kot mirmur
    Help: 206
    Rate: 561
    Yes , you've got it right, you just need to remember the polarity compatibility of the el.striker power supply from both keyboards. If it turns out that they do not match, use two rectifier bridges to supply the tap-on el. You connect the DC outputs of the bridge to the abutment el.s, the AC inputs to the control.
    mawerix123
    Help: 482
    Rate: 951
    BURMAR wrote:
    Returning to the diodes, my understanding is that a diode needs to be inserted in series in the power supply to the striker so that the power from one keypad does not back up through the striker to the other keypad.
    No, that's not why you put it there, read the topic describing your concerns --> https://www.elektroda.pl/rtvforum/topic3254338.html
    As for connecting a second keyboard I would use the idea alster1 to make the extra one control the old one.
  • #9 16888423
    BURMAR
    Rate: 300
    Once again, thank you very much for your help. Regards
  • #10 16890480
    BURMAR
    Rate: 300
    Hello again,
    I am after assembling the keypads. I took the advice of Alster1. Everything works OK. Thanks again to everyone for the help shown.
    Greetings
The discussion addresses connecting two ORNO numeric keypads to a single electric door strike powered by one power supply. The lock model is OR-ZS-802. It was clarified that the lock uses a relay output, and with a single power supply, diodes in series are generally unnecessary. Instead, the second keypad can be connected by utilizing the existing lock's input for an open button, effectively controlling the lock through the first keypad's circuitry. The parallel diode mentioned is typically connected in reverse across the electric strike coil to protect against voltage spikes. Polarity compatibility of the power supply to the electric strike from both keypads must be ensured; if mismatched, rectifier bridges can be used to correct polarity. Additionally, safety considerations include providing a reversible electric strike and an emergency exit mechanism, such as a "push glass to unlock" button or physical keys accessible through glass showcases. The solution implemented followed advice to control the second keypad via the first keypad's open input, resulting in successful operation.
